Author: janehu Date: 2008-04-08 14:11:39 -0500 (Tue, 08 Apr 2008) New Revision: 1751 Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp cgm/trunk/geom/OCC/OCCModifyEngine.hpp Log: Added a check to make sure the imprinting edges make an actual cut on the face before pass it in the splitor. Otherwise it will crash. Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-04-08 16:07:50 UTC (rev 1750) +++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-04-08 19:11:39 UTC (rev 1751) @@ -39,12 +39,15 @@ #include "Geom_BezierCurve.hxx" #include "BndLib_AddSurface.hxx" #include "Handle_Geom_Plane.hxx" +#include "BRepExtrema_DistShapeShape.hxx" +#include "Extrema_ExtPC.hxx" #include "BRepPrimAPI_MakePrism.hxx" #include "BRepPrimAPI_MakeCone.hxx" #include "BRepOffsetAPI_ThruSections.hxx" #include "BRepPrimAPI_MakeTorus.hxx" #include "BRepPrimAPI_MakeCylinder.hxx" #include "BRepBuilderAPI_Transform.hxx" +#include "BRepAdaptor_Curve.hxx" #include "GC_MakeEllipse.hxx" #include "BRepBuilderAPI_MakeEdge.hxx" #include "BRepAdaptor_Surface.hxx" @@ -1992,18 +1995,32 @@ DLIList<DLIList<TopoDS_Edge*>*> edge_lists; if (total_edges >= 1) { - sort_curves(curve_list, edge_lists); + CubitStatus stat = sort_curves(curve_list, edge_lists); DLIList<TopoDS_Edge*>* edge_list; edge_list = edge_lists.pop(); - BRepBuilderAPI_MakeWire myWire; - - for(int i = 0; i < edge_list->size(); i++) - { - TopoDS_Edge e = *(edge_list->get_and_step()); - myWire.Add(e); - } - splitor.Add(myWire.Wire(),from_face); - topo_changed = CUBIT_TRUE; + + //check if the edges make a split of the surface, error out if it's + //just a scar on the surface + int count_intersection = 0; + if (stat == CUBIT_FAILURE) //Open wire + { + count_intersection = check_intersection(edge_list, from_face); + + if (count_intersection < 2) + PRINT_WARNING("Cant make a scar on existing face without splitting it. \n"); + } + if (stat || count_intersection == 2) + { + BRepBuilderAPI_MakeWire myWire; + edge_list->reset(); + for(int i = 0; i < edge_list->size(); i++) + { + TopoDS_Edge e = *(edge_list->get_and_step()); + myWire.Add(e); + } + splitor.Add(myWire.Wire(),from_face); + topo_changed = CUBIT_TRUE; + } } if(topo_changed) { @@ -2052,6 +2069,78 @@ return CUBIT_SUCCESS; return CUBIT_FAILURE; } + +int OCCModifyEngine::check_intersection(DLIList<TopoDS_Edge*>* edge_list, + TopoDS_Face from_face)const +{ + int count_intersection = 0; + for(int j = 0; j < edge_list->size(); j++) + { + TopoDS_Edge* edge = edge_list->get_and_step(); + BRepAdaptor_Curve acurve(*edge); + double lower_bound = acurve.FirstParameter(); + double upper_bound = acurve.LastParameter(); + TopExp_Explorer Ex; + gp_Pnt newP(0.0, 0.0, 0.0); + double tol = OCCQueryEngine::instance()->get_sme_resabs_tolerance(); + for (Ex.Init(from_face, TopAbs_EDGE); Ex.More(); Ex.Next()) + { + TopoDS_Edge from_edge = TopoDS::Edge(Ex.Current()); + BRepAdaptor_Curve acurve2(from_edge); + double lower_bound2 = acurve2.FirstParameter(); + double upper_bound2 = acurve2.LastParameter(); + BRepExtrema_DistShapeShape distShapeShape(*edge, from_edge); + CubitBoolean qualified = CUBIT_FALSE; + if (distShapeShape.IsDone() && distShapeShape.Value() < tol) + { + newP = distShapeShape.PointOnShape1(1); + Extrema_ExtPC ext(newP, acurve, Precision::Approximation()); + double newVal; + if (ext.IsDone() && (ext.NbExt() > 0)) { + for ( int i = 1 ; i <= ext.NbExt() ; i++ ) { + if ( ext.IsMin(i) ) { + newVal = ext.Point(i).Parameter(); + if ((newVal-lower_bound) >= -tol && + (upper_bound - newVal) >= -tol) + { + qualified = CUBIT_TRUE; + break; + } + } + } + } + if (qualified) + { + qualified = CUBIT_FALSE; + Extrema_ExtPC ext(newP, acurve2, Precision::Approximation()); + double newVal; + if (ext.IsDone() && (ext.NbExt() > 0)) { + for ( int i = 1 ; i <= ext.NbExt() ; i++ ) { + if ( ext.IsMin(i) ) { + newVal = ext.Point(i).Parameter(); + if ((newVal-lower_bound2) >= -tol && + (upper_bound2 - newVal) >= -tol) + { + qualified = CUBIT_TRUE; + break; + } + } + } + } + } + + if(qualified) + { + count_intersection++; + break; + } + } + if (count_intersection == 2) + break; + } //for loop + } + return count_intersection; +} //=============================================================================== // Function : imprint // Member Type: PUBLIC Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp =================================================================== --- cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-04-08 16:07:50 UTC (rev 1750) +++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-04-08 19:11:39 UTC (rev 1751) @@ -665,6 +665,9 @@ CubitStatus sort_curves(DLIList<Curve*> curve_list, DLIList<DLIList<TopoDS_Edge*>*>& topo_edges_loops)const; private: + int check_intersection(DLIList<TopoDS_Edge*>* edge_list, + TopoDS_Face from_face)const; + } ;
participants (1)
janehu@mcs.anl.gov
