Author: janehu Date: 2007-11-28 08:45:44 -0600 (Wed, 28 Nov 2007) New Revision: 1427 Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp Log: Check to make sure when we export, we export in the original format of the Topo entities, which is if we just read in a Solid, we won't try to export a CompSolid which contains this Solid. Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-11-27 21:09:59 UTC (rev 1426) +++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-11-28 14:45:44 UTC (rev 1427) @@ -918,8 +918,24 @@ //Add every shape to the compound for (i = 0; i < OCC_bodies.size(); i++) { - TopoDS_Shape *shape = OCC_bodies.get_and_step()->get_TopoDS_Shape(); - B.Add(Co, *shape); + OCCBody* body = OCC_bodies.get_and_step(); + TopoDS_CompSolid *shape = body->get_TopoDS_Shape(); + + //check if this body is build backwards from lump. if so, + //the body and its CompSolid doesn't have bounded relationship + //established. In this case, each individual lump of the body + // will be exported as TopoDS_Solid without a CompSolid + if(OCCMap->IsBound(*shape)) + B.Add(Co, *shape); + else + { + DLIList<Lump*> lumps = body->lumps(); + for(int i = 0; i < lumps.size(); i++) + { + OCCLump *occ_lump = (OCCLump *) lumps.get_and_step(); + B.Add(Co, *(occ_lump->get_TopoDS_Solid())); + } + } } for (i = 0; i < OCC_surfaces.size(); i++) @@ -992,7 +1008,7 @@ // suitable to popolate for a TopoDS_CompSolid or TopoDS_Compound shape. TopExp_Explorer Ex; for (Ex.Init(aShape, TopAbs_COMPSOLID); Ex.More(); Ex.Next()) - tblist.append(populate_topology_bridge(TopoDS::Solid(Ex.Current()))); + tblist.append(populate_topology_bridge(TopoDS::CompSolid(Ex.Current()))); for (Ex.Init(aShape, TopAbs_SOLID, TopAbs_COMPSOLID); Ex.More(); Ex.Next()) tblist.append(populate_topology_bridge(TopoDS::Solid(Ex.Current()), CUBIT_TRUE));
participants (1)
janehu@mcs.anl.gov
