[RHSA-2014:1317-01] Moderate: cfme security, bug fix, and enhancement update
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1 ===================================================================== Red Hat Security Advisory Synopsis: Moderate: cfme security, bug fix, and enhancement update Advisory ID: RHSA-2014:1317-01 Product: Red Hat CloudForms Advisory URL: https://rhn.redhat.com/errata/RHSA-2014-1317.html Issue date: 2014-10-02 CVE Names: CVE-2014-0140 CVE-2014-3642 ===================================================================== 1. Summary: Updated cfme packages that fix two security issues, several bugs, and add various enhancements are now available for Red Hat CloudForms 3.1. Red Hat Product Security has rated this update as having Moderate security impact. Common Vulnerability Scoring System (CVSS) base scores, which give detailed severity ratings, are available for each vulnerability from the CVE links in the References section. 2. Relevant releases/architectures: CloudForms Management Engine 5.3 - noarch, x86_64 3. Description: Red Hat CloudForms Management Engine delivers the insight, control, and automation needed to address the challenges of managing virtual environments. CloudForms Management Engine is built on Ruby on Rails, a model-view-controller (MVC) framework for web application development. Action Pack implements the controller and the view components. It was found that Red Hat CloudForms exposed default routes that were reachable via HTTP(S) requests. An authenticated user could use this flaw to access potentially sensitive controllers and actions that would allow for privilege escalation. (CVE-2014-0140) It was found that Red Hat CloudForms contained an insecure send method that accepted user-supplied arguments. An authenticated user could use this flaw to modify the program flow in a way that could result in privilege escalation. (CVE-2014-3642) These issues were discovered by Jan Rusnacko of Red Hat Product Security. This update also fixes several bugs and adds various enhancements. Documentation for these changes is available in the Release Notes and Technical Notes documents linked to in the References section. All cfme users are advised to upgrade to these updated packages, which contain correct these issues and add these enhancements. 4. Solution: Before applying this update, make sure all previously released errata relevant to your system have been applied. This update is available via the Red Hat Network. Details on how to use the Red Hat Network to apply this update are available at https://access.redhat.com/site/articles/11258 5. Bugs fixed (https://bugzilla.redhat.com/): 1077359 - CVE-2014-0140 CFME: default routes expose controllers and actions 1092894 - CVE-2014-3642 CFME: dangerous send method in performance.rb 6. Package List: CloudForms Management Engine 5.3: Source: certmonger-0.75.13-1.el6.src.rpm cfme-5.2.1.8-1.el6cf.src.rpm cfme-5.2.2.1-1.el6cf.src.rpm cfme-5.3.0.0-1.el6cf.alpha2.src.rpm cfme-5.3.0.0-10.el6cf.alpha5.src.rpm cfme-5.3.0.0-13.el6cf.alpha6.src.rpm cfme-5.3.0.0-2.el6cf.alpha2.src.rpm cfme-5.3.0.0-3.el6cf.alpha2.src.rpm cfme-5.3.0.0-4.el6cf.alpha2.src.rpm cfme-5.3.0.0-5.el6cf.alpha3.src.rpm cfme-5.3.0.0-6.el6cf.alpha3.src.rpm cfme-5.3.0.0-7.el6cf.alpha4.src.rpm cfme-5.3.0.0-9.el6cf.alpha5.src.rpm cfme-5.3.0.15-1.el6cf.src.rpm cfme-vnc-plugin-1.0.0-2.el6cf.src.rpm libdnet-1.12-11.el6cf.src.rpm lshw-B.02.16-4.el6cf.src.rpm mod_authnz_pam-0.9.2-1.el6.src.rpm