../.libs/libcgm.a(iGeom_CGMA.o): In function `iGeom_load_cub_geometry': /home/jason/cgm/test/64/itaps/../../trunk/itaps/iGeom_CGMA.cc:5794: warning: the use of `tmpnam' is dangerous, better use `mkstemp' /usr/bin/ld: warning: libstdc++.so.5, needed by /opt/acis16.7/bin/linux_amd_64_so/libSpaAVis.so, may conflict with libstdc++.so.6 In file included from /opt/occ6.2/ros/inc/TCollection_AsciiString.hxx:752, from /opt/occ6.2/ros/inc/TDF_LabelNode.hxx:16, from /opt/occ6.2/ros/inc/TDF_Label.lxx:11, from /opt/occ6.2/ros/inc/TDF_Label.hxx:345, from ../../trunk/geom/OCC/OCCQueryEngine.hpp:29, from ../../trunk/test/makept.cpp:12: /opt/occ6.2/ros/inc/TCollection_AsciiString.lxx: In member function ‘TCollection_AsciiString TCollection_AsciiString::SubString(Standard_Integer, Standard_Integer) const’: /opt/occ6.2/ros/inc/TCollection_AsciiString.lxx:112: warning: deprecated conversion from string constant to ‘char*’ In file included from /opt/occ6.2/ros/inc/TCollection_AsciiString.hxx:752, from /opt/occ6.2/ros/inc/TDF_LabelNode.hxx:16, from /opt/occ6.2/ros/inc/TDF_Label.lxx:11, from /opt/occ6.2/ros/inc/TDF_Label.hxx:345, from ../../trunk/geom/OCC/OCCQueryEngine.hpp:29, from ../../trunk/test/modify.cpp:13: /opt/occ6.2/ros/inc/TCollection_AsciiString.lxx: In member function ‘TCollection_AsciiString TCollection_AsciiString::SubString(Standard_Integer, Standard_Integer) const’: /opt/occ6.2/ros/inc/TCollection_AsciiString.lxx:112: warning: deprecated conversion from string constant to ‘char*’ In file included from /opt/occ6.2/ros/inc/TCollection_AsciiString.hxx:752, from /opt/occ6.2/ros/inc/TDF_LabelNode.hxx:16, from /opt/occ6.2/ros/inc/TDF_Label.lxx:11, from /opt/occ6.2/ros/inc/TDF_Label.hxx:345, from ../../trunk/geom/OCC/OCCQueryEngine.hpp:29, from ../../trunk/test/r_w.cpp:13: /opt/occ6.2/ros/inc/TCollection_AsciiString.lxx: In member function ‘TCollection_AsciiString TCollection_AsciiString::SubString(Standard_Integer, Standard_Integer) const’: /opt/occ6.2/ros/inc/TCollection_AsciiString.lxx:112: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/webcut.cpp: In function ‘int main(int, char**)’: ../../trunk/test/webcut.cpp:67: warning: unused variable ‘gti’ ../../trunk/test/webcut.cpp: In function ‘CubitStatus read_geometry(int, char**)’: ../../trunk/test/webcut.cpp:118: warning: unused variable ‘file_ptr’ ../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_brick()’: ../../trunk/test/webcut.cpp:139: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_cylinder()’: ../../trunk/test/webcut.cpp:194: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_planar_sheet()’: ../../trunk/test/webcut.cpp:245: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_sweep_curves_rotated()’: ../../trunk/test/webcut.cpp:299: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_sweep_curves()’: ../../trunk/test/webcut.cpp:365: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_sweep_along_curve()’: ../../trunk/test/webcut.cpp:425: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_curve_loop()’: ../../trunk/test/webcut.cpp:496: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_extended_surf()’: ../../trunk/test/webcut.cpp:553: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_sweep_surfaces_rotated()’: ../../trunk/test/webcut.cpp:600: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_sweep_surfaces()’: ../../trunk/test/webcut.cpp:651: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_sweep_surfaces_along_curve()’: ../../trunk/test/webcut.cpp:701: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_sweep_surfaces_perp()’: ../../trunk/test/webcut.cpp:761: warning: deprecated conversion from string constant to ‘char*’ In file included from /opt/occ6.2/ros/inc/TCollection_AsciiString.hxx:752, from /opt/occ6.2/ros/inc/TDF_LabelNode.hxx:16, from /opt/occ6.2/ros/inc/TDF_Label.lxx:11, from /opt/occ6.2/ros/inc/TDF_Label.hxx:345, from ../../trunk/geom/OCC/OCCQueryEngine.hpp:29, from ../../trunk/test/sheet.cpp:27: /opt/occ6.2/ros/inc/TCollection_AsciiString.lxx: In member function ‘TCollection_AsciiString TCollection_AsciiString::SubString(Standard_Integer, Standard_Integer) const’: /opt/occ6.2/ros/inc/TCollection_AsciiString.lxx:112: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/sheet.cpp: In function ‘int main(int, char**)’: ../../trunk/test/sheet.cpp:38: warning: unused variable ‘gqe_list’ ../../trunk/test/makept.cpp: In function ‘CubitStatus make_Point()’: ../../trunk/test/makept.cpp:118: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/makept.cpp:122: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/makept.cpp:126: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/makept.cpp:266: warning: unused variable ‘d’ ../../trunk/test/makept.cpp:183: warning: unused variable ‘is_equal’ ../../trunk/test/makept.cpp:271: warning: unused variable ‘new_face2’ ../../trunk/test/makept.cpp:312: warning: unused variable ‘area’ ../../trunk/test/makept.cpp:351: warning: unused variable ‘pc2’ ../../trunk/test/makept.cpp:355: warning: unused variable ‘num_loops’ ../../trunk/test/makept.cpp:360: warning: unused variable ‘angle’ ../../trunk/test/modify.cpp: In function ‘CubitStatus make_Point()’: ../../trunk/test/modify.cpp:196: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/modify.cpp:119: warning: unused variable ‘ref’ ../../trunk/test/modify.cpp:166: warning: unused variable ‘gme’ ../../trunk/test/modify.cpp:167: warning: unused variable ‘stitched_body’ ../../trunk/test/modify.cpp:489: warning: unused variable ‘occ_bodies’ ../../trunk/test/r_w.cpp: In function ‘CubitStatus make_Point()’: ../../trunk/test/r_w.cpp:128: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/r_w.cpp:155: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/test/r_w.cpp:177: warning: unused variable ‘d’ ../../trunk/test/r_w.cpp:179: warning: unused variable ‘n’ /usr/bin/ld: warning: libstdc++.so.5, needed by /opt/acis16.7/bin/linux_amd_64_so/libSpaAVis.so, may conflict with libstdc++.so.6 /usr/bin/ld: warning: libstdc++.so.5, needed by /opt/acis16.7/bin/linux_amd_64_so/libSpaAVis.so, may conflict with libstdc++.so.6 /usr/bin/ld: warning: libstdc++.so.5, needed by /opt/acis16.7/bin/linux_amd_64_so/libSpaAVis.so, may conflict with libstdc++.so.6 /usr/bin/ld: warning: libstdc++.so.5, needed by /opt/acis16.7/bin/linux_amd_64_so/libSpaAVis.so, may conflict with libstdc++.so.6 /usr/bin/ld: warning: libstdc++.so.5, needed by /opt/acis16.7/bin/linux_amd_64_so/libSpaAVis.so, may conflict with libstdc++.so.6 terminate called after throwing an instance of 'Standard_TypeMismatch' make[2]: *** [check-TESTS] Error 1 make[1]: *** [check-am] Error 2 make: *** [check-recursive] Error 1 gLoad: Read 1 ACIS Entities from the input file Constructed 1 Volume: 1 Model contents: vertices: 36 edges: 60 faces: 33 regions: 1 Success tags: Tags defined on model: GLOBAL_ID, NAME Success gentity sets: Success topology adjacencies: Success construct: Created swept volume 3 Success primitives: Success transforms: Success booleans: Updated volume(s): 10 Destroyed