Re: [cgma-dev] r4775 - in cgm/trunk: . cgm_apps/ccapi/geom cgm_apps/cgm_cubit_acis cgm_apps/examples/driverc++ cgm_apps/examples/gomadrive geom geom/ACIS_SRC geom/ACIS_SRC/gtcAttrib geom/ACIS_SRC/gtcAttrib/incl geom/Cholla geom/OCC geom/SolidWorks geom/facet geom/facetbool geom/parallel geom/testing geom/testing/data geom/virtual init itaps test util util/OtherFiles
I think support for 10.2 is gone-- I tried a 10.2-based compile, but it fails in make check. ~S On Apr 26, 2011, at 14:39 , Tim Tautges wrote:
No, 10.2 should still be supported (Jane, can you check that too?)
- tim
On 04/26/2011 02:30 PM, Rajeev Jain wrote:
Would this change mean that Cubit-10.2 is no longer supported? Rajeev
------------------------------------------------------------------------ *From:* "[email protected]" <[email protected]> *To:* [email protected] *Sent:* Tuesday, April 26, 2011 12:54 PM *Subject:* [cgma-dev] r4775 - in cgm/trunk: . cgm_apps/ccapi/geom cgm_apps/cgm_cubit_acis cgm_apps/examples/driverc++ cgm_apps/examples/gomadrive geom geom/ACIS_SRC geom/ACIS_SRC/gtcAttrib geom/ACIS_SRC/gtcAttrib/incl geom/Cholla geom/OCC geom/SolidWorks geom/facet geom/facetbool geom/parallel geom/testing geom/testing/data geom/virtual init itaps test util util/OtherFiles
Author: janehu Date: 2011-04-26 12:54:11 -0500 (Tue, 26 Apr 2011) New Revision: 4775
Added: cgm/trunk/KNOWN_ISSUES cgm/trunk/geom/ACIS_SRC/AcisHistory.cpp cgm/trunk/geom/ACIS_SRC/AcisHistory.hpp cgm/trunk/geom/ACIS_SRC/AcisTopologyTool.cpp cgm/trunk/geom/ACIS_SRC/AcisTopologyTool.hpp cgm/trunk/geom/ACIS_SRC/attrib_history.cpp cgm/trunk/geom/ACIS_SRC/attrib_history.hpp cgm/trunk/geom/AutoMidsurfaceTool.cpp cgm/trunk/geom/AutoMidsurfaceTool.hpp cgm/trunk/geom/CGMHistory.cpp cgm/trunk/geom/CGMHistory.hpp cgm/trunk/geom/Cholla/ChollaVolume.cpp cgm/trunk/geom/Cholla/ChollaVolume.hpp cgm/trunk/geom/Cholla/FacetorUtil.cpp cgm/trunk/geom/Cholla/FacetorUtil.hpp cgm/trunk/geom/CubitCompat.cpp cgm/trunk/geom/CubitCompat.h.in cgm/trunk/geom/CubitCompat.hpp cgm/trunk/geom/OCC/OCCHistory.cpp cgm/trunk/geom/OCC/OCCHistory.hpp cgm/trunk/geom/OCC/occ_attrib_history.hpp cgm/trunk/geom/OCC/occ_patches_6.5 cgm/trunk/geom/PeriodicParamTool.cpp cgm/trunk/geom/PeriodicParamTool.hpp cgm/trunk/geom/testing/ cgm/trunk/geom/testing/AngleCalc.cpp cgm/trunk/geom/testing/CMakeLists.txt cgm/trunk/geom/testing/CreateGeometry.cpp cgm/trunk/geom/testing/GraphicsData.cpp cgm/trunk/geom/testing/Makefile.am cgm/trunk/geom/testing/ReadIgesFile.cpp cgm/trunk/geom/testing/TestConfig.h.in cgm/trunk/geom/testing/TestUtilities.cpp cgm/trunk/geom/testing/TestUtilities.hpp cgm/trunk/geom/testing/cgm_test.cpp cgm/trunk/geom/testing/cgm_test.hpp