mod_intercept_form_submit-0.9.7-1.el6.src.rpm mod_lookup_identity-0.9.2-1.el6.src.rpm netapp-manageability-sdk-4.0P1-3.el6cf.src.rpm open-vm-tools-9.2.3-5.el6cf.src.rpm prince-9.0r2-4.el6cf.src.rpm pyliblzma-0.5.3-7.el6cf.src.rpm ruby193-rubygem-Platform-0.4.0-4.el6cf.src.rpm ruby193-rubygem-actionmailer-3.2.17-1.el6cf.src.rpm ruby193-rubygem-actionpack-3.2.13-5.el6cf.src.rpm ruby193-rubygem-actionpack-3.2.17-3.el6cf.src.rpm ruby193-rubygem-actionpack-3.2.17-6.el6cf.src.rpm ruby193-rubygem-actionwebservice-3.1.0-3.el6cf.src.rpm ruby193-rubygem-active_hash-1.3.0-2.el6cf.src.rpm ruby193-rubygem-activemodel-3.2.17-1.el6cf.src.rpm ruby193-rubygem-activerecord-3.2.13-4.el6cf.src.rpm ruby193-rubygem-activerecord-3.2.17-1.el6cf.src.rpm ruby193-rubygem-activerecord-3.2.17-4.el6cf.src.rpm ruby193-rubygem-activeresource-3.2.17-1.el6cf.src.rpm ruby193-rubygem-activesupport-3.2.17-1.el6cf.src.rpm ruby193-rubygem-acts_as_list-0.1.9-1.el6cf.src.rpm ruby193-rubygem-acts_as_tree-0.1.1-1.el6cf.src.rpm ruby193-rubygem-addressable-2.2.8-1.el6cf.src.rpm ruby193-rubygem-akami-1.2.0-1.el6cf.src.rpm ruby193-rubygem-american_date-1.0.0-1.el6cf.src.rpm ruby193-rubygem-amq-protocol-1.9.2-3.el6cf.src.rpm ruby193-rubygem-ancestry-1.2.5-1.el6cf.src.rpm ruby193-rubygem-arrayfields-4.9.0-1.el6cf.src.rpm ruby193-rubygem-awesome_print-1.1.0-1.el6cf.src.rpm ruby193-rubygem-awesome_spawn-1.2.1-1.el6cf.src.rpm ruby193-rubygem-aws-sdk-1.11.3-1.el6cf.src.rpm ruby193-rubygem-binary_struct-1.0.1-1.el6cf.src.rpm ruby193-rubygem-brakeman-2.0.0-1.el6cf.src.rpm ruby193-rubygem-bullet-4.6.0-1.el6cf.src.rpm ruby193-rubygem-bundler_ext-0.4.0-1.el6cf.src.rpm ruby193-rubygem-bunny-1.0.7-1.el6cf.src.rpm ruby193-rubygem-capybara-2.1.0-1.el6cf.src.rpm ruby193-rubygem-childprocess-0.3.9-1.el6cf.src.rpm ruby193-rubygem-chronic-0.3.0-1.el6cf.src.rpm ruby193-rubygem-churn-0.0.29-1.el6cf.src.rpm ruby193-rubygem-code_analyzer-0.3.2-1.el6cf.src.rpm ruby193-rubygem-color-1.4.1-4.el6cf.src.rpm ruby193-rubygem-colored-1.2-1.el6cf.src.rpm ruby193-rubygem-crack-0.3.2-1.el6cf.src.rpm ruby193-rubygem-daemons-1.1.9-2.el6cf.src.rpm ruby193-rubygem-dalli-2.2.1-1.el6cf.src.rpm ruby193-rubygem-default_value_for-1.0.7-1.el6cf.src.rpm ruby193-rubygem-elif-0.1.0-1.el6cf.src.rpm ruby193-rubygem-eventmachine-1.0.0-1.el6cf.src.rpm ruby193-rubygem-excon-0.31.0-1.el6cf.src.rpm ruby193-rubygem-execjs-2.0.2-1.el6cf.src.rpm ruby193-rubygem-ezcrypto-0.7-1.el6cf.src.rpm ruby193-rubygem-facade-1.0.5-1.el6cf.src.rpm ruby193-rubygem-factory_girl-4.1.0-1.el6cf.src.rpm ruby193-rubygem-fastercsv-1.5.5-2.el6cf.src.rpm ruby193-rubygem-fattr-2.2.1-1.el6cf.src.rpm ruby193-rubygem-ffi-1.9.3-1.el6cf.src.rpm ruby193-rubygem-flay-2.3.0-1.el6cf.src.rpm ruby193-rubygem-flog-3.2.3-2.el6cf.src.rpm ruby193-rubygem-fog-1.19.0-1.el6cf.src.rpm ruby193-rubygem-formatador-0.2.4-1.el6cf.src.rpm ruby193-rubygem-gssapi-1.1.2-1.el6cf.src.rpm ruby193-rubygem-gyoku-1.0.0-1.el6cf.src.rpm ruby193-rubygem-haml-4.0.5-1.el6cf.src.rpm ruby193-rubygem-haml-rails-0.4-1.el6cf.src.rpm ruby193-rubygem-handsoap-0.2.5-2.el6cf.src.rpm ruby193-rubygem-highline-1.6.21-1.el6cf.src.rpm ruby193-rubygem-hirb-0.7.1-1.el6cf.src.rpm ruby193-rubygem-hmac-0.4.0-7.el6cf.src.rpm ruby193-rubygem-hoe-2.12.3-2.el6cf.src.rpm ruby193-rubygem-httparty-0.10.2-1.el6cf.src.rpm ruby193-rubygem-httpclient-2.2.7-1.el6cf.src.rpm ruby193-rubygem-httpi-2.0.2-1.el6cf.src.rpm ruby193-rubygem-i18n-0.6.9-1.el6cf.src.rpm ruby193-rubygem-inifile-2.0.2-1.el6cf.src.rpm ruby193-rubygem-io-extra-1.2.6-1.el6cf.src.rpm