Author: hongjun Date: 2009-08-20 12:30:11 -0500 (Thu, 20 Aug 2009) New Revision: 3109 Modified: cgm/trunk/itaps/testgeom.cc Log: o OCC test geometry file is changed from "Hip_Prothesis.brep" to "LeverArm.brep". Modified: cgm/trunk/itaps/testgeom.cc =================================================================== --- cgm/trunk/itaps/testgeom.cc 2009-08-19 20:05:46 UTC (rev 3108) +++ cgm/trunk/itaps/testgeom.cc 2009-08-20 17:30:11 UTC (rev 3109) @@ -134,13 +134,13 @@ #ifndef HAVE_OCC #error "Cannot force use of OCC w/out OCC support" #endif - std::string filename = STRINGIFY(SRCDIR) "/../test/Hip_Prothesis.brep"; + std::string filename = STRINGIFY(SRCDIR) "/../test/LeverArm.brep"; std::string engine_opt = ";engine=OCC"; #elif defined(HAVE_ACIS) std::string filename = STRINGIFY(SRCDIR) "/testgeom.sat"; std::string engine_opt = ";engine=ACIS"; #elif defined(USE_OCC) - std::string filename = STRINGIFY(SRCDIR) "/../test/Hip_Prothesis.brep"; + std::string filename = STRINGIFY(SRCDIR) "/../test/LeverArm.brep"; std::string engine_opt = ";engine=OCC"; #else std::string filename = STRINGIFY(SRCDIR) "/testgeom.sat";
participants (1)
hongjun@mcs.anl.gov
