Author: janehu Date: 2012-07-26 10:42:27 -0500 (Thu, 26 Jul 2012) New Revision: 5639 Modified: cgm/branches/merge-cubit13.1/test/Makefile.am Log: Remove the attribute_to_buffer from the link. It's no longer a testcase here. Modified: cgm/branches/merge-cubit13.1/test/Makefile.am =================================================================== --- cgm/branches/merge-cubit13.1/test/Makefile.am 2012-07-25 19:42:36 UTC (rev 5638) +++ cgm/branches/merge-cubit13.1/test/Makefile.am 2012-07-26 15:42:27 UTC (rev 5639) @@ -46,8 +46,6 @@ init_SOURCES = init.cpp attribute_to_file_SOURCES = attribute_to_file.cpp attribute_to_file_CPPFLAGS = $(CPPFLAGS) $(AM_CPPFLAGS) -DTEST_OCC -attribute_to_buffer_SOURCES = attribute_to_buffer.cpp -attribute_to_buffer_CPPFLAGS = $(CPPFLAGS) $(AM_CPPFLAGS) -DTEST_OCC brick_sources = brick.cpp brick_acis_SOURCES = $(brick_sources)
participants (1)
janehu@mcs.anl.gov