volume(s): 11 Updated volume(s): 12 Updated volume(s): 12 Destroyed volume(s): 13 Success TSTT TEST SUMMARY: Number Tests: 8 Number Successful: 8 Number Not Implemented: 0 Number Failed: 0 PASS: testgeom ================== All 1 tests passed ================== make[3]: Leaving directory `/home/jason/cgm/test/64/itaps' make[2]: Leaving directory `/home/jason/cgm/test/64/itaps' make[1]: Leaving directory `/home/jason/cgm/test/64/itaps' Making check in . make[1]: Entering directory `/home/jason/cgm/test/64' make[1]: Leaving directory `/home/jason/cgm/test/64' Making check in test make[1]: Entering directory `/home/jason/cgm/test/64/test' make sheet webcut modify makept r_w make[2]: Entering directory `/home/jason/cgm/test/64/test' if c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/occ6.2/ros/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_ACIS -DHAVE_OCC -Wall -pipe -g -MT sheet.o -MD -MP -MF ".deps/sheet.Tpo" -c -o sheet.o ../../trunk/test/sheet.cpp; \ then mv -f ".deps/sheet.Tpo" ".deps/sheet.Po"; else rm -f ".deps/sheet.Tpo"; exit 1; fi if c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/occ6.2/ros/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_ACIS -DHAVE_OCC -Wall -pipe -g -MT webcut.o -MD -MP -MF ".deps/webcut.Tpo" -c -o webcut.o ../../trunk/test/webcut.cpp; \ then mv -f ".deps/webcut.Tpo" ".deps/webcut.Po"; else rm -f ".deps/webcut.Tpo"; exit 1; fi if c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/occ6.2/ros/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_ACIS -DHAVE_OCC -Wall -pipe -g -MT modify.o -MD -MP -MF ".deps/modify.Tpo" -c -o modify.o ../../trunk/test/modify.cpp; \ then mv -f ".deps/modify.Tpo" ".deps/modify.Po"; else rm -f ".deps/modify.Tpo"; exit 1; fi if c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/occ6.2/ros/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_ACIS -DHAVE_OCC -Wall -pipe -g -MT makept.o -MD -MP -MF ".deps/makept.Tpo" -c -o makept.o ../../trunk/test/makept.cpp; \ then mv -f ".deps/makept.Tpo" ".deps/makept.Po"; else rm -f ".deps/makept.Tpo"; exit 1; fi if c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/occ6.2/ros/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_ACIS -DHAVE_OCC -Wall -pipe -g -MT r_w.o -MD -MP -MF ".deps/r_w.Tpo" -c -o r_w.o ../../trunk/test/r_w.cpp; \ then mv -f ".deps/r_w.Tpo" ".deps/r_w.Po"; else rm -f ".deps/r_w.Tpo"; exit 1; fi /bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -g -o sheet -R/opt/acis16.7/bin/linux_amd_64_so -R/opt/occ6.2/ros/Linux/lib sheet.o ../libcgm.la -lm /bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -g -o webcut -R/opt/acis16.7/bin/linux_amd_64_so -R/opt/occ6.2/ros/Linux/lib webcut.o ../libcgm.la -lm mkdir .libs /bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -g -o r_w -R/opt/acis16.7/bin/linux_amd_64_so -R/opt/occ6.2/ros/Linux/lib r_w.o ../libcgm.la -lm /bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -g -o makept -R/opt/acis16.7/bin/linux_amd_64_so -R/opt/occ6.2/ros/Linux/lib makept.o ../libcgm.la -lm /bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -g -o modify -R/opt/acis16.7/bin/linux_amd_64_so -R/opt/occ6.2/ros/Linux/lib modify.o ../libcgm.la -lm c++ -Wall -pipe -g -o r_w r_w.o ../.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -L/opt/occ6.2/ros/Linux/lib -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.2/ros/lin/lib/libTKFeat.so /opt/OpenCascade6.2/ros/lin/lib/libTKHLR.so /opt/OpenCascade6.2/ros/lin/lib/libTKIGES.so /opt/OpenCascade6.2/ros/lin/lib/libTKOffset.so /opt/OpenCascade6.2/ros/lin/lib/libTKFillet.so /opt/OpenCascade6.2/ros/lin/lib/libTKBool.so /opt/OpenCascade6.2/ros/lin/lib/libTKBO.so /opt/OpenCascade6.2/ros/lin/lib/libTKPrim.