Fwd: Undelivered Mail Returned to Sender
I removed Eric Ross from the RT alcf-operations group since he left the lab. Begin forwarded message:
From: [email protected] (Mail Delivery System) Subject: Undelivered Mail Returned to Sender Date: January 8, 2013 1:39:01 PM CST To: [email protected]
This is the mail system at host rt.mcs.anl.gov.
I'm sorry to have to inform you that your message could not be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can delete your own text from the attached returned message.
The mail system
<[email protected]>: host 140.221.7.6[140.221.7.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command) Reporting-MTA: dns; rt.mcs.anl.gov X-Postfix-Queue-ID: D1162422AD X-Postfix-Sender: rfc822; [email protected] Arrival-Date: Tue, 8 Jan 2013 13:39:01 -0600 (CST)
Final-Recipient: rfc822; [email protected] Action: failed Status: 5.1.1 Remote-MTA: dns; 140.221.7.6 Diagnostic-Code: smtp; 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table
From: Steve Crusan <[email protected]> Subject: [alcf2-maint #147125] Rebuild mira login GPFS cluster Date: January 8, 2013 1:39:01 PM CST To: [email protected] Reply-To: [email protected], Steve Crusan <[email protected]>
Description: Right now, the mira login node cluster has the wrong name (miralacNSD), and only 1 node is actively being used by users. We should rebuild this closer using a proper name, and configure the GPFS settings to support a login environment, and test if possible. Eventually, everything will transition to having the mira lions being a part of this cluster, but I'd like to get the foundation for all of that setup before we need to do 45 things at once. Even if we don't open up the other lacs to user login yet, we would have everything ready.
Time: 4 hours Kicken: Yes Dependencies: mira login nodes, GPFS, IB network Notes:
- delete the miralacNSD cluster (it's a namespace only, gpfs0 is LOOOOOONG gone) - delete remote cluster authorizations for this cluster from NSD clusters, and delete the RSA keys - build new GPFS cluster miraloginIO.mira.i2b.alcf.anl.gov cluster - setup GPFS tunables to cater to a login environment (more file/inode caching, etc) - do some simple tests if there is time - hostbased (as root) must work between miralac1-4 - during this timeframe, the infrastructure team could also update the other login nodes (miralac2-4) if they would like. Might be worth another ticket…
-------------------------------------- Steve Crusan HPC System Administrator - Filesystems Leadership Computing Facility Argonne National Laboratory
participants (1)
Ti Leggett
