Re: [mpich-devel] progress in flushall
Jeff, If there are no local RMA operations, Win_flush will essentially be a no-op, so no it’ll not make any progress. — Pavan On Apr 29, 2014, at 12:18 PM, Jeff Hammond <[email protected]> wrote:
win_flush_all mentions poking the progress engine for async progress but it won't actually do this if a given process has not initiated any RMA operations. This defeats the purpose of using win_flush_all to drive progress locally.
Maybe I am misreading the code, but I'd sleep better at night if I was absolutely certain that win_flush_all hit the progress at least once.
Jeff
(the following excerpts are easily found in src/mpid/ch3/src/ch3u_rma_sync.c)
int MPIDI_Win_flush_all(MPID_Win *win_ptr) { int mpi_errno = MPI_SUCCESS; int i; MPIDI_STATE_DECL(MPIDI_STATE_MPIDI_WIN_FLUSH_ALL);
MPIDI_RMA_FUNC_ENTER(MPIDI_STATE_MPIDI_WIN_FLUSH_ALL);
MPIU_ERR_CHKANDJUMP(win_ptr->epoch_state != MPIDI_EPOCH_LOCK && win_ptr->epoch_state != MPIDI_EPOCH_LOCK_ALL, mpi_errno, MPI_ERR_RMA_SYNC, "**rmasync");
/* FIXME: Performance -- we should not process the ops separately. * Ideally, we should be able to use the same infrastructure that's used by * active target to complete all operations. */
/* Note: Local RMA calls don't poke the progress engine. This routine * should poke the progress engine when the local target is flushed to help * make asynchronous progress. Currently this is handled by Win_flush(). */ for (i = 0; i < MPIR_Comm_size(win_ptr->comm_ptr); i++) { if (MPIDI_CH3I_RMA_Ops_head(&win_ptr->targets[i].rma_ops_list) == NULL) continue; if (win_ptr->targets[i].remote_lock_state != MPIDI_CH3_WIN_LOCK_NONE) { mpi_errno = win_ptr->RMAFns.Win_flush(i, win_ptr); if (mpi_errno != MPI_SUCCESS) { MPIU_ERR_POP(mpi_errno); } } }
int MPIDI_Win_flush(int rank, MPID_Win *win_ptr) { int mpi_errno = MPI_SUCCESS; int wait_for_rma_done_pkt = 0; MPIDI_RMA_Op_t *rma_op; MPIDI_STATE_DECL(MPID_STATE_MPIDI_WIN_FLUSH);
MPIDI_RMA_FUNC_ENTER(MPID_STATE_MPIDI_WIN_FLUSH);
/* Check if win_lock was called */ MPIU_ERR_CHKANDJUMP(win_ptr->targets[rank].remote_lock_state == MPIDI_CH3_WIN_LOCK_NONE, mpi_errno, MPI_ERR_RMA_SYNC, "**rmasync");
/* Local flush: ops are performed immediately on the local process */ if (rank == win_ptr->comm_ptr->rank) { MPIU_Assert(win_ptr->targets[rank].remote_lock_state == MPIDI_CH3_WIN_LOCK_GRANTED); MPIU_Assert(MPIDI_CH3I_RMA_Ops_isempty(&win_ptr->targets[rank].rma_ops_list));
/* If flush is used as a part of polling for incoming data, we can * deadlock, since local RMA calls never poke the progress engine. So, * make extra progress here to avoid this problem. */ mpi_errno = MPIDI_CH3_Progress_poke(); if (mpi_errno) MPIU_ERR_POP(mpi_errno); goto fn_exit; }
/* NOTE: All flush and req-based operations are currently implemented in terms of MPIDI_Win_flush. When this changes, those operations will also need to insert this read/write memory fence for shared memory windows. */
if (win_ptr->shm_allocated == TRUE) { OPA_read_write_barrier(); }
rma_op = MPIDI_CH3I_RMA_Ops_head(&win_ptr->targets[rank].rma_ops_list);
/* If there is no activity at this target (e.g. lock-all was called, but we * haven't communicated with this target), don't do anything. */ if (win_ptr->targets[rank].remote_lock_state == MPIDI_CH3_WIN_LOCK_CALLED && rma_op == NULL) { goto fn_exit; }
-- Jeff Hammond [email protected] _______________________________________________ To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/devel
participants (1)
Balaji, Pavan
