Hi Iulian cgmurl I can see, I doubt I have ever used it, why is there more than one for cubit12.2? Also I was using 13.1 from branches (no cgm_version.h) , not 13.1.1 from tags (which has cgm_version.h) Out of curiosity, should there not be a 13.1.1 on branches? Perhaps now that 13.1 is out of date you could replace it with 13.1.1? Same for 12.2-merge? Andy On 01/29/2014 09:19 AM, Grindeanu, Iulian R. wrote:
buildbot uses these: cgmurl = 'https://svn.mcs.anl.gov/repos/ITAPS/cgm/branches/merge-cubit12.2' for cubit 12.2
cgmurlt1311 = 'https://svn.mcs.anl.gov/repos/ITAPS/cgm/tags/13.1.1' for cubit 13.1
cgmurltrunk = 'https://svn.mcs.anl.gov/repos/ITAPS/cgm/trunk' for Cubit14.0
What versions are you using? What is not compiling for you?
Iulian ________________________________________ From: Paul Wilson [[email protected]] Sent: Wednesday, January 29, 2014 9:15 AM To: Andrew Davis; Grindeanu, Iulian R.; [email protected] Subject: Re: [cgma-dev] Cubit 14
Hi Andy,
Can you remind me of the specific symptom? Is it the existence of the version file that needs to be backported (perhaps not), or is it the use of the version info to change the behavior that needs to be backported (perhaps)?
Paul
On 01/29/2014 09:10 AM, Andrew Davis wrote:
Hi Julian
The SVN
Andy
On 01/29/2014 09:07 AM, Grindeanu, Iulian R. wrote:
I think that current branches (mergecubit12.2, trunk, ) all have that file; at least buildbot is not complaining. Are you using a release tar file or svn repo? ________________________________________ From: [email protected] [[email protected]] on behalf of Andrew Davis [[email protected]] Sent: Wednesday, January 29, 2014 9:05 AM To: [email protected] Subject: [cgma-dev] Cubit 14
This is question kind of linked to both CGM and MOAB
Jane fixed readCGM.cpp in MOAB, however this fix only works for CGM, since it relies on cgm_version.h, which was included in CGM14.0, however, when we compile with any version previous we do not have this header file availble to us. Would it be possible to back port the cgm_version.h file back into previous CGM releases?
Thanks
Andy -- -- ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ -- Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu Faculty Director, Advanced Computing Infrastructure
participants (1)
Andrew Davis