cgm/trunk/geom/testing/cgm_test_script cgm/trunk/geom/testing/data/ cgm/trunk/geom/testing/data/brick.iges cgm/trunk/geom/testing/main.cpp cgm/trunk/geom/virtual/SplitCompositeSurfaceTool.cpp cgm/trunk/geom/virtual/SplitCompositeSurfaceTool.hpp cgm/trunk/test/Cylinder_1.brep cgm/trunk/test/Cylinder_2.brep cgm/trunk/util/CommandFeedback.hpp cgm/trunk/util/CubitUndo.cpp cgm/trunk/util/CubitUndo.hpp cgm/trunk/util/ExternalCoordinateSystem.hpp cgm/trunk/util/GlobalCommandFeedback.cpp cgm/trunk/util/GlobalCommandFeedback.hpp cgm/trunk/util/ManagedPtrVector.hpp cgm/trunk/util/OrderedMap.hpp cgm/trunk/util/OrderedSet.hpp Removed: cgm/trunk/KNOWN_ISSUES cgm/trunk/geom/testing/AngleCalc.cpp cgm/trunk/geom/testing/CMakeLists.txt cgm/trunk/geom/testing/CreateGeometry.cpp cgm/trunk/geom/testing/GraphicsData.cpp cgm/trunk/geom/testing/Makefile.am cgm/trunk/geom/testing/ReadIgesFile.cpp cgm/trunk/geom/testing/TestConfig.h.in cgm/trunk/geom/testing/TestUtilities.cpp cgm/trunk/geom/testing/TestUtilities.hpp cgm/trunk/geom/testing/cgm_test.cpp cgm/trunk/geom/testing/cgm_test.hpp cgm/trunk/geom/testing/cgm_test_script cgm/trunk/geom/testing/data/ cgm/trunk/geom/testing/data/brick.iges cgm/trunk/geom/testing/main.cpp Modified: cgm/trunk/ cgm/trunk/Makefile.am cgm/trunk/cgm_apps/ccapi/geom/GeometryTool_ccapi.cpp cgm/trunk/cgm_apps/cgm_cubit_acis/main_cubit_acis.cpp cgm/trunk/cgm_apps/examples/driverc++/mergechk.cpp cgm/trunk/cgm_apps/examples/gomadrive/gm_cgm_c_interface.C cgm/trunk/configure.ac cgm/trunk/geom/ cgm/trunk/geom/ACIS_SRC/ cgm/trunk/geom/ACIS_SRC/AcisBridge.cpp cgm/trunk/geom/ACIS_SRC/AcisDrawTool.cpp cgm/trunk/geom/ACIS_SRC/AcisEdgeTool.cpp cgm/trunk/geom/ACIS_SRC/AcisFacetManager.cpp cgm/trunk/geom/ACIS_SRC/AcisFacetManager.hpp cgm/trunk/geom/ACIS_SRC/AcisFeatureEngine.cpp cgm/trunk/geom/ACIS_SRC/AcisFeatureEngine.hpp cgm/trunk/geom/ACIS_SRC/AcisHealerTool.cpp cgm/trunk/geom/ACIS_SRC/AcisHealerTool.hpp cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.cpp cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.hpp cgm/trunk/geom/ACIS_SRC/AcisSurfaceTool.cpp cgm/trunk/geom/ACIS_SRC/AcisSurfaceTool.hpp cgm/trunk/geom/ACIS_SRC/AcisToolUtil.cpp cgm/trunk/geom/ACIS_SRC/AcisToolUtil.hpp cgm/trunk/geom/ACIS_SRC/AcisTweakTool.cpp cgm/trunk/geom/ACIS_SRC/AcisTweakTool.hpp cgm/trunk/geom/ACIS_SRC/BodyACIS.cpp cgm/trunk/geom/ACIS_SRC/BodyACIS.hpp cgm/trunk/geom/ACIS_SRC/CMakeLists.txt cgm/trunk/geom/ACIS_SRC/CoEdgeACIS.cpp cgm/trunk/geom/ACIS_SRC/CurveACIS.cpp cgm/trunk/geom/ACIS_SRC/CurveACIS.hpp cgm/trunk/geom/ACIS_SRC/LoopACIS.cpp cgm/trunk/geom/ACIS_SRC/LoopACIS.hpp cgm/trunk/geom/ACIS_SRC/LumpACIS.cpp cgm/trunk/geom/ACIS_SRC/LumpACIS.hpp cgm/trunk/geom/ACIS_SRC/Makefile.am