On Tue, Jun 17, 2014 at 3:51 AM, Lisandro Dalcin <[email protected]> wrote:
On 17 June 2014 01:55, Dave Goodell (dgoodell) <[email protected]> wrote:
This OMPI bug may be of note to the MPICH community: https://svn.open-mpi.org/trac/ompi/ticket/4721
From a user point of view, I do not like that behaviour. I agree that the MPI implementation is free to allocate as much space it is convenient, but the size it reports back after a query is a different story. Does the MPI standard requires that the result query of the query is the exact allocated size? If not, I see more convenient to return the requested-at-allocation- time size the the allocated one. What's the use case of returning the exact allocated size? After all, I guess users cannot rely on "extra space" being available at the end of the buffer.
http://www.mpi-forum.org/docs/mpi-3.0/mpi30-report.pdf page 410 explicitly permits padding in the case of alloc_shared_noncontig=True. The user can use exactly the amount in the window, which is either the exact amount they requested or a slightly larger amount due to padding. What is wrong with that? I think it is a very good idea to let users know how much memory is being allocated, because this might cause them to improve their usage of MPI. For example, someone might think its a good idea to have a C++ flag object in shared memory and allocate an 8-byte shared-memory window in each object constructor. They might think alloc_shared_noncontig=True is an optimization, but the OS could decide to round up to the page boundary. Thus, the users lightweight flag object is allocating 4096+n bytes instead of 8+n, where n is the number of bytes in the object but not the window. Exposing this tidbit to the user might inspire them to allocate a pool for shared-memory flag state that doesn't waste memory. I suppose you could complain about the implementation rounding up to page boundaries, but this might be required by the OS, in which case you'll have to complain to someone like Linus about it :-D The MPI standard occasionally exposes low-level information to users that is not necessarily helpful. It is quite straightforward to implement a library on top of MPI that hides this information if it is considered detrimental to user experience. Jeff -- Jeff Hammond [email protected] http://jeffhammond.github.io/
participants (1)
Jeff Hammond
