Re: [mpich-devel] Mac autogen.sh fails
Here is why I have: $ for i in libtool glibtool libtoolize glibtoolize ; do which $i ; done /usr/bin/libtool /usr/local/bin/glibtool /usr/local/bin/glibtoolize $ /usr/bin/libtool -V Apple Inc. version cctools-900 $ /usr/local/bin/glibtool --version glibtool (GNU libtool) 2.4.6 Written by Gordon Matzigkeit, 1996 Copyright (C) 2014 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. On Fri, Dec 8, 2017 at 1:30 PM, Kenneth Raffenetti <[email protected]> wrote:
Does 'which libtoolize' or 'which glibtoolize' return a valid program? It looks like we could do a better job or returning an error when they aren't even found. At the moment these errors go unnoticed:
usage: dirname path
Ken
On 12/08/2017 02:00 PM, Jeff Hammond wrote:
merely reverting the change on the most pertinent lines doesn't solve the problem. i'm not sure what the fix is.
jrhammon-mac01:git jrhammon$ git diff diff --git a/autogen.sh b/autogen.sh index 4036565be..eda353652 100755 --- a/autogen.sh +++ b/autogen.sh @@ -304,7 +304,12 @@ if [ -n "$autotoolsdir" ] ; then automake=$autotoolsdir/automake autom4te=$autotoolsdir/autom4te aclocal=$autotoolsdir/aclocal - libtoolize=$autotoolsdir/libtoolize + #libtoolize=$autotoolsdir/libtoolize + if [ -x "$autotoolsdir/glibtoolize" ] ; then + libtoolize=$autotoolsdir/glibtoolize + else + libtoolize=$autotoolsdir/libtoolize + fi AUTOCONF=$autoconf AUTOHEADER=$autoheader @@ -332,7 +337,12 @@ else autom4te=${AUTOM4TE:-autom4te} automake=${AUTOMAKE:-automake} aclocal=${ACLOCAL:-aclocal} - libtoolize=${LIBTOOLIZE:-libtoolize} + #libtoolize=${LIBTOOLIZE:-libtoolize} + if [ -x "$autotoolsdir/glibtoolize" ] ; then + libtoolize=$autotoolsdir/glibtoolize + else + libtoolize=$autotoolsdir/libtoolize + fi fi ProgHomeDir $autoconf autoconfdir jrhammon-mac01:git jrhammon$ ./autogen.sh
#################################### ## Checking user environment ####################################
Verifying the location of autogen.sh... done usage: dirname path Checking if autotools are in the same location... no autoconf is in /usr/local automake is in /usr/local libtool is in / ===> WARNING: Autotools are in different locations. In rare occasion, ===> WARNING: resulting configure or makefile may fail in some unexpected ways. Checking if autoreconf accepts -I //share/aclocal... no Checking if autoreconf works after an additional /libtoolize step... no ===> ERROR: Since none of the autoreconf workaround works ===> ERROR: and autotools are not in the same directory, aborting... ===> ERROR: Updating autotools or putting all autotools in the same location ===> ERROR: may resolve the issue.
On Fri, Dec 8, 2017 at 11:54 AM, Kenneth Raffenetti <[email protected] <mailto:[email protected]>> wrote:
Hmm, I suppose we didn't run into this on our test systems since we always install those tools from scratch, and I'm still not a Mac guy so I didn't notice :). I'll put together a PR to revert it.
Ken
On 12/08/2017 09:27 AM, Bland, Wesley wrote:
I guess posting the link to our GitHub Enterprise instance doesn't help. Here's the correct link:
https://github.com/pmodels/mpich/commit/a512f954007fefa4b3b2 18848854481927422fc3 <https://github.com/pmodels/mpich/commit/a512f954007fefa4b3b 218848854481927422fc3>
On Dec 8, 2017, at 9:24 AM, Bland, Wesley <[email protected] <mailto:[email protected]>> wrote:
This would appear to be the culprit. Maybe Pavan/Ken can talk about why it was removed?
https://github.intel.com/csr/mpich-ofi/commit/a512f954007fef a4b3b218848854481927422fc3 <https://github.intel.com/csr/mpich-ofi/commit/a512f954007fe fa4b3b218848854481927422fc3>
On Dec 7, 2017, at 3:51 PM, Jeff Hammond <[email protected] <mailto:[email protected]>>
wrote:
autogen.sh is failing for me on Mac because Apple's libtool is not in the same place as Homebrew's autoconf/automake. I perused autogen.sh but didn't see an option to fix this.
I need to use Homebrew autotools for other projects and don't want to uninstall Xcode for obvious reasons. Is there a workaround besides hacking autogen.sh and hating myself? I'd like to cause it to glibtool instead.
If nothing else, autogen.sh incorrectly prints the location of libtool. It is in /usr/bin not /.
Jeff
jrhammon-mac01:git jrhammon$ which libtool /usr/bin/libtool jrhammon-mac01:git jrhammon$ which autoconf /usr/local/bin/autoconf jrhammon-mac01:git jrhammon$ which automake /usr/local/bin/automake jrhammon-mac01:git jrhammon$ which glibtool /usr/local/bin/glibtool
Verifying the location of autogen.sh... done usage: dirname path Checking if autotools are in the same location... no autoconf is in /usr/local automake is in /usr/local libtool is in / ===> WARNING: Autotools are in different locations. In rare occasion, ===> WARNING: resulting configure or makefile may fail in some unexpected ways. Checking if autoreconf accepts -I //share/aclocal... no Checking if autoreconf works after an additional libtoolize step... no ===> ERROR: Since none of the autoreconf workaround works ===> ERROR: and autotools are not in the same directory, aborting... ===> ERROR: Updating autotools or putting all autotools in the same location ===> ERROR: may resolve the issue.
-- Jeff Hammond [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> http://jeffhammond.github.io/ _______________________________________________ To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/devel <https://lists.mpich.org/mailman/listinfo/devel>
-- Jeff Hammond [email protected] <mailto:[email protected]> http://jeffhammond.github.io/
-- Jeff Hammond [email protected] http://jeffhammond.github.io/
participants (1)
Jeff Hammond
