I think it should stay a separate function, even though it's quite similar. After you apply for an ANL acct, this can serve as verification that you can commit stuff. - tim Steve Jackson wrote:
I want to be able to define cones through the iGeom interface. (Tim and I have discussed this already, and agreed that such an extension to iGeom would be straightforward.) Attached to this email is a patch that implements an iGeom_createCone function, with an interface derived from createCylinder.
Indeed, the new function is almost identical to createCylinder. If we want to avoid adding more functions to iGeom, it would be possible to simply extend the createCylinder function to accept one more argument, thus giving it the capacity to define cones as well as cylinders. But perhaps it is better to leave the existing cylinder interface as it is, and add a new cone function like the one I've attached.
If the attached patch meets the approval of the lead developers, I'd ask one of them to apply it to the repository. Thanks. (By the way, it seems like the svn repository may have gone down this afternoon; I'm currently unable to contact it.) ~S
-- ================================================================ "You will keep in perfect peace him whose mind is steadfast, because he trusts in you." Isaiah 26:3 Tim Tautges Argonne National Laboratory ([email protected]) (telecommuting from UW-Madison) phone: (608) 263-8485 1500 Engineering Dr. fax: (608) 263-4499 Madison, WI 53706
participants (1)
Tim Tautges
