Re: [CI Ticketing System #4334] Re: URGENT /ci/projects/cnari disk usage
fmri_classic would make the most sense i think On Fri, Apr 30, 2010 at 2:56 PM, Ti Leggett <[email protected]> wrote:
Can I move them into one of the PADS project spaces: stroke_recovery, child_language, aphasia, fmri_classic, normal_language, or swift instead /gpfs/pads/fmri (which needs to be emptied and moved into project spaces)?
On Fri Apr 30 14:45:43 2010, [email protected] wrote:
Yes, Im sure they can.
For now, please do whatever you need to solve the problem if its affecting all users, and we can sort things out on monday.
If you want to just compress things, if you do things older than a month (or even a week) I strongly suspect there will be no user impact, and I will take responsibility for any impact that does occur (short of data loss ;)
Mike A, can you confirm that this is just an archival directory, and that moving old logs elsewhere will not impact any work for HNL/CNARI?
Mike
----- "Ti Leggett" <[email protected]> wrote:
Can the logs be compressed at all?
On Fri Apr 30 14:40:09 2010, [email protected] wrote:
Ti, Sarah is on vacation till Tuesday
That dir looks to me like Swift logs.
If you need space ASAP, you can consider doing this: - make a log dir in CNARI space on PADS (I'll suggest a dir in a moment) - make a symlink logs/OLD to that log "archive" - move logs older than 30 days to the OLD/<username> directory
Will that solve the problem?
Moving forward, we can automate this.
We *do* however need to keep these logs for the moment.
Mike A, if we go ahead with this, can you alert any users that would be affected?
Mike
The cnari project in /ci/projects is using about 60% of the total available capacity of that drive. Most of that is in the logs directory. Is it possible to clean up that space? Possibly delete unneeded log files (400G worth)?
[root@nfs space0]# du --max-depth=1 projects/cnari | sort -n 40 projects/cnari/.svn 612 projects/cnari/wrappers 888 projects/cnari/projects 892 projects/cnari/config 920 projects/cnari/scripts 306000 projects/cnari/scratch 311280 projects/cnari/soft 576832 projects/cnari/usr 1609780 projects/cnari/.builds 2111660 projects/cnari/sandbox 13311276 projects/cnari/apps 173988356 projects/cnari/swift_work 408088576 projects/cnari/logs 600307116 projects/cnari
participants (1)
skenny