ruby193-rubygem-japgolly-Saikuro-1.1.1.0-1.el6cf.src.rpm ruby193-rubygem-jbuilder-2.0.7-1.el6cf.src.rpm ruby193-rubygem-json-1.8.0-3.el6cf.src.rpm ruby193-rubygem-json_pure-1.8.0-1.el6cf.src.rpm ruby193-rubygem-libxml-ruby-2.2.2-1.el6cf.src.rpm ruby193-rubygem-linux_admin-0.7.0-1.el6cf.src.rpm ruby193-rubygem-linux_admin-0.9.1-1.el6cf.src.rpm ruby193-rubygem-little-plugger-1.1.3-1.el6cf.src.rpm ruby193-rubygem-log4r-1.1.8-1.el6cf.src.rpm ruby193-rubygem-logging-1.6.2-1.el6cf.src.rpm ruby193-rubygem-mail-2.5.4-1.el6cf.src.rpm ruby193-rubygem-main-4.7.1-1.el6cf.src.rpm ruby193-rubygem-map-6.5.1-1.el6cf.src.rpm ruby193-rubygem-metric_fu-3.0.0-1.el6cf.src.rpm ruby193-rubygem-mime-types-1.20.1-1.el6cf.src.rpm ruby193-rubygem-minitest-3.2.0-3.el6cf.src.rpm ruby193-rubygem-more_core_extensions-1.2.0-1.el6cf.src.rpm ruby193-rubygem-multi_json-1.7.7-1.el6cf.src.rpm ruby193-rubygem-multi_xml-0.5.2-1.el6cf.src.rpm ruby193-rubygem-net-ldap-0.7.0-1.el6cf.src.rpm ruby193-rubygem-net-ping-1.7.4-2.el6cf.src.rpm ruby193-rubygem-net-scp-1.1.2-1.el6cf.src.rpm ruby193-rubygem-net-sftp-2.0.5-7.el6cf.src.rpm ruby193-rubygem-net-ssh-2.9.1-1.el6cf.src.rpm ruby193-rubygem-netrc-0.7.7-3.el6cf.src.rpm ruby193-rubygem-nokogiri-1.5.6-3.el6cf.src.rpm ruby193-rubygem-nori-2.1.0-1.el6cf.src.rpm ruby193-rubygem-open4-1.3.0-4.el6cf.src.rpm ruby193-rubygem-outfielding-jqplot-rails-1.0.8-1.el6cf.src.rpm ruby193-rubygem-ovirt_metrics-1.0.1-1.el6cf.src.rpm ruby193-rubygem-parallel-0.5.21-1.el6cf.src.rpm ruby193-rubygem-pdf-writer-1.1.8-1.el6cf.src.rpm ruby193-rubygem-pg-0.12.2-5.el6cf.src.rpm ruby193-rubygem-princely-1.2.6-1.el6cf.src.rpm ruby193-rubygem-progressbar-0.11.0-2.el6cf.src.rpm ruby193-rubygem-prototype-rails-3.2.1-1.el6cf.src.rpm ruby193-rubygem-qpid_messaging-0.20.2-2.el6cf.src.rpm ruby193-rubygem-rack-1.4.5-3.el6cf.src.rpm ruby193-rubygem-rack-test-0.6.2-1.el6cf.src.rpm ruby193-rubygem-rails-3.2.17-1.el6cf.src.rpm ruby193-rubygem-rails_best_practices-1.13.8-1.el6cf.src.rpm ruby193-rubygem-railties-3.2.17-1.el6cf.src.rpm ruby193-rubygem-rake-10.1.0-1.el6cf.src.rpm ruby193-rubygem-rake-compiler-0.8.3-2.el6cf.src.rpm ruby193-rubygem-rbovirt-0.0.17-3.el6cf.src.rpm ruby193-rubygem-rbvmomi-1.2.3-4.el6cf.src.rpm ruby193-rubygem-rdoc-3.12.2-4.el6cf.src.rpm ruby193-rubygem-reek-1.3.1-1.el6cf.src.rpm ruby193-rubygem-rest-client-1.6.7-5.el6cf.src.rpm ruby193-rubygem-roodi-2.2.0-1.el6cf.src.rpm ruby193-rubygem-rspec-2.12.0-1.el6cf.src.rpm ruby193-rubygem-rspec-core-2.12.2-1.el6cf.src.rpm ruby193-rubygem-rspec-expectations-2.12.1-1.el6cf.src.rpm ruby193-rubygem-rspec-fire-1.3.0-1.el6cf.src.rpm ruby193-rubygem-rspec-mocks-2.12.1-1.el6cf.src.rpm ruby193-rubygem-rspec-rails-2.12.1-1.el6cf.src.rpm ruby193-rubygem-ruby-graphviz-1.0.9-1.el6cf.src.rpm ruby193-rubygem-ruby-plsql-0.4.1-1.el6cf.src.rpm ruby193-rubygem-ruby-prof-0.13.0-1.el6cf.src.rpm ruby193-rubygem-ruby-progressbar-0.0.10-1.el6cf.src.rpm ruby193-rubygem-ruby2ruby-2.0.6-1.el6cf.src.rpm ruby193-rubygem-ruby_parser-3.1.3-2.el6cf.src.rpm ruby193-rubygem-rubyforge-2.0.4-3.el6cf.src.rpm ruby193-rubygem-rubyntlm-0.4.0-1.el6cf.src.rpm ruby193-rubygem-rubyrep-1.2.0-6.el6cf.src.rpm ruby193-rubygem-rubywbem-0.1.0-2.el6cf.src.rpm ruby193-rubygem-rubyzip-0.9.5-1.el6cf.src.rpm ruby193-rubygem-rufus-lru-1.0.5-1.el6cf.src.rpm ruby193-rubygem-rufus-scheduler-2.0.19-2.el6cf.src.rpm ruby193-rubygem-ruport-1.7.0-2.el6cf.src.rpm ruby193-rubygem-savon-2.2.0-1.el6cf.src.rpm ruby193-rubygem-secure_headers-1.1.1-1.el6cf.src.rpm