How do I use OTF2 traces generated from Score-P as a model workload type? I know DUMPI is the default, but I cannot seem to specify the other case. Also, I am passing the Score-P measurement directory with the trace files (one per process), hopefully that is the correct usage. model-net-mpi-replay --sync=1 --workload_type=<???> --workload_file=scorep-measurement-folder --num_net_traces=1024 -- modelnet-test-dragonfly.conf -- Thanks, Sayan | https://sg0.github.io/
I think I missed to use Tracer, as I understand now, OTF2 traces can be replayed using Tracer on CODES/ROSS model networks. On Thu, Sep 26, 2019 at 10:23 PM Sayan Ghosh <[email protected]> wrote:
-- Sayan | https://sg0.github.io/
participants (1)
Sayan Ghosh
