Re: [mpich-devel] Issue with MPI_Error_string() for user-defined codes/clases
On 23 April 2014 00:55, Rob Latham <[email protected]> wrote:
On 04/22/2014 04:04 AM, Lisandro Dalcin wrote:
The following simple tests segfaults. A quick fix would be to return an empty string in MPIR_Err_get_dynerr_string() (file dynerrutil.c),
I don't muck around in this code very often, so after thinking about it for a bit, and coming up with another way to do it, I opened a ticket so i could get a second (third, I guess) opinion:
IMHO your patch complicates things too much, I'm still in support of this slightly refined version that removes the usage of empty string constants (Rob, could you upload this patch to the ticket?): $ git diff diff --git a/src/mpi/errhan/dynerrutil.c b/src/mpi/errhan/dynerrutil.c index 943e8c3..2e3bb27 100644 --- a/src/mpi/errhan/dynerrutil.c +++ b/src/mpi/errhan/dynerrutil.c @@ -48,6 +48,7 @@ static const char *(user_class_msgs[ERROR_MAX_NCLASS]) = { 0 }; static const char *(user_code_msgs[ERROR_MAX_NCODE]) = { 0 }; static int first_free_class = 0; static int first_free_code = 1; /* code 0 is reserved */ +static const char empty_error_string[1] = { 0 }; /* Forward reference */ const char *MPIR_Err_get_dynerr_string( int code ); @@ -297,11 +298,13 @@ const char *MPIR_Err_get_dynerr_string( int code ) if (errcode) { if (errcode < first_free_code) { errstr = user_code_msgs[errcode]; + if (!errstr) errstr = empty_error_string; } } else { if (errclass < first_free_class) { errstr = user_class_msgs[errclass]; + if (!errstr) errstr = empty_error_string; } } -- Lisandro Dalcin --------------- CIMEC (UNL/CONICET) Predio CONICET-Santa Fe Colectora RN 168 Km 472, Paraje El Pozo 3000 Santa Fe, Argentina Tel: +54-342-4511594 (ext 1016) Tel/Fax: +54-342-4511169
participants (1)
Lisandro Dalcin