ruby193-rubygem-selenium-webdriver-2.32.1-2.el6cf.src.rpm ruby193-rubygem-sexp_processor-4.2.1-1.el6cf.src.rpm ruby193-rubygem-shindo-0.3.4-7.el6cf.src.rpm ruby193-rubygem-shoulda-matchers-1.0.0-1.el6cf.src.rpm ruby193-rubygem-simple-rss-1.2.3-8.el6cf.src.rpm ruby193-rubygem-simplecov-0.7.1-6.el6cf.src.rpm ruby193-rubygem-simplecov-html-0.7.1-2.el6cf.src.rpm ruby193-rubygem-simplecov-rcov-0.2.3-1.el6cf.src.rpm ruby193-rubygem-simplecov-rcov-text-0.0.2-1.el6cf.src.rpm ruby193-rubygem-slim-1.3.9-1.el6cf.src.rpm ruby193-rubygem-snmp-1.1.0-6.el6cf.src.rpm ruby193-rubygem-soap4r-1.6.0-2.el6cf.src.rpm ruby193-rubygem-state_machine-1.1.2-8.el6cf.src.rpm ruby193-rubygem-syntax-1.0.0-8.el6cf.src.rpm ruby193-rubygem-temple-0.6.5-1.el6cf.src.rpm ruby193-rubygem-terminal-table-1.4.5-1.el6cf.src.rpm ruby193-rubygem-test-spec-0.10.0-7.el6cf.src.rpm ruby193-rubygem-test-unit-2.4.5-5.el6cf.src.rpm ruby193-rubygem-thin-1.3.1-5.el6cf.src.rpm ruby193-rubygem-timecop-0.5.3-1.el6cf.src.rpm ruby193-rubygem-transaction-simple-1.4.0-5.el6cf.src.rpm ruby193-rubygem-trollop-1.16.2-2.el6cf.src.rpm ruby193-rubygem-uglifier-2.4.0-1.el6cf.src.rpm ruby193-rubygem-uniform_notifier-1.2.0-1.el6cf.src.rpm ruby193-rubygem-uuidtools-2.1.3-3.el6cf.src.rpm ruby193-rubygem-vcr-2.4.0-1.el6cf.src.rpm ruby193-rubygem-wasabi-3.1.0-1.el6cf.src.rpm ruby193-rubygem-webmock-1.11.0-1.el6cf.src.rpm ruby193-rubygem-websocket-1.0.7-1.el6cf.src.rpm ruby193-rubygem-winrm-1.1.3-1.el6cf.src.rpm ruby193-rubygem-winrm-1.1.3-2.el6cf.src.rpm ruby193-rubygem-winrm-1.1.3-4.el6cf.src.rpm ruby193-rubygem-xml-simple-1.0.12-1.el6cf.src.rpm ruby193-rubygem-xpath-2.0.0-1.el6cf.src.rpm ruby193-rubygem-ziya-2.3.0-2.el6cf.src.rpm selinux-policy-3.7.19-244.el6.src.rpm sneakernet_ca-0.1-2.el6cf.src.rpm sssd-1.11.6-3.el6.src.rpm noarch: python-sssdconfig-1.11.6-3.el6.noarch.rpm ruby193-rubygem-Platform-0.4.0-4.el6cf.noarch.rpm ruby193-rubygem-actionmailer-3.2.17-1.el6cf.noarch.rpm ruby193-rubygem-actionpack-3.2.13-5.el6cf.noarch.rpm ruby193-rubygem-actionpack-3.2.17-3.el6cf.noarch.rpm ruby193-rubygem-actionpack-3.2.17-6.el6cf.noarch.rpm ruby193-rubygem-actionwebservice-3.1.0-3.el6cf.noarch.rpm ruby193-rubygem-active_hash-1.3.0-2.el6cf.noarch.rpm ruby193-rubygem-activemodel-3.2.17-1.el6cf.noarch.rpm ruby193-rubygem-activerecord-3.2.13-4.el6cf.noarch.rpm ruby193-rubygem-activerecord-3.2.17-1.el6cf.noarch.rpm ruby193-rubygem-activerecord-3.2.17-4.el6cf.noarch.rpm ruby193-rubygem-activeresource-3.2.17-1.el6cf.noarch.rpm ruby193-rubygem-activesupport-3.2.17-1.el6cf.noarch.rpm ruby193-rubygem-acts_as_list-0.1.9-1.el6cf.noarch.rpm ruby193-rubygem-acts_as_tree-0.1.1-1.el6cf.noarch.rpm ruby193-rubygem-addressable-2.2.8-1.el6cf.noarch.rpm ruby193-rubygem-akami-1.2.0-1.el6cf.noarch.rpm ruby193-rubygem-american_date-1.0.0-1.el6cf.noarch.rpm ruby193-rubygem-amq-protocol-1.9.2-3.el6cf.noarch.rpm ruby193-rubygem-ancestry-1.2.5-1.el6cf.noarch.rpm ruby193-rubygem-arrayfields-4.9.0-1.el6cf.noarch.rpm ruby193-rubygem-awesome_print-1.1.0-1.el6cf.noarch.rpm ruby193-rubygem-awesome_spawn-1.2.1-1.el6cf.noarch.rpm ruby193-rubygem-aws-sdk-1.11.3-1.el6cf.noarch.rpm ruby193-rubygem-binary_struct-1.0.1-1.el6cf.noarch.rpm ruby193-rubygem-brakeman-2.0.0-1.el6cf.noarch.rpm ruby193-rubygem-bullet-4.6.0-1.el6cf.noarch.rpm ruby193-rubygem-bundler_ext-0.4.0-1.el6cf.noarch.rpm ruby193-rubygem-bunny-1.0.7-1.el6cf.noarch.rpm ruby193-rubygem-capybara-2.1.0-1.el6cf.noarch.rpm ruby193-rubygem-childprocess-0.3.9-1.el6cf.noarch.rpm ruby193-rubygem-chronic-0.3.0-1.el6cf.noarch.rpm