cgm/trunk/geom/ACIS_SRC/PointACIS.cpp cgm/trunk/geom/ACIS_SRC/ShellACIS.cpp cgm/trunk/geom/ACIS_SRC/SurfaceACIS.cpp cgm/trunk/geom/ACIS_SRC/SurfaceACIS.hpp cgm/trunk/geom/ACIS_SRC/UseACIS.cmake cgm/trunk/geom/ACIS_SRC/attrib_cubit_owner.cpp cgm/trunk/geom/ACIS_SRC/attrib_cubit_owner.hpp cgm/trunk/geom/ACIS_SRC/attrib_snl.cpp cgm/trunk/geom/ACIS_SRC/attrib_snl.hpp cgm/trunk/geom/ACIS_SRC/attrib_snl_simple.cpp cgm/trunk/geom/ACIS_SRC/attrib_snl_simple.hpp cgm/trunk/geom/ACIS_SRC/decl_none.h cgm/trunk/geom/ACIS_SRC/gtcAttrib/CMakeLists.txt cgm/trunk/geom/ACIS_SRC/gtcAttrib/Makefile cgm/trunk/geom/ACIS_SRC/gtcAttrib/incl/attrib_gtc_export.h cgm/trunk/geom/AllocMemManagersGeom.cpp cgm/trunk/geom/AnalyticGeometryTool.cpp cgm/trunk/geom/AnalyticGeometryTool.hpp cgm/trunk/geom/BasicTopologyEntity.cpp cgm/trunk/geom/BasicTopologyEntity.hpp cgm/trunk/geom/Body.cpp cgm/trunk/geom/Body.hpp cgm/trunk/geom/BodySM.cpp cgm/trunk/geom/BodySM.hpp cgm/trunk/geom/BoundingBoxTool.cpp cgm/trunk/geom/BoundingBoxTool.hpp cgm/trunk/geom/BridgeManager.cpp cgm/trunk/geom/BridgeManager.hpp cgm/trunk/geom/CAActuateSet.cpp cgm/trunk/geom/CAActuateSet.hpp cgm/trunk/geom/CADeferredAttrib.cpp cgm/trunk/geom/CADeferredAttrib.hpp cgm/trunk/geom/CADefines.hpp cgm/trunk/geom/CAEntityColor.cpp cgm/trunk/geom/CAEntityColor.hpp cgm/trunk/geom/CAEntityId.cpp cgm/trunk/geom/CAEntityId.hpp cgm/trunk/geom/CAEntityName.cpp cgm/trunk/geom/CAEntityName.hpp cgm/trunk/geom/CAGroup.cpp cgm/trunk/geom/CAGroup.hpp cgm/trunk/geom/CAMergePartner.cpp cgm/trunk/geom/CAMergePartner.hpp cgm/trunk/geom/CAMergeStatus.cpp cgm/trunk/geom/CAMergeStatus.hpp cgm/trunk/geom/CASourceFeature.cpp cgm/trunk/geom/CASourceFeature.hpp cgm/trunk/geom/CAUniqueId.cpp cgm/trunk/geom/CAUniqueId.hpp cgm/trunk/geom/CGMApp.cpp cgm/trunk/geom/CGMApp.hpp cgm/trunk/geom/CGMEngineDynamicLoader.cpp cgm/trunk/geom/CGMEngineDynamicLoader.hpp cgm/trunk/geom/CMakeLists.txt cgm/trunk/geom/Chain.cpp cgm/trunk/geom/Chain.hpp cgm/trunk/geom/Cholla/ cgm/trunk/geom/Cholla/CMakeLists.txt cgm/trunk/geom/Cholla/Cholla.cpp cgm/trunk/geom/Cholla/ChollaCurve.cpp cgm/trunk/geom/Cholla/ChollaCurve.hpp cgm/trunk/geom/Cholla/ChollaEngine.cpp cgm/trunk/geom/Cholla/ChollaEngine.hpp cgm/trunk/geom/Cholla/ChollaPoint.cpp cgm/trunk/geom/Cholla/ChollaPoint.hpp cgm/trunk/geom/Cholla/ChollaSurface.cpp cgm/trunk/geom/Cholla/ChollaSurface.hpp cgm/trunk/geom/Cholla/CubitFacet.cpp cgm/trunk/geom/Cholla/CubitFacet.hpp cgm/trunk/geom/Cholla/CubitFacetData.cpp cgm/trunk/geom/Cholla/CubitFacetData.hpp cgm/trunk/geom/Cholla/CubitFacetEdge.hpp cgm/trunk/geom/Cholla/CurveFacetEvalTool.cpp cgm/trunk/geom/Cholla/CurveFacetEvalTool.hpp cgm/trunk/geom/Cholla/FacetDataUtil.cpp