On 03/15/2016 08:14 PM, Dominic Kedelty wrote:
Hello,
I am wondering if I can get help with an error I am receiving when using MPI IO. I was referred here by openmpi saying that this was a possible ROMIO bug. I am receiving the following error
Error in ADIOI_Calc_aggregator(): rank_index(40) >= fd->hints->cb_nodes (40) fd_size=213909504 off=8617247540 Error in ADIOI_Calc_aggregator(): rank_index(40) >= fd->hints->cb_nodes (40) fd_size=213909504 off=8617247540 application called MPI_Abort(MPI_COMM_WORLD, 1) - process 157 application called MPI_Abort(MPI_COMM_WORLD, 1) - process 477
This is happening I BELIEVE when the code I am using is writing an ensight gold format file for a large problem that I am running on 640 cores. I can provide more information if need be. I am using openmpi 1.8.7, but I have tried mvapich2 version 1.9 with the same error code, which are the two current mpi files on the cluster that I am using.
ROMIO selects a subset of processes called I/O aggregators. These aggregators will carry out I/O. Generally this works great: fewer clients banging on the file system, average I/O request size increases. In this assertion, something in ROMIO selected the 41st i/o aggregator, but only 40 I/O aggreagators were available. Since this happens pretty far down inside ROMIO, it's going to be a lot easier to debug if you can provide me a reproducer or a reproducing recipe . Since EnSight Gold is a commercial CFD package, it might be difficult for me to know what it's trying to do. Do other applications using MPI-IO work on your system? thanks ==rob
_______________________________________________ To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/devel
participants (1)
Rob Latham