ruby193-rubygem-churn-0.0.29-1.el6cf.noarch.rpm ruby193-rubygem-code_analyzer-0.3.2-1.el6cf.noarch.rpm ruby193-rubygem-color-1.4.1-4.el6cf.noarch.rpm ruby193-rubygem-colored-1.2-1.el6cf.noarch.rpm ruby193-rubygem-crack-0.3.2-1.el6cf.noarch.rpm ruby193-rubygem-daemons-1.1.9-2.el6cf.noarch.rpm ruby193-rubygem-dalli-2.2.1-1.el6cf.noarch.rpm ruby193-rubygem-default_value_for-1.0.7-1.el6cf.noarch.rpm ruby193-rubygem-elif-0.1.0-1.el6cf.noarch.rpm ruby193-rubygem-excon-0.31.0-1.el6cf.noarch.rpm ruby193-rubygem-execjs-2.0.2-1.el6cf.noarch.rpm ruby193-rubygem-ezcrypto-0.7-1.el6cf.noarch.rpm ruby193-rubygem-facade-1.0.5-1.el6cf.noarch.rpm ruby193-rubygem-factory_girl-4.1.0-1.el6cf.noarch.rpm ruby193-rubygem-fastercsv-1.5.5-2.el6cf.noarch.rpm ruby193-rubygem-fattr-2.2.1-1.el6cf.noarch.rpm ruby193-rubygem-flay-2.3.0-1.el6cf.noarch.rpm ruby193-rubygem-flog-3.2.3-2.el6cf.noarch.rpm ruby193-rubygem-fog-1.19.0-1.el6cf.noarch.rpm ruby193-rubygem-formatador-0.2.4-1.el6cf.noarch.rpm ruby193-rubygem-gssapi-1.1.2-1.el6cf.noarch.rpm ruby193-rubygem-gyoku-1.0.0-1.el6cf.noarch.rpm ruby193-rubygem-haml-4.0.5-1.el6cf.noarch.rpm ruby193-rubygem-haml-rails-0.4-1.el6cf.noarch.rpm ruby193-rubygem-handsoap-0.2.5-2.el6cf.noarch.rpm ruby193-rubygem-highline-1.6.21-1.el6cf.noarch.rpm ruby193-rubygem-hirb-0.7.1-1.el6cf.noarch.rpm ruby193-rubygem-hmac-0.4.0-7.el6cf.noarch.rpm ruby193-rubygem-hoe-2.12.3-2.el6cf.noarch.rpm ruby193-rubygem-httparty-0.10.2-1.el6cf.noarch.rpm ruby193-rubygem-httpclient-2.2.7-1.el6cf.noarch.rpm ruby193-rubygem-httpi-2.0.2-1.el6cf.noarch.rpm ruby193-rubygem-i18n-0.6.9-1.el6cf.noarch.rpm ruby193-rubygem-inifile-2.0.2-1.el6cf.noarch.rpm ruby193-rubygem-japgolly-Saikuro-1.1.1.0-1.el6cf.noarch.rpm ruby193-rubygem-jbuilder-2.0.7-1.el6cf.noarch.rpm ruby193-rubygem-json_pure-1.8.0-1.el6cf.noarch.rpm ruby193-rubygem-linux_admin-0.7.0-1.el6cf.noarch.rpm ruby193-rubygem-linux_admin-0.9.1-1.el6cf.noarch.rpm ruby193-rubygem-little-plugger-1.1.3-1.el6cf.noarch.rpm ruby193-rubygem-log4r-1.1.8-1.el6cf.noarch.rpm ruby193-rubygem-logging-1.6.2-1.el6cf.noarch.rpm ruby193-rubygem-mail-2.5.4-1.el6cf.noarch.rpm ruby193-rubygem-main-4.7.1-1.el6cf.noarch.rpm ruby193-rubygem-map-6.5.1-1.el6cf.noarch.rpm ruby193-rubygem-metric_fu-3.0.0-1.el6cf.noarch.rpm ruby193-rubygem-mime-types-1.20.1-1.el6cf.noarch.rpm ruby193-rubygem-minitest-3.2.0-3.el6cf.noarch.rpm ruby193-rubygem-more_core_extensions-1.2.0-1.el6cf.noarch.rpm ruby193-rubygem-multi_json-1.7.7-1.el6cf.noarch.rpm ruby193-rubygem-multi_xml-0.5.2-1.el6cf.noarch.rpm ruby193-rubygem-net-ldap-0.7.0-1.el6cf.noarch.rpm ruby193-rubygem-net-ping-1.7.4-2.el6cf.noarch.rpm ruby193-rubygem-net-scp-1.1.2-1.el6cf.noarch.rpm ruby193-rubygem-net-sftp-2.0.5-7.el6cf.noarch.rpm ruby193-rubygem-net-ssh-2.9.1-1.el6cf.noarch.rpm ruby193-rubygem-netrc-0.7.7-3.el6cf.noarch.rpm ruby193-rubygem-nori-2.1.0-1.el6cf.noarch.rpm ruby193-rubygem-open4-1.3.0-4.el6cf.noarch.rpm ruby193-rubygem-outfielding-jqplot-rails-1.0.8-1.el6cf.noarch.rpm ruby193-rubygem-ovirt_metrics-1.0.1-1.el6cf.noarch.rpm ruby193-rubygem-parallel-0.5.21-1.el6cf.noarch.rpm ruby193-rubygem-pdf-writer-1.1.8-1.el6cf.noarch.rpm ruby193-rubygem-princely-1.2.6-1.el6cf.noarch.rpm ruby193-rubygem-progressbar-0.11.0-2.el6cf.noarch.rpm ruby193-rubygem-prototype-rails-3.2.1-1.el6cf.noarch.rpm ruby193-rubygem-rack-1.4.5-3.el6cf.noarch.rpm ruby193-rubygem-rack-test-0.6.2-1.el6cf.noarch.rpm ruby193-rubygem-rails-3.2.17-1.el6cf.noarch.rpm