One thing that you can do (not sure if would be helpful in this case) is filter a Darshan log file down so that it only includes instrumentation data for a single file, and then run darshan-job-summary.pl on just that one file view. If you wanted to try that, you can do the following: $ darshan-parser --file-list loring_oscillator_id1336628_3-14-37278-8825292184016672560_1.darshan |head -n 75 # I'm just picking a file at random from the output, but this example is for # /global/cscratch1/sd/loring/sensei/fpp/10k/PosthocIO_5.vtmb # so I'm using it's corresponding hash value. The following command will write a new darshan log file that strips # away everything except for that one file: $ darshan-convert --file 13503923528039498363 loring_oscillator_id1336628_3-14-37278-8825292184016672560_1.darshan onefile.darshan $ darshan-job-summary.pl onefile.darshan The resulting pdf is generated instantaneously and is easy to open, but it doesn't tell you anything about the I/O at all except what happened to that one file. It might be helpful for some cases, though. You can also use the following to get a text dump of the cumulative statistics across all files (which also runs pretty quickly): darshan-parser --total loring_oscillator_id1336628_3-14-37278-8825292184016672560_1.darshan Unfortunately that output is presented in text format instead of producing another darshan log that could then be visualized with darshan-job-summary.pl, but maybe that is something we could consider in a future version. thanks, -Phil On 03/15/2016 11:18 AM, Burlen Loring wrote:
I let darshan job summary run all night, still going but no indication of progress.
This is my first experience with darshan, let me ask a naive question: is it possible to extract time series for a single process? write bandwidth over time for instance? and time for file open (or close) vs time?
Thanks for all your help Burlen
On 03/14/2016 09:53 PM, Burlen Loring wrote:
Yes, you are correct, it's file per process on 6496 processes, and the simulation runs for 100 time steps, plus there are some header files and directories created (I think by rank 0). It doesn't seem like too extreme of a case to me. We will also run 50k cores for 100 time steps. It sounds like darshan can't analyze this type of i/o, but please let me know if you have any ideas!
On the size discrepancy. My fault. Darshan had the size correct. I was looking at the wrong output file, 200G is the size of the smaller run (812 procs). I apologize that I didn't notice that sooner!
On 03/14/2016 08:55 PM, Shane Snyder wrote:
Maybe the reason the job summary graphs are hanging might be due to the number of files the application is opening? It looks like there are over 500,000 files (100 each for 6,496 processes). I haven't tried generating graphs for any logs that large myself, but that might be beyond what the graphing utilities can realistically handle. It takes forever for me to even parse the logs in text form.
As for the discrepancy in size, that may just be due to what the 'du' utility is actually reporting. 'du' measures the size of a given file based on the underlying file system block size. If the file is 1 byte, and the block size is 1 MiB, the file is reported as 1 MiB. Additionally, if you run 'du' on a directory containing numerous subdirectories (as you have, 100 subdirectories), it counts the sizes of the directories as well. Darshan will only report the I/O observed at the application level, so it does not account for file system blocks or directories. You can use 'du -b' to show the "actual" (i.e., not rounded up to block sizes) of individual files, though it still counts subdirectory sizes when determining the size of a given directory. If you do that, is it closer to what Darshan reports?
--Shane
On 03/14/2016 06:44 PM, Burlen Loring wrote:
sure, here is the link https://drive.google.com/open?id=0B3y5yyus32lveHljWkExal9TVmM
On 03/14/2016 03:56 PM, Shane Snyder wrote:
Hi Burlen,
Would you mind sharing your Darshan log with us? If you prefer, you can send it to me off-list, or if it contains sensitive information we can give you details on how to anonymize parts of it (e.g., file names, etc.).
I don't know for sure what the historical reason the "(may be incorrect)" caveat is given with the total bytes read and written. Someone correct me if I'm wrong, but I suspect that is to warn against the possibility that the code actually wrote/read more data than expected from the application's point of view? For instance, an I/O optimization called data sieving is possible at the MPI-IO layer which results in more data being read than expected from the application's point of view to improve performance. That shouldn't account for the drastic discrepancy you are seeing, though, so perhaps something else is up.
Thanks, --Shane
On 03/14/2016 05:29 PM, Burlen Loring wrote:
Hi, I'd like to analyze our runs with darshan. I'm able to get the log files, but so far no luck plotting them.
In the terminal after a while I see the following output, but then the program appears to hang. After ~20 min of no output and no evidence of it running in top, I killed it, and I didn't see any newly created files.
I'm also wondering about the total bytes report and warning that it may be wrong. it does indeed seem way off, du reports 1.6T, but darshan only reports ~200G.
Please, let me know what I did wrong! and if I should I be concerned about the numbers being so far off.
Thanks Burlen
$/work/apps/darshan/3.0.0-pre/bin/darshan-job-summary.pl loring_oscillator_id1336621_3-14-37256-5315836542621785504_1.darshan Slowest unique file time: 25.579892 Slowest shared file time: 0 Total bytes read and written by app (may be incorrect): 214218545937 Total absolute I/O time: 25.579892 **NOTE: above shared and unique file times calculated using MPI-IO timers if MPI-IO interface used on a given file, POSIX timers otherwise. _______________________________________________ Darshan-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
Shane, Phil, these commands are all working fine. Thanks One thing I'd like to do is separate the open from the write. the file-list-detailed option may give me what I need. are the values in the columns time stamps? so I can estimate write time by "<end_close> - <start_write>", and open time by "<start_write> - <start_open>", columns? I didn't see documentation for those columns and want to make sure I have it right before embarking on a wild goose chase. <start_open> <start_read> <start_write> <end_read> <end_write> <end_close> 0.770823 0.000000 1.602510 0.000000 1.607319 1.608949 Burlen On 03/15/2016 10:48 AM, Phil Carns wrote:
thanks, -Phil
--Shane
Hi Burlen,
Thanks, --Shane
Thanks Burlen
participants (2)
Burlen Loring -
Phil Carns
