Re: [mpich-devel] Suboptimal MPI_Allreduce() for intercommunicators
It was probably done that way to avoid the need for memory allocation, but can you add a ticket in Trac and we will look at it. (For example, on one side of the intercommunicator sendbuf=1 byte, recvbuf=1 gigabyte; on the other side, sendbuf=1 gigabyte, recvbuf=1 byte) Rajeev On Apr 30, 2014, at 4:44 AM, Lisandro Dalcin <[email protected]> wrote:
The implementation of Allreduce for intercommunicator (MPIR_Allreduce_inter in src/mpi/coll/allreduce.c) uses more or less the following algorithm (this is Python code I'm using to test this issue)
def allreduce_inter_mpich(obj, op, comm, tag, localcomm, low_group): zero = 0 if comm.rank == 0: root = MPI.ROOT else: root = MPI.PROC_NULL if low_group: ignore = reduce_inter(obj, op, zero, comm, tag, localcomm) result = reduce_inter(obj, op, root, comm, tag, localcomm) else: result = reduce_inter(obj, op, root, comm, tag, localcomm) ignore = reduce_inter(obj, op, zero, comm, tag, localcomm) return localcomm.bcast(result, 0)
However, while the broadcasts at each group overlap, the calls to reduce_inter() introduce serialization. A much better implementation would be:
def allreduce_inter_dalcinl(obj, op, comm, tag, localcomm): result = reduce_binomial(obj, op, 0, localcomm, tag) if comm.rank == 0: result = comm.sendrecv(result, 0, tag, None, 0, tag) return localcomm.bcast(result, 0)
i.e, perform (overlaped) reductions in the local groups, exchange results between local and remote rank 0, and (overlaped) broadcast in the local groups.
I'm ataching a test Python script (I do not expect you to run it :-), but perhaps you want to see the code). I'm defining a reduce operation that artificially sleeps 1 second. Running this code in 8 cores in my desktop clearly shows the issue with the MPICH implementation:
$ mpiexec -n 8 python test-reduce.py [mpich] time: min=4.003491e+00 max=4.003569e+00 [dalcinl] time: min=2.002367e+00 max=2.002456e+00
What do you think? Am I right? Or perhaps I'm missing something obvious?
-- Lisandro Dalcin --------------- CIMEC (UNL/CONICET) Predio CONICET-Santa Fe Colectora RN 168 Km 472, Paraje El Pozo 3000 Santa Fe, Argentina Tel: +54-342-4511594 (ext 1016) Tel/Fax: +54-342-4511169 <test-allreduce.py>_______________________________________________ To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/devel
participants (1)
Rajeev Thakur