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPAttr.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP209.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTL.so /opt/OpenCascade6.2/ros/lin/lib/libTKMesh.so /opt/OpenCascade6.2/ros/lin/lib/libTKXSBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKShHealing.so /opt/OpenCascade6.2/ros/lin/lib/libTKLCAF.so /opt/OpenCascade! 6.2/ros/lin/lib/libTKCDF.so /opt/OpenCascade6.2/ros/lin/lib/libTKTopAlgo.so /opt/OpenCascade6.2/ros/lin/lib/libTKGeomAlgo.so /opt/OpenCascade6.2/ros/lin/lib/libTKBRep.so /opt/OpenCascade6.2/ros/lin/lib/libTKGeomBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKG3d.so /opt/OpenCascade6.2/ros/lin/lib/libTKG2d.so /opt/OpenCascade6.2/ros/lin/lib/libTKMath.so /opt/OpenCascade6.2/ros/lin/lib/libTKernel.so -ldl -lpthread -lieee -lm -Wl,--rpath -Wl,/opt/OpenCascade6.2/ros/lin/lib -Wl,--rpath -Wl,/opt/OpenCascade6.2/ros/lin/lib -Wl,--rpath -Wl,/opt/acis16.7/bin/linux_amd_64_so -Wl,--rpath -Wl,/opt/occ6.2/ros/Linux/lib c++ -Wall -pipe -g -o sheet sheet.o ../.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -L/opt/occ6.2/ros/Linux/lib -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.2/ros/lin/lib/libTKFeat.so /opt/OpenCascade6.2/ros/lin/lib/libTKHLR.so /opt/OpenCascade6.2/ros/lin/lib/libTKIGES.so /opt/OpenCascade6.2/ros/lin/lib/libTKOffset.so /opt/OpenCascade6.2/ros/lin/lib/libTKFillet.so /opt/OpenCascade6.2/ros/lin/lib/libTKBool.so /opt/OpenCascade6.2/ros/lin/lib/libTKBO.so /opt/OpenCascade6.2/ros/lin/lib/libTKPrim.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPAttr.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP209.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTL.so /opt/OpenCascade6.2/ros/lin/lib/libTKMesh.so /opt/OpenCascade6.2/ros/lin/lib/libTKXSBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKShHealing.so /opt/OpenCascade6.2/ros/lin/lib/libTKLCAF.so /opt/OpenCas! cade6.2/ros/lin/lib/libTKCDF.so /opt/OpenCascade6.2/ros/lin/lib/libTKTopAlgo.so /opt/OpenCascade6.2/ros/lin/lib/libTKGeomAlgo.so /opt/OpenCascade6.2/ros/lin/lib/libTKBRep.so /opt/OpenCascade6.2/ros/lin/lib/libTKGeomBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKG3d.so /opt/OpenCascade6.2/ros/lin/lib/libTKG2d.so /opt/OpenCascade6.2/ros/lin/lib/libTKMath.so /opt/OpenCascade6.2/ros/lin/lib/libTKernel.so -ldl -lpthread -lieee -lm -Wl,--rpath -Wl,/opt/OpenCascade6.2/ros/lin/lib -Wl,--rpath -Wl,/opt/OpenCascade6.2/ros/lin/lib -Wl,--rpath -Wl,/opt/acis16.7/bin/linux_amd_64_so -Wl,--rpath -Wl,/opt/occ6.2/ros/Linux/lib c++ -Wall -pipe -g -o webcut webcut.o ../.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -L/opt/occ6.2/ros/Linux/lib -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.2/ros/lin/lib/libTKFeat.so /opt/OpenCascade6.2/ros/lin/lib/libTKHLR.so /opt/OpenCascade6.2/ros/lin/lib/libTKIGES.so /opt/OpenCascade6.2/ros/lin/lib/libTKOffset.so /opt/OpenCascade6.2/ros/lin/lib/libTKFillet.so /opt/OpenCascade6.2/ros/lin/lib/libTKBool.so /opt/OpenCascade6.2/ros/lin/lib/libTKBO.so /opt/OpenCascade6.2/ros/lin/lib/libTKPrim.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPAttr.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP209.