Collective i/o failure
Question. If a rank fails a collective i/o, does it make sense for all ranks to fail that collective i/o? Or just the single rank? The problem with just a single rank failing is the remaining ranks likely get hung in some internal collective call. I'm wondering if having all ranks fail is *better*? In write_all in particular: http://git.mpich.org/mpich.git/blob/HEAD:/src/mpi/romio/mpi-io/write_all.c#l... 89 if (file_ptr_type == ADIO_EXPLICIT_OFFSET && offset < 0) 90 { 91 error_code = MPIO_Err_create_code(MPI_SUCCESS, MPIR_ERR_RECOVERABLE, 92 myname, __LINE__, MPI_ERR_ARG, 93 "**iobadoffset", 0); 94 error_code = MPIO_Err_return_file(adio_fh, error_code); 95 goto fn_exit; 96 } 97 /* --END ERROR HANDLING-- */ We *could* allreduce the offset and fail all ranks if any rank has a negative offset. Not sure that's the right answer. What happened was a single rank failed, the remaining ranks entered a (hardware-based) allreduce. The failing rank happened to enter an application (hardware-based) allreduce and you get a hardware detected failure that no app developer is going to even try to decode and debug. So I get the call. Without the hardware involved, it just hangs on two independent allreduces. They might have figured that one out by looking at where the (hundreds/thousands of) stacks were hung. Of course, they didn't actually check the return from the write_all :) Although I'm not sure how MPIR_ERR_RECOVERABLE it is at that point. Just wondering if there's something I can fix here in addition to the application. Bob Cernohous: (T/L 553) 507-253-6093 [email protected] IBM Rochester, Building 030-2(C335), Department 61L 3605 Hwy 52 North, Rochester, MN 55901-7829
Chaos reigns within. Reflect, repent, and reboot. Order shall return.
participants (1)
Bob Cernohous
