Author: janehu Date: 2008-05-02 15:12:30 -0500 (Fri, 02 May 2008) New Revision: 1792 Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp cgm/trunk/geom/OCC/OCCQueryEngine.hpp Log: fixed the problem of generating more coedges, causing free entities after deleting body. Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-05-02 14:26:27 UTC (rev 1791) +++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-05-02 20:12:30 UTC (rev 1792) @@ -117,6 +117,7 @@ typedef std::map<int, TopologyBridge*>::value_type valType; int OCCQueryEngine::iTotalTBCreated = 0; +int OCCQueryEngine::total_coedges = 0; CubitBoolean OCCQueryEngine::PRINT_RESULT = CUBIT_FALSE; //================================================================================ // Description: @@ -1304,17 +1305,36 @@ } BRepTools_WireExplorer Ex; - DLIList <OCCCoEdge*> coedges; + DLIList <OCCCoEdge*> coedges_old, coedges_new; for (Ex.Init(aShape); Ex.More(); Ex.Next()) { Curve* curve = populate_topology_bridge(Ex.Current()); OCCCurve *occ_curve = CAST_TO(curve, OCCCurve); - OCCCoEdge * coedge = new OCCCoEdge( curve, loop, + coedges_old = loop->coedges(); + CubitBoolean exist = CUBIT_FALSE; + OCCCoEdge * coedge = NULL; + int size = coedges_old.size(); + for(int i = 0; i < size; i++) + { + coedge = coedges_old.pop(); + if(coedge->curve() == curve) + { + exist = CUBIT_TRUE; + coedge->set_sense(Ex.Orientation() == TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED); + coedges_new.append(coedge); + break; + } + } + if(!exist) + { + coedge = new OCCCoEdge( curve, loop, (Ex.Orientation() == TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED)); - coedges.append(coedge); + coedges_new.append(coedge); + total_coedges++; + } occ_curve->add_loop(loop); } - loop->coedges(coedges); + loop->coedges(coedges_new); return loop; } @@ -1788,15 +1808,15 @@ } CubitStatus status = unhook_LoopSM_from_OCC(loopsm); + + for(int i = 0; i < curves.size(); i ++) + delete_solid_model_entities(curves.get_and_step()); + if (status) { WireList->remove(occ_loop); delete loopsm; } - - for(int i = 0; i < curves.size(); i ++) - delete_solid_model_entities(curves.get_and_step()); - return status; } @@ -2486,16 +2506,7 @@ OccToCGM->erase(k); GeometryEntity* ge = CAST_TO(tb, GeometryEntity); if(ge) - { - OCCSurface* surface = CAST_TO(ge, OCCSurface); - OCCCurve* curve = CAST_TO(ge, OCCCurve); - if (surface) - unhook_cofaces_of_a_surface(surface); - else if (curve) - unhook_coedges_of_a_curve(curve); - delete_solid_model_entities( ge, CUBIT_FALSE ); - } } else @@ -2511,10 +2522,11 @@ DLIList<OCCShell*> shells; shells = surface->shells(); DLIList<OCCCoFace*> cofaces; - for (int i = 0; i < shells.size(); i ++) + while ( shells.size() > 0) { DLIList<OCCCoFace*> children ; - children = shells.get_and_step()->cofaces(); + OCCShell* shell = shells.pop(); + children = shell->cofaces(); for(int j = 0; j < children.size(); j++) { OCCCoFace* coface = children.get_and_step(); @@ -2525,7 +2537,6 @@ } } } - assert (cofaces.size() == shells.size()); unhook_CoFaces_from_OCC(cofaces); } void OCCQueryEngine::unhook_coedges_of_a_curve(OCCCurve* curve)const @@ -2541,10 +2552,7 @@ { OCCCoEdge* coedge = children.get_and_step(); if (coedge->curve() == curve) - { coedges.append(coedge); - break; - } } } unhook_CoEdges_from_OCC(coedges); Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp =================================================================== --- cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2008-05-02 14:26:27 UTC (rev 1791) +++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2008-05-02 20:12:30 UTC (rev 1792) @@ -363,7 +363,7 @@ TopTools_DataMapOfShapeInteger* OCCMap; std::map<int, TopologyBridge*>* OccToCGM; static int iTotalTBCreated ; - + static int total_coedges; protected: OCCQueryEngine();
participants (1)
janehu@mcs.anl.gov