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTL.so /opt/OpenCascade6.2/ros/lin/lib/libTKMesh.so /opt/OpenCascade6.2/ros/lin/lib/libTKXSBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKShHealing.so /opt/OpenCascade6.2/ros/lin/lib/libTKLCAF.so /opt/OpenC! ascade6.2/ros/lin/lib/libTKCDF.so /opt/OpenCascade6.2/ros/lin/lib/libTKTopAlgo.so /opt/OpenCascade6.2/ros/lin/lib/libTKGeomAlgo.so /opt/OpenCascade6.2/ros/lin/lib/libTKBRep.so /opt/OpenCascade6.2/ros/lin/lib/libTKGeomBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKG3d.so /opt/OpenCascade6.2/ros/lin/lib/libTKG2d.so /opt/OpenCascade6.2/ros/lin/lib/libTKMath.so /opt/OpenCascade6.2/ros/lin/lib/libTKernel.so -ldl -lpthread -lieee -lm -Wl,--rpath -Wl,/opt/OpenCascade6.2/ros/lin/lib -Wl,--rpath -Wl,/opt/OpenCascade6.2/ros/lin/lib -Wl,--rpath -Wl,/opt/acis16.7/bin/linux_amd_64_so -Wl,--rpath -Wl,/opt/occ6.2/ros/Linux/lib c++ -Wall -pipe -g -o makept makept.o ../.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -L/opt/occ6.2/ros/Linux/lib -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.2/ros/lin/lib/libTKFeat.so /opt/OpenCascade6.2/ros/lin/lib/libTKHLR.so /opt/OpenCascade6.2/ros/lin/lib/libTKIGES.so /opt/OpenCascade6.2/ros/lin/lib/libTKOffset.so /opt/OpenCascade6.2/ros/lin/lib/libTKFillet.so /opt/OpenCascade6.2/ros/lin/lib/libTKBool.so /opt/OpenCascade6.2/ros/lin/lib/libTKBO.so /opt/OpenCascade6.2/ros/lin/lib/libTKPrim.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPAttr.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP209.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTL.so /opt/OpenCascade6.2/ros/lin/lib/libTKMesh.so /opt/OpenCascade6.2/ros/lin/lib/libTKXSBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKShHealing.so /opt/OpenCascade6.2/ros/lin/lib/libTKLCAF.so /opt/OpenC! ascade6.2/ros/lin/lib/libTKCDF.so /opt/OpenCascade6.2/ros/lin/lib/libTKTopAlgo.so /opt/OpenCascade6.2/ros/lin/lib/libTKGeomAlgo.so /opt/OpenCascade6.2/ros/lin/lib/libTKBRep.so /opt/OpenCascade6.2/ros/lin/lib/libTKGeomBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKG3d.so /opt/OpenCascade6.2/ros/lin/lib/libTKG2d.so /opt/OpenCascade6.2/ros/lin/lib/libTKMath.so /opt/OpenCascade6.2/ros/lin/lib/libTKernel.so -ldl -lpthread -lieee -lm -Wl,--rpath -Wl,/opt/OpenCascade6.2/ros/lin/lib -Wl,--rpath -Wl,/opt/OpenCascade6.2/ros/lin/lib -Wl,--rpath -Wl,/opt/acis16.7/bin/linux_amd_64_so -Wl,--rpath -Wl,/opt/occ6.2/ros/Linux/lib c++ -Wall -pipe -g -o modify modify.o ../.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -L/opt/occ6.2/ros/Linux/lib -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.2/ros/lin/lib/libTKFeat.so /opt/OpenCascade6.2/ros/lin/lib/libTKHLR.so /opt/OpenCascade6.2/ros/lin/lib/libTKIGES.so /opt/OpenCascade6.2/ros/lin/lib/libTKOffset.so /opt/OpenCascade6.2/ros/lin/lib/libTKFillet.so /opt/OpenCascade6.2/ros/lin/lib/libTKBool.so /opt/OpenCascade6.2/ros/lin/lib/libTKBO.so /opt/OpenCascade6.2/ros/lin/lib/libTKPrim.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPAttr.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP209.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTL.so /opt/OpenCascade6.2/ros/lin/lib/libTKMesh.so /opt/OpenCascade6.2/ros/lin/lib/libTKXSBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKShHealing.so /opt/OpenCascade6.2/ros/lin/lib/libTKLCAF.so /opt/OpenC! ascade6.2/ros/lin/lib/libTKCDF.so /opt/OpenCascade6.2/ros/lin/lib/libTKTopAlgo.so /opt/OpenCascade6.2/ros/lin/lib/libTKGeomAlgo.so /opt/OpenCascade6.2/ros/lin/lib/libTKBRep.so /opt/OpenCascade6.2/ros/lin/lib/libTKGeomBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKG3d.so /opt/OpenCascade6.2/ros/lin/lib/libTKG2d.so /opt/OpenCascade6.2/ros/lin/lib/libTKMath.so /opt/OpenCascade6.2/ros/lin/lib/libTKernel.so -ldl -lpthread -lieee -lm -Wl,--rpath -Wl,/opt/OpenCascade6.2/ros/lin/lib -Wl,--rpath -Wl,/opt/OpenCascade6.2/ros/lin/lib -Wl,--rpath -Wl,/opt/acis16.7/bin/linux_amd_64_so -Wl,--rpath -Wl,/opt/occ6.2/ros/Linux/lib make[2]: Leaving directory `/home/jason/cgm/test/64/test' make check-TESTS make[2]: Entering directory `/home/jason/cgm/test/64/test' Success (16AcisModifyEngine) Success (15OCCModifyEngine) PASS: sheet ======================================= Read 1 ACIS Entities from the input file Constructed 1 Volume: 1 ======================================= Creating the new (webcut) volumes... Created volume(s): 2 Updated volume(s): 1 Exported: 2 Volumes ======================================= Read 1 ACIS Entities from the input file Constructed 1 Volume: 3 ======================================= Creating the new (webcut) volumes... Created volume(s): 4 Updated volume(s): 3 Exported: 2 Volumes ======================================= Read 1 ACIS Entities from the input file Constructed 1 Volume: 5 ======================================= Creating the new (webcut) volumes... Created volume(s): 6 Updated volume(s): 5 Exported: 2 Volumes ======================================= Read 3 ACIS Entities from the input file Constructed 1 Volume: 7 Constructed 2 Free Curves: 4457, 4458 ======================================= Creating the new (webcut) volumes... Created volume(s): 8 Updated volume(s): 7 CPU time taken to WEBCUT this body: 5.410000 secs Exported: 2 Volumes 2 Curves ======================================= Read 3 ACIS Entities from the input file Constructed 1 Volume: 9 Constructed 2 Free Curves: 5296, 5297 ======================================= Creating the new (webcut) volumes... Created volume(s): 10 Updated volume(s): 9 Exported: 2 Volumes 2 Curves ======================================= Read 3 ACIS Entities from the input file Constructed 1 Volume: 11 Constructed 2 Free Curves: 5322, 5323 ======================================= Creating the new (webcut) volumes... Created volume(s): 12 Updated volume(s): 11 Exported: 2 Volumes 2 Curves ======================================= Read 5 ACIS Entities from the input file Constructed 1 Volume: 13 Constructed 4 Free Curves: 5348 to 5351 ======================================= Creating the new (webcut) volumes... Created volume(s): 14 Updated volume(s): 13 Exported: 2 Volumes 4 Curves ======================================= Read 2 ACIS Entities from the input file Constructed 2 Volumes: 15, 16 ======================================= Creating the new (webcut) volumes... Created volume(s): 17 Updated volume(s): 15 Exported: 3 Volumes ======================================= Read 2 ACIS Entities from the input file Constructed 2 Volumes: 18, 19 ======================================= Creating the new (webcut) volumes... Created volume(s): 20 Updated volume(s): 18 Exported: 3 Volumes ======================================= Read 2 ACIS Entities from the input file Constructed 2 Volumes: 21, 22 ======================================= Creating the new (webcut) volumes... Created volume(s): 23 Updated volume(s): 21 Exported: 3 Volumes ======================================= Read 2 ACIS Entities from the input file Constructed 2 Volumes: 24, 25 ======================================= Creating the new (webcut) volumes... Created volume(s): 26 Updated volume(s): 24 Exported: 3 Volumes ======================================= Read 2 ACIS Entities from the input file Constructed 2 Volumes: 27, 28 ======================================= Creating the new (webcut) volumes... Created volume(s): 29 Updated volume(s): 27 Exported: 3 Volumes PASS: webcut Created volume(s): 8 Destroyed volume(s): 2 to 7 Exported: 1 OCC Body ======================================= Adding solids. Adding shells. