Author: janehu Date: 2012-02-03 11:30:54 -0600 (Fri, 03 Feb 2012) New Revision: 5377 Added: cgm/trunk/test/loft.cpp Modified: cgm/trunk/test/Makefile.am Log: Testcase for bug #257 fix. code check in is at r5376. Modified: cgm/trunk/test/Makefile.am =================================================================== --- cgm/trunk/test/Makefile.am 2012-02-03 17:22:24 UTC (rev 5376) +++ cgm/trunk/test/Makefile.am 2012-02-03 17:30:54 UTC (rev 5377) @@ -22,7 +22,7 @@ endif endif if build_OCC - TESTS += attribute_to_file attribute_to_buffer modify subtract makept offset_curves r_w test_occ operation brick_occ merge_occ point_project imprint_bug + TESTS += attribute_to_file attribute_to_buffer modify subtract makept loft offset_curves r_w test_occ operation brick_occ merge_occ point_project imprint_bug endif check_PROGRAMS = $(TESTS) @@ -37,6 +37,7 @@ makept_SOURCES = makept.cpp offset_curves_SOURCES = offset_curves.cpp +loft_SOURCES = loft.cpp modify_SOURCES = modify.cpp imprint_bug_SOURCES = imprint_bug.cpp subtract_SOURCES = subtract.cpp @@ -139,6 +140,7 @@ imprint.brep \ BsplineCurve.occ \ curves.brep \ + loft.brep \ bug.brep \ subtract.occ \ glue.occ \ Added: cgm/trunk/test/loft.cpp =================================================================== --- cgm/trunk/test/loft.cpp (rev 0) +++ cgm/trunk/test/loft.cpp 2012-02-03 17:30:54 UTC (rev 5377) @@ -0,0 +1,137 @@ +/** + * \file makept.cpp + * + * \brief makept, another simple C++ driver for CGM + * + * This program acts as a simple driver for CGM. It reads in a geometry, + * and performs varies checks for bodies, surfaces, curves and vertices. + */ + +#undef NDEBUG +#include <cassert> + +#include "GeometryModifyEngine.hpp" +#include "GeometryModifyTool.hpp" +#include "GeometryQueryTool.hpp" +#include "CubitMessage.hpp"
participants (1)
jiangtao_ma@yahoo.com