cgm/trunk/geom/Cholla/FacetDataUtil.hpp cgm/trunk/geom/Cholla/FacetEvalTool.cpp cgm/trunk/geom/Cholla/FacetEvalTool.hpp cgm/trunk/geom/Cholla/FacetorTool.cpp cgm/trunk/geom/Cholla/FacetorTool.hpp cgm/trunk/geom/Cholla/LoopParamTool.cpp cgm/trunk/geom/Cholla/LoopParamTool.hpp cgm/trunk/geom/Cholla/Makefile.am cgm/trunk/geom/Cholla/TDGeomFacet.cpp cgm/trunk/geom/Cholla/TDGeomFacet.hpp cgm/trunk/geom/Cholla/debug.cpp cgm/trunk/geom/Cholla/debug.hpp cgm/trunk/geom/CoEdge.cpp cgm/trunk/geom/CoEdge.hpp cgm/trunk/geom/CoEdgeSM.cpp cgm/trunk/geom/CoEdgeSM.hpp cgm/trunk/geom/CoFace.cpp cgm/trunk/geom/CoFace.hpp cgm/trunk/geom/CoVertex.cpp cgm/trunk/geom/CoVertex.hpp cgm/trunk/geom/CoVolume.cpp cgm/trunk/geom/CoVolume.hpp cgm/trunk/geom/CollectionEntity.cpp cgm/trunk/geom/CollectionEntity.hpp cgm/trunk/geom/CompositeCombineEvent.hpp cgm/trunk/geom/CubitAttrib.cpp cgm/trunk/geom/CubitAttrib.hpp cgm/trunk/geom/CubitAttribManager.cpp cgm/trunk/geom/CubitAttribManager.hpp cgm/trunk/geom/CubitAttribUser.cpp cgm/trunk/geom/CubitAttribUser.hpp cgm/trunk/geom/CubitEvaluator.hpp cgm/trunk/geom/CubitGeomConfigure.h cgm/trunk/geom/CubitGeomConfigure.h.in cgm/trunk/geom/CubitPolygon.cpp cgm/trunk/geom/CubitPolygon.hpp cgm/trunk/geom/CubitSimpleAttrib.cpp cgm/trunk/geom/CubitSimpleAttrib.hpp cgm/trunk/geom/Curve.cpp cgm/trunk/geom/Curve.hpp cgm/trunk/geom/CurveOverlapFacet.cpp cgm/trunk/geom/CurveOverlapFacet.hpp cgm/trunk/geom/CurveSM.cpp cgm/trunk/geom/CurveSM.hpp cgm/trunk/geom/CylinderEvaluator.cpp cgm/trunk/geom/CylinderEvaluator.hpp cgm/trunk/geom/DAG.cpp cgm/trunk/geom/DAG.hpp cgm/trunk/geom/DagDrawingTool.cpp cgm/trunk/geom/DagDrawingTool.hpp cgm/trunk/geom/DagType.hpp cgm/trunk/geom/GSaveOpen.cpp cgm/trunk/geom/GSaveOpen.hpp cgm/trunk/geom/GeomDataObserver.cpp cgm/trunk/geom/GeomDataObserver.hpp cgm/trunk/geom/GeomMeasureTool.cpp cgm/trunk/geom/GeomMeasureTool.hpp cgm/trunk/geom/GeomPoint.hpp cgm/trunk/geom/GeomSeg.hpp cgm/trunk/geom/GeometryEntity.cpp cgm/trunk/geom/GeometryEntity.hpp cgm/trunk/geom/GeometryFeatureEngine.cpp cgm/trunk/geom/GeometryFeatureEngine.hpp cgm/trunk/geom/GeometryFeatureTool.cpp cgm/trunk/geom/GeometryFeatureTool.hpp cgm/trunk/geom/GeometryHealerEngine.cpp cgm/trunk/geom/GeometryHealerEngine.hpp cgm/trunk/geom/GeometryHealerTool.cpp cgm/trunk/geom/GeometryHealerTool.hpp cgm/trunk/geom/GeometryModifyEngine.cpp cgm/trunk/geom/GeometryModifyEngine.hpp cgm/trunk/geom/GeometryModifyTool.cpp cgm/trunk/geom/GeometryModifyTool.hpp cgm/trunk/geom/GeometryQueryEngine.cpp cgm/trunk/geom/GeometryQueryEngine.hpp cgm/trunk/geom/GeometryQueryTool.cpp cgm/trunk/geom/GeometryQueryTool.hpp cgm/trunk/geom/GeometryUtil.cpp cgm/trunk/geom/GeometryUtil.hpp