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Constructed 1 Volume: 9 ======================================= WARNING: WARNING: Edge found with zero arclength For cones, this may be normal. FAIL: modify ======================================= Adding solids. Adding shells. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding edges. Adding loops. Adding edges. Adding vertices. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding edges. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding loops. Adding edges. Adding vertices. Adding faces. Adding loops. Adding loops. Adding edges. Adding vertices. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Constructed 1 Volume: 1 ======================================= ======================================= Adding solids. Adding shells. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding loops. Adding edges. Adding vertices. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding edges. Adding vertices. Adding edges. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding loops. Adding edges. Adding vertices. Adding faces. Adding loops. Adding loops. Adding edges. Adding vertices. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Constructed 1 Volume: 2 ======================================= ======================================= Adding solids. Adding shells. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding loops. Adding edges. Adding vertices. Adding loops. Adding edges. Adding vertices. Adding loops. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding loops. Adding edges. Adding vertices. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding solids. Adding shells. Adding faces. Adding loops. Adding edges. Adding vertices. Adding loops. Adding edges. Adding vertices. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding loops. Adding edges. Adding vertices. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding loops. Adding edges. Adding vertices. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding loops. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding loops. Adding edges. Adding vertices. Adding faces. Adding loops. Adding loops. Adding edges. Adding vertices. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding loops. Adding edges. Adding vertices. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding loops. Adding loops. Adding edges. Adding vertices. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding loops. Adding edges. Adding vertices. Adding loops. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding edges. Adding vertices. Adding edges. Adding faces. Adding loops. Adding faces. Adding loops. Constructed 2 Volumes: 3, 4 ======================================= Created volume(s): 5 to 8 Exported: 5 OCC Bodies 3 OCC Points Exported: 2 OCC Bodies 3 OCC Points PASS: makept ======================================= ERROR: Problems reading geometry file ./stitch.occ_name. FAIL: r_w =================== 2 of 5 tests failed =================== make[2]: Leaving directory `/home/jason/cgm/test/64/test' make[1]: Leaving directory `/home/jason/cgm/test/64/test'
participants (1)
Nightly Test