ruby193-rubygem-rails_best_practices-1.13.8-1.el6cf.noarch.rpm ruby193-rubygem-railties-3.2.17-1.el6cf.noarch.rpm ruby193-rubygem-rake-10.1.0-1.el6cf.noarch.rpm ruby193-rubygem-rake-compiler-0.8.3-2.el6cf.noarch.rpm ruby193-rubygem-rbovirt-0.0.17-3.el6cf.noarch.rpm ruby193-rubygem-rbvmomi-1.2.3-4.el6cf.noarch.rpm ruby193-rubygem-rdoc-3.12.2-4.el6cf.noarch.rpm ruby193-rubygem-reek-1.3.1-1.el6cf.noarch.rpm ruby193-rubygem-rest-client-1.6.7-5.el6cf.noarch.rpm ruby193-rubygem-roodi-2.2.0-1.el6cf.noarch.rpm ruby193-rubygem-rspec-2.12.0-1.el6cf.noarch.rpm ruby193-rubygem-rspec-core-2.12.2-1.el6cf.noarch.rpm ruby193-rubygem-rspec-expectations-2.12.1-1.el6cf.noarch.rpm ruby193-rubygem-rspec-fire-1.3.0-1.el6cf.noarch.rpm ruby193-rubygem-rspec-mocks-2.12.1-1.el6cf.noarch.rpm ruby193-rubygem-rspec-rails-2.12.1-1.el6cf.noarch.rpm ruby193-rubygem-ruby-graphviz-1.0.9-1.el6cf.noarch.rpm ruby193-rubygem-ruby-plsql-0.4.1-1.el6cf.noarch.rpm ruby193-rubygem-ruby-progressbar-0.0.10-1.el6cf.noarch.rpm ruby193-rubygem-ruby2ruby-2.0.6-1.el6cf.noarch.rpm ruby193-rubygem-ruby_parser-3.1.3-2.el6cf.noarch.rpm ruby193-rubygem-rubyforge-2.0.4-3.el6cf.noarch.rpm ruby193-rubygem-rubyntlm-0.4.0-1.el6cf.noarch.rpm ruby193-rubygem-rubyrep-1.2.0-6.el6cf.noarch.rpm ruby193-rubygem-rubywbem-0.1.0-2.el6cf.noarch.rpm ruby193-rubygem-rubyzip-0.9.5-1.el6cf.noarch.rpm ruby193-rubygem-rufus-lru-1.0.5-1.el6cf.noarch.rpm ruby193-rubygem-rufus-scheduler-2.0.19-2.el6cf.noarch.rpm ruby193-rubygem-ruport-1.7.0-2.el6cf.noarch.rpm ruby193-rubygem-savon-2.2.0-1.el6cf.noarch.rpm ruby193-rubygem-secure_headers-1.1.1-1.el6cf.noarch.rpm ruby193-rubygem-sexp_processor-4.2.1-1.el6cf.noarch.rpm ruby193-rubygem-shindo-0.3.4-7.el6cf.noarch.rpm ruby193-rubygem-shoulda-matchers-1.0.0-1.el6cf.noarch.rpm ruby193-rubygem-simple-rss-1.2.3-8.el6cf.noarch.rpm ruby193-rubygem-simplecov-0.7.1-6.el6cf.noarch.rpm ruby193-rubygem-simplecov-html-0.7.1-2.el6cf.noarch.rpm ruby193-rubygem-simplecov-rcov-0.2.3-1.el6cf.noarch.rpm ruby193-rubygem-simplecov-rcov-text-0.0.2-1.el6cf.noarch.rpm ruby193-rubygem-slim-1.3.9-1.el6cf.noarch.rpm ruby193-rubygem-snmp-1.1.0-6.el6cf.noarch.rpm ruby193-rubygem-soap4r-1.6.0-2.el6cf.noarch.rpm ruby193-rubygem-state_machine-1.1.2-8.el6cf.noarch.rpm ruby193-rubygem-syntax-1.0.0-8.el6cf.noarch.rpm ruby193-rubygem-temple-0.6.5-1.el6cf.noarch.rpm ruby193-rubygem-terminal-table-1.4.5-1.el6cf.noarch.rpm ruby193-rubygem-test-spec-0.10.0-7.el6cf.noarch.rpm ruby193-rubygem-test-unit-2.4.5-5.el6cf.noarch.rpm ruby193-rubygem-timecop-0.5.3-1.el6cf.noarch.rpm ruby193-rubygem-transaction-simple-1.4.0-5.el6cf.noarch.rpm ruby193-rubygem-trollop-1.16.2-2.el6cf.noarch.rpm ruby193-rubygem-uglifier-2.4.0-1.el6cf.noarch.rpm ruby193-rubygem-uniform_notifier-1.2.0-1.el6cf.noarch.rpm ruby193-rubygem-uuidtools-2.1.3-3.el6cf.noarch.rpm ruby193-rubygem-vcr-2.4.0-1.el6cf.noarch.rpm ruby193-rubygem-wasabi-3.1.0-1.el6cf.noarch.rpm ruby193-rubygem-webmock-1.11.0-1.el6cf.noarch.rpm ruby193-rubygem-websocket-1.0.7-1.el6cf.noarch.rpm ruby193-rubygem-winrm-1.1.3-1.el6cf.noarch.rpm ruby193-rubygem-winrm-1.1.3-2.el6cf.noarch.rpm ruby193-rubygem-winrm-1.1.3-4.el6cf.noarch.rpm ruby193-rubygem-xml-simple-1.0.12-1.el6cf.noarch.rpm ruby193-rubygem-xpath-2.0.0-1.el6cf.noarch.rpm ruby193-rubygem-ziya-2.3.0-2.el6cf.noarch.rpm selinux-policy-3.7.19-244.el6.noarch.rpm selinux-policy-targeted-3.7.19-244.el6.noarch.rpm sneakernet_ca-0.1-2.el6cf.noarch.rpm x86_64: certmonger-0.75.13-1.el6.x86_64.rpm certmonger-debuginfo-0.75.13-1.el6.x86_64.rpm