cgm/trunk/geom/GfxPreview.cpp cgm/trunk/geom/GfxPreview.hpp cgm/trunk/geom/GroupingEntity.cpp cgm/trunk/geom/GroupingEntity.hpp cgm/trunk/geom/IntermediateGeomEngine.hpp cgm/trunk/geom/Loop.cpp cgm/trunk/geom/Loop.hpp cgm/trunk/geom/LoopSM.cpp cgm/trunk/geom/LoopSM.hpp cgm/trunk/geom/Lump.cpp cgm/trunk/geom/Lump.hpp cgm/trunk/geom/LumpSM.cpp cgm/trunk/geom/LumpSM.hpp cgm/trunk/geom/Makefile.am cgm/trunk/geom/MedialTool2D.cpp cgm/trunk/geom/MedialTool2D.hpp cgm/trunk/geom/MedialTool3D.cpp cgm/trunk/geom/MedialTool3D.hpp cgm/trunk/geom/MergeTool.cpp cgm/trunk/geom/MergeTool.hpp cgm/trunk/geom/MergeToolAssistant.cpp cgm/trunk/geom/MergeToolAssistant.hpp cgm/trunk/geom/MidPlaneTool.cpp cgm/trunk/geom/MidPlaneTool.hpp cgm/trunk/geom/ModelEntity.cpp cgm/trunk/geom/ModelEntity.hpp cgm/trunk/geom/ModelQueryEngine.cpp cgm/trunk/geom/ModelQueryEngine.hpp cgm/trunk/geom/OCC/ cgm/trunk/geom/OCC/Makefile.am cgm/trunk/geom/OCC/OCCAttribSet.cpp cgm/trunk/geom/OCC/OCCBody.cpp cgm/trunk/geom/OCC/OCCCurve.cpp cgm/trunk/geom/OCC/OCCDrawTool.cpp cgm/trunk/geom/OCC/OCCLoop.cpp cgm/trunk/geom/OCC/OCCLoop.hpp cgm/trunk/geom/OCC/OCCLump.cpp cgm/trunk/geom/OCC/OCCLump.hpp cgm/trunk/geom/OCC/OCCModifyEngine.cpp cgm/trunk/geom/OCC/OCCModifyEngine.hpp cgm/trunk/geom/OCC/OCCPoint.cpp cgm/trunk/geom/OCC/OCCQueryEngine.cpp cgm/trunk/geom/OCC/OCCQueryEngine.hpp cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp cgm/trunk/geom/OCC/OCCShell.cpp cgm/trunk/geom/OCC/OCCSurface.cpp cgm/trunk/geom/OCC/OCCSurface.hpp cgm/trunk/geom/OffsetSplitTool.cpp cgm/trunk/geom/OffsetSplitTool.hpp cgm/trunk/geom/OldUnmergeCode.cpp cgm/trunk/geom/OldUnmergeCode.hpp cgm/trunk/geom/Point.cpp cgm/trunk/geom/Point.hpp cgm/trunk/geom/PointSM.cpp cgm/trunk/geom/PointSM.hpp cgm/trunk/geom/RefCollection.cpp cgm/trunk/geom/RefCollection.hpp cgm/trunk/geom/RefEdge.cpp cgm/trunk/geom/RefEdge.hpp cgm/trunk/geom/RefEntity.cpp cgm/trunk/geom/RefEntity.hpp cgm/trunk/geom/RefEntityFactory.cpp cgm/trunk/geom/RefEntityFactory.hpp cgm/trunk/geom/RefEntityName.cpp cgm/trunk/geom/RefEntityName.hpp cgm/trunk/geom/RefEntityNameMap.hpp cgm/trunk/geom/RefFace.cpp cgm/trunk/geom/RefFace.hpp cgm/trunk/geom/RefGroup.cpp cgm/trunk/geom/RefGroup.hpp cgm/trunk/geom/RefVertex.cpp cgm/trunk/geom/RefVertex.hpp cgm/trunk/geom/RefVolume.cpp cgm/trunk/geom/RefVolume.hpp cgm/trunk/geom/SenseEntity.cpp cgm/trunk/geom/SenseEntity.hpp cgm/trunk/geom/Shell.cpp cgm/trunk/geom/Shell.hpp cgm/trunk/geom/ShellSM.cpp cgm/trunk/geom/ShellSM.hpp cgm/trunk/geom/SolidWorks/ cgm/trunk/geom/SphereEvaluator.cpp cgm/trunk/geom/SphereEvaluator.hpp cgm/trunk/geom/SplitSurfaceTool.cpp cgm/trunk/geom/SplitSurfaceTool.hpp cgm/trunk/geom/SurfParamTool.cpp