r5481 - in cgm/branches/merge-cubit13.1: . itaps
Author: janehu Date: 2012-04-13 12:55:55 -0500 (Fri, 13 Apr 2012) New Revision: 5481 Modified: cgm/branches/merge-cubit13.1/configure.ac cgm/branches/merge-cubit13.1/itaps/CATag.cpp cgm/branches/merge-cubit13.1/itaps/CATag.hpp cgm/branches/merge-cubit13.1/itaps/Makefile.am cgm/branches/merge-cubit13.1/itaps/iBase.h cgm/branches/merge-cubit13.1/itaps/iGeom-Defs.inc.in cgm/branches/merge-cubit13.1/itaps/iGeom.h cgm/branches/merge-cubit13.1/itaps/iGeomError.cc cgm/branches/merge-cubit13.1/itaps/iGeomError.h cgm/branches/merge-cubit13.1/itaps/iGeom_CGMA.cc cgm/branches/merge-cubit13.1/itaps/iGeom_protos.h cgm/branches/merge-cubit13.1/itaps/testgeom.cc Log: Updates from trunk cgm for itaps. Modified: cgm/branches/merge-cubit13.1/configure.ac =================================================================== --- cgm/branches/merge-cubit13.1/configure.ac 2012-04-12 21:17:13 UTC (rev 5480) +++ cgm/branches/merge-cubit13.1/configure.ac 2012-04-13 17:55:55 UTC (rev 5481) @@ -10,8 +10,12 @@ [AM_INIT_AUTOMAKE([foreign -Wall])]) AC_DISABLE_SHARED +AC_ARG_ENABLE([fortran],[AC_HELP_STRING([--disable-fortran], + [No Fortran name mangling in ITAPS C headers])], + [ENABLE_FORTRAN=$enableval],[ENABLE_FORTRAN=yes]) + EXTRA_GNU_FLAGS="-Wall -pipe -pedantic" -FATHOM_CHECK_COMPILERS +FATHOM_CHECK_COMPILERS([yes],[yes],[$ENABLE_FORTRAN]) AC_PROG_LIBTOOL LIBS="-lm" AC_PROG_SED @@ -21,7 +25,7 @@ ################################################################################ # Fortran Stuff for ITAPS C bindings ################################################################################ -if test "x" != "x$FC"; then +if test "xyes" = "x$ENABLE_FORTRAN" && test "x" != "x$FC"; then AC_FC_WRAPPERS fi @@ -308,11 +312,11 @@ # Newer C++ compilers may not provide this backwards-compatibility # file. Check if it is present, and if not, use our own. ACIS_NEW_COMPAT_INC='-I${top_srcdir}/compat/new' -#if test "x$ACIS_DIR" != "xno"; then +if test "x$ACIS_DIR" != "xno"; then AC_LANG_PUSH(C++) -# AC_CHECK_HEADER([new.h],[],[ACIS_INCLUDES="$ACIS_INCLUDES $ACIS_NEW_COMPAT_INC"]) + AC_CHECK_HEADER([new.h],[],[ACIS_INCLUDES="$ACIS_INCLUDES $ACIS_NEW_COMPAT_INC"]) AC_LANG_POP(C++) -#fi +fi AC_SUBST(ACIS_DEFS) AC_SUBST(ACIS_DIR) @@ -387,6 +391,13 @@ AC_SUBST(USE_BABEL) AM_CONDITIONAL(USE_BABEL, [test "xno" != "x$USE_BABEL"]) +################################################################################ +# ITAPS shim +################################################################################ +AC_ARG_ENABLE([shim],[AC_HELP_STRING([--enable-shim], + [Enable ITAPS shim])],
participants (1)
jiangtao_ma@yahoo.com