cfme-5.2.1.8-1.el6cf.x86_64.rpm cfme-5.2.2.1-1.el6cf.x86_64.rpm cfme-5.3.0.0-1.el6cf.alpha2.x86_64.rpm cfme-5.3.0.0-10.el6cf.alpha5.x86_64.rpm cfme-5.3.0.0-13.el6cf.alpha6.x86_64.rpm cfme-5.3.0.0-2.el6cf.alpha2.x86_64.rpm cfme-5.3.0.0-3.el6cf.alpha2.x86_64.rpm cfme-5.3.0.0-4.el6cf.alpha2.x86_64.rpm cfme-5.3.0.0-5.el6cf.alpha3.x86_64.rpm cfme-5.3.0.0-6.el6cf.alpha3.x86_64.rpm cfme-5.3.0.0-7.el6cf.alpha4.x86_64.rpm cfme-5.3.0.0-9.el6cf.alpha5.x86_64.rpm cfme-5.3.0.15-1.el6cf.x86_64.rpm cfme-appliance-5.2.1.8-1.el6cf.x86_64.rpm cfme-appliance-5.2.2.1-1.el6cf.x86_64.rpm cfme-appliance-5.3.0.0-1.el6cf.alpha2.x86_64.rpm cfme-appliance-5.3.0.0-10.el6cf.alpha5.x86_64.rpm cfme-appliance-5.3.0.0-13.el6cf.alpha6.x86_64.rpm cfme-appliance-5.3.0.0-2.el6cf.alpha2.x86_64.rpm cfme-appliance-5.3.0.0-3.el6cf.alpha2.x86_64.rpm cfme-appliance-5.3.0.0-4.el6cf.alpha2.x86_64.rpm cfme-appliance-5.3.0.0-5.el6cf.alpha3.x86_64.rpm cfme-appliance-5.3.0.0-6.el6cf.alpha3.x86_64.rpm cfme-appliance-5.3.0.0-7.el6cf.alpha4.x86_64.rpm cfme-appliance-5.3.0.0-9.el6cf.alpha5.x86_64.rpm cfme-appliance-5.3.0.15-1.el6cf.x86_64.rpm cfme-debuginfo-5.2.1.8-1.el6cf.x86_64.rpm cfme-debuginfo-5.2.2.1-1.el6cf.x86_64.rpm cfme-debuginfo-5.3.0.0-1.el6cf.alpha2.x86_64.rpm cfme-debuginfo-5.3.0.0-10.el6cf.alpha5.x86_64.rpm cfme-debuginfo-5.3.0.0-13.el6cf.alpha6.x86_64.rpm cfme-debuginfo-5.3.0.0-2.el6cf.alpha2.x86_64.rpm cfme-debuginfo-5.3.0.0-3.el6cf.alpha2.x86_64.rpm cfme-debuginfo-5.3.0.0-4.el6cf.alpha2.x86_64.rpm cfme-debuginfo-5.3.0.0-5.el6cf.alpha3.x86_64.rpm cfme-debuginfo-5.3.0.0-6.el6cf.alpha3.x86_64.rpm cfme-debuginfo-5.3.0.0-7.el6cf.alpha4.x86_64.rpm cfme-debuginfo-5.3.0.0-9.el6cf.alpha5.x86_64.rpm cfme-debuginfo-5.3.0.15-1.el6cf.x86_64.rpm cfme-lib-5.2.1.8-1.el6cf.x86_64.rpm cfme-lib-5.2.2.1-1.el6cf.x86_64.rpm cfme-lib-5.3.0.0-1.el6cf.alpha2.x86_64.rpm cfme-lib-5.3.0.0-10.el6cf.alpha5.x86_64.rpm cfme-lib-5.3.0.0-13.el6cf.alpha6.x86_64.rpm cfme-lib-5.3.0.0-2.el6cf.alpha2.x86_64.rpm cfme-lib-5.3.0.0-3.el6cf.alpha2.x86_64.rpm cfme-lib-5.3.0.0-4.el6cf.alpha2.x86_64.rpm cfme-lib-5.3.0.0-5.el6cf.alpha3.x86_64.rpm cfme-lib-5.3.0.0-6.el6cf.alpha3.x86_64.rpm cfme-lib-5.3.0.0-7.el6cf.alpha4.x86_64.rpm cfme-lib-5.3.0.0-9.el6cf.alpha5.x86_64.rpm cfme-lib-5.3.0.15-1.el6cf.x86_64.rpm cfme-vnc-plugin-1.0.0-2.el6cf.x86_64.rpm cfme-vnc-plugin-debuginfo-1.0.0-2.el6cf.x86_64.rpm libdnet-1.12-11.el6cf.x86_64.rpm libdnet-debuginfo-1.12-11.el6cf.x86_64.rpm libdnet-devel-1.12-11.el6cf.x86_64.rpm libdnet-progs-1.12-11.el6cf.x86_64.rpm libipa_hbac-1.11.6-3.el6.x86_64.rpm libipa_hbac-devel-1.11.6-3.el6.x86_64.rpm libipa_hbac-python-1.11.6-3.el6.x86_64.rpm libsss_idmap-1.11.6-3.el6.x86_64.rpm libsss_idmap-devel-1.11.6-3.el6.x86_64.rpm libsss_nss_idmap-1.11.6-3.el6.x86_64.rpm libsss_nss_idmap-devel-1.11.6-3.el6.x86_64.rpm libsss_nss_idmap-python-1.11.6-3.el6.x86_64.rpm lshw-B.02.16-4.el6cf.x86_64.rpm lshw-debuginfo-B.02.16-4.el6cf.x86_64.rpm lshw-gui-B.02.16-4.el6cf.x86_64.rpm mingw32-cfme-host-5.2.1.8-1.el6cf.x86_64.rpm mingw32-cfme-host-5.2.2.1-1.el6cf.x86_64.rpm mingw32-cfme-host-5.3.0.0-1.el6cf.alpha2.x86_64.rpm mingw32-cfme-host-5.3.0.0-10.el6cf.alpha5.x86_64.rpm mingw32-cfme-host-5.3.0.0-13.el6cf.alpha6.x86_64.rpm mingw32-cfme-host-5.3.0.0-2.el6cf.alpha2.x86_64.rpm mingw32-cfme-host-5.3.0.0-3.el6cf.alpha2.x86_64.rpm mingw32-cfme-host-5.3.0.0-4.el6cf.alpha2.x86_64.rpm mingw32-cfme-host-5.3.0.0-5.el6cf.alpha3.x86_64.rpm mingw32-cfme-host-5.3.0.0-6.el6cf.alpha3.x86_64.rpm mingw32-cfme-host-5.3.0.0-7.el6cf.alpha4.x86_64.rpm