cgm/trunk/geom/SurfParamTool.hpp cgm/trunk/geom/Surface.cpp cgm/trunk/geom/Surface.hpp cgm/trunk/geom/SurfaceOverlapFacet.cpp cgm/trunk/geom/SurfaceOverlapFacet.hpp cgm/trunk/geom/SurfaceOverlapTool.cpp cgm/trunk/geom/SurfaceOverlapTool.hpp cgm/trunk/geom/SurfaceSM.cpp cgm/trunk/geom/SurfaceSM.hpp cgm/trunk/geom/TBOwner.hpp cgm/trunk/geom/TBOwnerSet.hpp cgm/trunk/geom/TDCAGE.cpp cgm/trunk/geom/TDCAGE.hpp cgm/trunk/geom/TDCompare.hpp cgm/trunk/geom/TDSourceFeature.cpp cgm/trunk/geom/TDSourceFeature.hpp cgm/trunk/geom/TDSplitSurface.cpp cgm/trunk/geom/TDSplitSurface.hpp cgm/trunk/geom/TDSurfaceOverlap.cpp cgm/trunk/geom/TDSurfaceOverlap.hpp cgm/trunk/geom/TDUniqueId.cpp cgm/trunk/geom/TDUniqueId.hpp cgm/trunk/geom/TopologyBridge.cpp cgm/trunk/geom/TopologyBridge.hpp cgm/trunk/geom/TopologyEntity.cpp cgm/trunk/geom/TopologyEntity.hpp cgm/trunk/geom/UnMergeEvent.hpp cgm/trunk/geom/facet/ cgm/trunk/geom/facet/FacetCurve.cpp cgm/trunk/geom/facet/FacetLoop.cpp cgm/trunk/geom/facet/FacetLoop.hpp cgm/trunk/geom/facet/FacetModifyEngine.cpp cgm/trunk/geom/facet/FacetModifyEngine.hpp cgm/trunk/geom/facet/FacetParamTool.cpp cgm/trunk/geom/facet/FacetParamTool.hpp cgm/trunk/geom/facet/FacetQueryEngine.cpp cgm/trunk/geom/facet/FacetQueryEngine.hpp cgm/trunk/geom/facet/FacetboolInterface.cpp cgm/trunk/geom/facetbool/ cgm/trunk/geom/facetbool/FBRetriangulate.cpp cgm/trunk/geom/libcubit_geom.dsp cgm/trunk/geom/parallel/ cgm/trunk/geom/parallel/CGMmpi.h cgm/trunk/geom/parallel/CGMmpi_config.h.in cgm/trunk/geom/virtual/ cgm/trunk/geom/virtual/CMakeLists.txt cgm/trunk/geom/virtual/CollapseCurveTool.cpp cgm/trunk/geom/virtual/CollapseCurveTool.hpp cgm/trunk/geom/virtual/CompSurfFacets.cpp cgm/trunk/geom/virtual/CompositeEngine.cpp cgm/trunk/geom/virtual/CompositeEngine.hpp cgm/trunk/geom/virtual/CompositeGeom.cpp cgm/trunk/geom/virtual/CompositeGeom.hpp cgm/trunk/geom/virtual/CompositeLoop.cpp cgm/trunk/geom/virtual/CompositeLoop.hpp cgm/trunk/geom/virtual/CompositeSurface.cpp cgm/trunk/geom/virtual/CompositeSurface.hpp cgm/trunk/geom/virtual/CompositeTool.cpp cgm/trunk/geom/virtual/FacetProjectTool.cpp cgm/trunk/geom/virtual/FacetProjectTool.hpp cgm/trunk/geom/virtual/Faceter.cpp cgm/trunk/geom/virtual/ImprintBoundaryTool.cpp cgm/trunk/geom/virtual/Makefile.am cgm/trunk/geom/virtual/PartSurfFacetTool.cpp cgm/trunk/geom/virtual/PartitionEngine.cpp cgm/trunk/geom/virtual/PartitionEngine.hpp cgm/trunk/geom/virtual/PartitionLoop.cpp cgm/trunk/geom/virtual/PartitionLoop.hpp cgm/trunk/geom/virtual/PartitionSurface.cpp cgm/trunk/geom/virtual/PartitionTool.cpp cgm/trunk/geom/virtual/RemoveBlends.cpp cgm/trunk/geom/virtual/SimplifyTool.cpp cgm/trunk/geom/virtual/SimplifyTool.hpp