It depends on where you look in MPICH. I analyzed memory consumption of MPI on Blue Gene/Q, which was based on MPICH (and is OSS, so you can read all of it). There was O(nproc) memory usage at every node, but I recall it the prefactor was ~82 bytes, which is pretty lean (~25 MB per rank at 3M ranks). I don't know if the O(nproc) data was in MPICH itself or the underlying layer (PAMI), or both, but it doesn't really matter from a user perspective. Some _networks_ might make it hard not to have O(nproc) eager buffers on every rank, and there are other "features" of network HW/SW that may require O(nproc) data. Obviously, since this sort of thing is not scalable, networks that historically had such properties have evolved to support more scalable designs. Some of the low-level issues are addressed in https://www.open-mpi.org/papers/ipdps-2006/ipdps-2006-openmpi-ib-scalability... . User buffers are a separate issue. MPI_Alltoall and MPI_Allgather acts on O(nproc) user storage. MPI_Allgatherv, MPI_Alltoallv and MPI_Alltoallw have O(nproc) input vectors. MPI experts often refer to the vector collectives as unscalable, but of course this may not matter in practice for many users. And in some of the cases where MPI_Alltoallv is used, one can replace with a carefully written loop over Send-Recv calls that does not require the user to allocate O(nproc) vectors specifically for MPI. There's a paper by Argonne+IBM that addresses this topic in more detail: http://www.mcs.anl.gov/~thakur/papers/mpi-million.pdf Jeff On Wed, Aug 24, 2016 at 10:28 AM, Dan Ibanez <[email protected]> wrote:
Hello,
This may be a silly question, but the reason I'm asking is to obtain a fairly definitive answer. Basically, does MPICH have data structures which are of size: 1) O(N) 2) O(N^2) Where N is the size of MPI_COMM_WORLD ? My initial guess would be no, because there exist machines (Mira) for which it is not possible to store N^2 bytes, and even N bytes becomes an issue. I understand there are MPI functions (MPI_alltoall) one can call that by definition will require at least O(N) memory, but supposing one does not use these, would the internal MPICH systems still have this memory complexity ?
Thank you for looking at this anyway
_______________________________________________ To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/devel
-- Jeff Hammond [email protected] http://jeffhammond.github.io/
participants (1)
Jeff Hammond