mingw32-cfme-host-5.3.0.0-9.el6cf.alpha5.x86_64.rpm mingw32-cfme-host-5.3.0.15-1.el6cf.x86_64.rpm mod_authnz_pam-0.9.2-1.el6.x86_64.rpm mod_authnz_pam-debuginfo-0.9.2-1.el6.x86_64.rpm mod_intercept_form_submit-0.9.7-1.el6.x86_64.rpm mod_intercept_form_submit-debuginfo-0.9.7-1.el6.x86_64.rpm mod_lookup_identity-0.9.2-1.el6.x86_64.rpm mod_lookup_identity-debuginfo-0.9.2-1.el6.x86_64.rpm netapp-manageability-sdk-4.0P1-3.el6cf.x86_64.rpm netapp-manageability-sdk-devel-4.0P1-3.el6cf.x86_64.rpm open-vm-tools-9.2.3-5.el6cf.x86_64.rpm open-vm-tools-debuginfo-9.2.3-5.el6cf.x86_64.rpm open-vm-tools-desktop-9.2.3-5.el6cf.x86_64.rpm open-vm-tools-devel-9.2.3-5.el6cf.x86_64.rpm prince-9.0r2-4.el6cf.x86_64.rpm pyliblzma-0.5.3-7.el6cf.x86_64.rpm pyliblzma-debuginfo-0.5.3-7.el6cf.x86_64.rpm ruby193-rubygem-eventmachine-1.0.0-1.el6cf.x86_64.rpm ruby193-rubygem-eventmachine-debuginfo-1.0.0-1.el6cf.x86_64.rpm ruby193-rubygem-ffi-1.9.3-1.el6cf.x86_64.rpm ruby193-rubygem-ffi-debuginfo-1.9.3-1.el6cf.x86_64.rpm ruby193-rubygem-io-extra-1.2.6-1.el6cf.x86_64.rpm ruby193-rubygem-io-extra-debuginfo-1.2.6-1.el6cf.x86_64.rpm ruby193-rubygem-json-1.8.0-3.el6cf.x86_64.rpm ruby193-rubygem-json-debuginfo-1.8.0-3.el6cf.x86_64.rpm ruby193-rubygem-libxml-ruby-2.2.2-1.el6cf.x86_64.rpm ruby193-rubygem-libxml-ruby-debuginfo-2.2.2-1.el6cf.x86_64.rpm ruby193-rubygem-nokogiri-1.5.6-3.el6cf.x86_64.rpm ruby193-rubygem-nokogiri-debuginfo-1.5.6-3.el6cf.x86_64.rpm ruby193-rubygem-pg-0.12.2-5.el6cf.x86_64.rpm ruby193-rubygem-pg-debuginfo-0.12.2-5.el6cf.x86_64.rpm ruby193-rubygem-qpid_messaging-0.20.2-2.el6cf.x86_64.rpm ruby193-rubygem-qpid_messaging-debuginfo-0.20.2-2.el6cf.x86_64.rpm ruby193-rubygem-ruby-prof-0.13.0-1.el6cf.x86_64.rpm ruby193-rubygem-ruby-prof-debuginfo-0.13.0-1.el6cf.x86_64.rpm ruby193-rubygem-selenium-webdriver-2.32.1-2.el6cf.x86_64.rpm ruby193-rubygem-selenium-webdriver-debuginfo-2.32.1-2.el6cf.x86_64.rpm ruby193-rubygem-thin-1.3.1-5.el6cf.x86_64.rpm ruby193-rubygem-thin-debuginfo-1.3.1-5.el6cf.x86_64.rpm sssd-1.11.6-3.el6.x86_64.rpm sssd-ad-1.11.6-3.el6.x86_64.rpm sssd-client-1.11.6-3.el6.x86_64.rpm sssd-common-1.11.6-3.el6.x86_64.rpm sssd-common-pac-1.11.6-3.el6.x86_64.rpm sssd-dbus-1.11.6-3.el6.x86_64.rpm sssd-debuginfo-1.11.6-3.el6.x86_64.rpm sssd-ipa-1.11.6-3.el6.x86_64.rpm sssd-krb5-1.11.6-3.el6.x86_64.rpm sssd-krb5-common-1.11.6-3.el6.x86_64.rpm sssd-ldap-1.11.6-3.el6.x86_64.rpm sssd-proxy-1.11.6-3.el6.x86_64.rpm sssd-tools-1.11.6-3.el6.x86_64.rpm These packages are GPG signed by Red Hat for security. Our key and details on how to verify the signature are available from https://access.redhat.com/security/team/key/#package 7. References: https://www.redhat.com/security/data/cve/CVE-2014-0140.html https://www.redhat.com/security/data/cve/CVE-2014-3642.html https://access.redhat.com/security/updates/classification/#moderate https://access.redhat.com/documentation/en-US/CloudForms/3.1/html/Management... https://access.redhat.com/documentation/en-US/CloudForms/3.1/html/Management... 8. Contact: The Red Hat security contact is <[email protected]>. More contact details at https://access.redhat.com/security/team/contact/ Copyright 2014 Red Hat, Inc. -----BEGIN PGP SIGNATURE----- Version: GnuPG v1 iD8DBQFULaYzXlSAg2UNWIIRAn+RAKCdvNwsjNzIlKu40AzLlpw4bXZZDgCgg2Ss iCNZ/CM91CW4wiQ4IQjkzD4= =wP86 -----END PGP SIGNATURE----- -- RHSA-announce mailing list [email protected] https://www.redhat.com/mailman/listinfo/rhsa-announce
participants (1)
bugzilla@redhat.com