cgm/trunk/geom/virtual/SubCurve.cpp cgm/trunk/geom/virtual/SubSurface.cpp cgm/trunk/geom/virtual/VGLoopTool.cpp cgm/trunk/geom/virtual/VirtualQueryEngine.cpp cgm/trunk/geom/virtual/VirtualQueryEngine.hpp cgm/trunk/init/InitCGMA.cpp cgm/trunk/itaps/iGeom_CGMA.cc cgm/trunk/itaps/testgeom.cc cgm/trunk/test/makept.cpp cgm/trunk/test/merge_test.cpp cgm/trunk/test/modify.cpp cgm/trunk/test/operation.cpp cgm/trunk/test/r_w.cpp cgm/trunk/test/test_occ.cpp cgm/trunk/test/webcut.cpp cgm/trunk/util/AppUtil.cpp cgm/trunk/util/AppUtil.hpp cgm/trunk/util/ArrayBasedContainer.cpp cgm/trunk/util/CMakeLists.txt cgm/trunk/util/CastTo.hpp cgm/trunk/util/CpuTimer.cpp cgm/trunk/util/CpuTimer.hpp cgm/trunk/util/CubitBox.cpp cgm/trunk/util/CubitBox.hpp cgm/trunk/util/CubitColorConstants.hpp cgm/trunk/util/CubitCoordinateSystem.cpp cgm/trunk/util/CubitDefines.h cgm/trunk/util/CubitDynamicLoader.cpp cgm/trunk/util/CubitEntity.cpp cgm/trunk/util/CubitEventDefines.h cgm/trunk/util/CubitFile.cpp cgm/trunk/util/CubitFile.hpp cgm/trunk/util/CubitFileFEModel.cpp cgm/trunk/util/CubitFileFEModel.hpp cgm/trunk/util/CubitFileIOWrapper.cpp cgm/trunk/util/CubitFileIOWrapper.hpp cgm/trunk/util/CubitFileMetaData.cpp cgm/trunk/util/CubitFileUtil.cpp cgm/trunk/util/CubitInputFile.hpp cgm/trunk/util/CubitMatrix.cpp cgm/trunk/util/CubitMessage.cpp cgm/trunk/util/CubitMessage.hpp cgm/trunk/util/CubitPlane.cpp cgm/trunk/util/CubitPlane.hpp cgm/trunk/util/CubitStack.cpp cgm/trunk/util/CubitString.cpp cgm/trunk/util/CubitString.hpp cgm/trunk/util/CubitTransformMatrix.cpp cgm/trunk/util/CubitTransformMatrix.hpp cgm/trunk/util/CubitUtil.cpp cgm/trunk/util/CubitUtil.hpp cgm/trunk/util/CubitUtilConfigure.h.in cgm/trunk/util/CubitVector.cpp cgm/trunk/util/CubitVector.hpp cgm/trunk/util/DIntArray.cpp cgm/trunk/util/DLIList.cpp cgm/trunk/util/DLIList.hpp cgm/trunk/util/DLList.hpp cgm/trunk/util/DynamicArray.cpp cgm/trunk/util/DynamicArray.hpp cgm/trunk/util/ElementType.h cgm/trunk/util/GMem.cpp cgm/trunk/util/GeometryDefines.h cgm/trunk/util/GetLongOpt.hpp cgm/trunk/util/GfxDebug.cpp cgm/trunk/util/GfxDebug.hpp cgm/trunk/util/IntersectionTool.cpp cgm/trunk/util/IntersectionTool.hpp cgm/trunk/util/KDDTree.cpp cgm/trunk/util/Makefile.am cgm/trunk/util/MemoryBlock.hpp cgm/trunk/util/MemoryManager.cpp cgm/trunk/util/MemoryManager.hpp cgm/trunk/util/OctTree.cpp cgm/trunk/util/OtherFiles/make.client cgm/trunk/util/ParamTool.hpp cgm/trunk/util/PlanarParamTool.cpp cgm/trunk/util/PlanarParamTool.hpp cgm/trunk/util/PriorityQueue.cpp cgm/trunk/util/RTree.cpp cgm/trunk/util/RTree.hpp cgm/trunk/util/RandomMersenne.cpp cgm/trunk/util/SDLList.cpp cgm/trunk/util/SDLList.hpp cgm/trunk/util/SettingHandler.cpp cgm/trunk/util/SettingHandler.hpp