Re: [mpich-devel] Issue with MPI_Error_string() for user-defined codes/clases
On 04/22/2014 04:04 AM, Lisandro Dalcin wrote:
The MPI-3 standard says (pp.354, lines 39-40):
""" If MPI_ERROR_STRING is called when no string has been set, it will return a empty string (all spaces in Fortran, "" in C). """
The following simple tests segfaults. A quick fix would be to return an empty string in MPIR_Err_get_dynerr_string() (file dynerrutil.c), e.g:
Now that I look at this a bit more closely, shouldn't user_code_msgs[] and user_class_msgs[] be initialized to "", not 0 ? That messes up some other assumptions of the errorcode handling code, though.. ==rob
diff --git a/src/mpi/errhan/dynerrutil.c b/src/mpi/errhan/dynerrutil.c index 943e8c3..fb40469 100644 --- a/src/mpi/errhan/dynerrutil.c +++ b/src/mpi/errhan/dynerrutil.c @@ -297,11 +297,13 @@ const char *MPIR_Err_get_dynerr_string( int code ) if (errcode) { if (errcode < first_free_code) { errstr = user_code_msgs[errcode]; + if (!errstr) errstr = ""; } } else { if (errclass < first_free_class) { errstr = user_class_msgs[errclass]; + if (!errstr) errstr = ""; } }
[dalcinl@kw2060 ~]$ cat error_string2.c #include <stdio.h> #include <mpi.h> int main(int argc, char *argv[]) { int errorclass; char errorstring[MPI_MAX_ERROR_STRING] = {64,0}; int slen; MPI_Init(&argc, &argv); MPI_Add_error_class(&errorclass); MPI_Error_string(errorclass, errorstring, &slen); printf("errorclass:%d errorstring:'%s' len:%d\n", errorclass, errorstring, slen); MPI_Finalize(); return 0; }
[dalcinl@kw2060 ~]$ mpicc error_string2.c [dalcinl@kw2060 ~]$ ./a.out Segmentation fault (core dumped)
[dalcinl@kw2060 ~]$ valgrind -q ./a.out ==14176== Invalid read of size 1 ==14176== at 0x4C6F5E7: MPIU_Strncpy (safestr.c:65) ==14176== by 0x4C61864: MPIR_Err_get_string (errutil.c:601) ==14176== by 0x4DA4DB4: PMPI_Error_string (error_string.c:80) ==14176== by 0x400888: main (in /home/dalcinl/Devel/BUGS-MPI/~/a.out) ==14176== Address 0x0 is not stack'd, malloc'd or (recently) free'd ==14176== ==14176== ==14176== Process terminating with default action of signal 11 (SIGSEGV) ==14176== Access not within mapped region at address 0x0 ==14176== at 0x4C6F5E7: MPIU_Strncpy (safestr.c:65) ==14176== by 0x4C61864: MPIR_Err_get_string (errutil.c:601) ==14176== by 0x4DA4DB4: PMPI_Error_string (error_string.c:80) ==14176== by 0x400888: main (in /home/dalcinl/Devel/BUGS-MPI/~/a.out) ==14176== If you believe this happened as a result of a stack ==14176== overflow in your program's main thread (unlikely but ==14176== possible), you can try to increase the size of the ==14176== main thread stack using the --main-stacksize= flag. ==14176== The main thread stack size used in this run was 8720384. Segmentation fault (core dumped)
-- Rob Latham Mathematics and Computer Science Division Argonne National Lab, IL USA
participants (1)
Rob Latham
