Here's the output. [root@backup log]# rpm --verify openssh-server SM5....T c /etc/ssh/sshd_config On May 13, 2011, at 10:23 AM, Ti Leggett wrote:
Run rpm -- verify openssh-server to see if it's been changes
On May 13, 2011, at 10:12 AM, Craig Stacey <[email protected]> wrote:
Thanks, Robert. Please copy [email protected] on communications as well so we can coordinate. I've forwarded this on.
On May 13, 2011, at 10:07 , Robert Johnson wrote:
Hello,
I was concerned about backup.ibi because backup.ci needed a rebuild and the two servers communicate.
I did not see anything in the log files that make me suspicious of a break in but the md5 sum
[root@backup ~]# md5sum /usr/sbin/sshd 16644bf80e5c8f79a03cc50e22ac8c48 /usr/sbin/sshd
Is different from what I would expect from a bcfg CI server.
I have turned off SSH on the server as a precaution.
-- Robert
== Craig
That means sshd matches the md5 of the RPM so you should be ok. On May 13, 2011, at 10:27 AM, Robert Johnson <[email protected]> wrote:
Here's the output.
Hello,
-- Robert
== Craig
participants (2)
Robert Johnson -
Ti Leggett