cgm/trunk/util/TextProgressTool.cpp cgm/trunk/util/ToolData.cpp cgm/trunk/util/ToolData.hpp cgm/trunk/util/ToolDataUser.cpp cgm/trunk/util/ToolDataUser.hpp cgm/trunk/util/TtyProgressTool.cpp Log: Merge branch/merge-cubit12 to trunk, passed all testcases for OCC6.3(build with /geom/OCC/occ_patches), OCC6.5(build with /geom/OCC/occ_patches_6.5), acis17 as well as cubit12 builds. Special note: When building with cubit12, current test code doesn't do anything for geom/testing directory. Status is <All 0 tests passed>.
Property changes on: cgm/trunk ___________________________________________________________________ Added: svn:mergeinfo + /cgm/branches/cubit:1041-3427 /cgm/branches/merge-cubit12:3424-4774
Deleted: cgm/trunk/KNOWN_ISSUES =================================================================== --- cgm/trunk/KNOWN_ISSUES 2011-04-23 05:15:17 UTC (rev 4774) +++ cgm/trunk/KNOWN_ISSUES 2011-04-26 17:54:11 UTC (rev 4775) @@ -1,27 +0,0 @@ -This is a list of the known issues with CGM on OCC.For more details please see -the online ticket system at the MOAB website: - https://trac.mcs.anl.gov/projects/ITAPS/wiki - - - -ID Severity Summary/Details -=== ======== =================================================================== -175 critical imprint special cases fail with crash. - -176 minor CGM memory leak - -178 major Unite function doesn't unite smoothly connected surfaces. - -179 major mcnp2cad test suite lat1-7 not working, needs debugging. - -180 major There are lots new functions or added functions to exsisting - functions requirements to port OCC to cubit12. - -181 minor Lack of good cases for testing purpose. - -182 minor Dirty geometry/imported geometry is not tested for read/repair yet -183 minor Don't have proper tool to visualize the TopoDS_Shapes, debugging - process is long preparing for graphics to understand the issue - -185 major mcnp2cad/tests/INP-torus test case fails on imprinting 2 spline - surfaces.
Added: cgm/trunk/KNOWN_ISSUES =================================================================== --- cgm/trunk/KNOWN_ISSUES (rev 0) +++ cgm/trunk/KNOWN_ISSUES 2011-04-26 17:54:11 UTC (rev 4775) @@ -0,0 +1,27 @@ +This is a list of the known issues with CGM on OCC.For more details please see +the online ticket system at the MOAB website: + https://trac.mcs.anl.gov/projects/ITAPS/wiki + + +
-- ================================================================ "You will keep in perfect peace him whose mind is steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory ([email protected]) (telecommuting from UW-Madison) phone: (608) 263-8485 1500 Engineering Dr. fax: (608) 263-4499 Madison, WI 53706
participants (1)
Steve Jackson
