Author: janehu Date: 2014-03-12 10:31:38 -0500 (Wed, 12 Mar 2014) New Revision: 6145 Added: cgm/branches/cgm12.2/README.DOWNLOAD Removed: cgm/branches/cgm12.2/CMakeLists.txt cgm/branches/cgm12.2/KNOWN_ISSUES cgm/branches/cgm12.2/LICENSE.CGM cgm/branches/cgm12.2/Makefile.am cgm/branches/cgm12.2/README.CGM cgm/branches/cgm12.2/README.CONFIGURE cgm/branches/cgm12.2/README.OCC cgm/branches/cgm12.2/README.OpenCascade cgm/branches/cgm12.2/cgm.make.in cgm/branches/cgm12.2/cgm_apps/ cgm/branches/cgm12.2/cgm_version.h cgm/branches/cgm12.2/compat/ cgm/branches/cgm12.2/configure.ac cgm/branches/cgm12.2/geom/ cgm/branches/cgm12.2/init/ cgm/branches/cgm12.2/itaps/ cgm/branches/cgm12.2/m4/ cgm/branches/cgm12.2/test/ cgm/branches/cgm12.2/util/ Log: Removed all source files. Added info to direct interested user to use bitbucket. Deleted: cgm/branches/cgm12.2/CMakeLists.txt =================================================================== --- cgm/branches/cgm12.2/CMakeLists.txt 2014-03-12 15:28:40 UTC (rev 6144) +++ cgm/branches/cgm12.2/CMakeLists.txt 2014-03-12 15:31:38 UTC (rev 6145) @@ -1,5 +0,0 @@ - -# do util and geom and test subdirs -SUBDIRS( util geom test init ) - - Deleted: cgm/branches/cgm12.2/KNOWN_ISSUES =================================================================== --- cgm/branches/cgm12.2/KNOWN_ISSUES 2014-03-12 15:28:40 UTC (rev 6144) +++ cgm/branches/cgm12.2/KNOWN_ISSUES 2014-03-12 15:31:38 UTC (rev 6145) @@ -1,27 +0,0 @@ -This is a list of the known issues with CGM on OCC.For more details please see -the online ticket system at the MOAB website: - https://trac.mcs.anl.gov/projects/ITAPS/wiki - - - -ID Severity Summary/Details -=== ======== =================================================================== -175 critical imprint special cases fail with crash. - -176 minor CGM memory leak - -178 major Unite function doesn't unite smoothly connected surfaces. - -179 major mcnp2cad test suite lat1-7 not working, needs debugging. - -180 major There are lots new functions or added functions to exsisting - functions requirements to port OCC to cubit12. - -181 minor Lack of good cases for testing purpose. - -182 minor Dirty geometry/imported geometry is not tested for read/repair yet -183 minor Don't have proper tool to visualize the TopoDS_Shapes, debugging - process is long preparing for graphics to understand the issue - -185 major mcnp2cad/tests/INP-torus test case fails on imprinting 2 spline - surfaces. Deleted: cgm/branches/cgm12.2/LICENSE.CGM =================================================================== --- cgm/branches/cgm12.2/LICENSE.CGM 2014-03-12 15:28:40 UTC (rev 6144) +++ cgm/branches/cgm12.2/LICENSE.CGM 2014-03-12 15:31:38 UTC (rev 6145) @@ -1,21 +0,0 @@ -CGM, the Common Geometry Module, is a code library which provides -geometry functionality used for mesh generation and other applications.
participants (1)
janehu@mcs.anl.gov
