Re: [mpich-devel] ROMIO collective i/o memory use
Do alltoallv actually run faster than send-recv for the MPIO use case? For >1MB messages, is alltoallv noticeably faster than a well-written send-recv implantation? At least on BGQ, send-recv turns into a receiver-side PAMI_Rget for large messages; I would guess the optimized alltoallv implementation is rput-based at the SPI level. Other than overhead, they should run at the same speed, no? If execution overhead is not significant, then the implementation that minimizes memory usage should be the default. I suppose I should just write alltoallv using send-recv and see what the difference is... Jeff On Mon, May 6, 2013 at 3:05 PM, Bob Cernohous <[email protected]> wrote:
On Mon, May 06, 2013 at 02:30:15PM -0500, Bob Cernohous wrote:
Should we consider this as interest in working on this problem on the IBM side :)? -- Rob
Say what?! ;)
RobR's excited that IBM's looking at the ROMIO piece of DCMF. We thought we were on our own with that one.
I was looking more for agreement that collective i/o is 'what it is'... and maybe some idea if we just have some known limitations on scaling it. Yes, that BG alltoallv is a bigger problem that we can avoid with an env var -- is that just going to have to be 'good enough'? (I think that Jeff P wrote that on BG/P and got good performance with that alltoallv. Trading memory for performance, not unusual, and at least it's selectable.)
I can't test while our Blue Gene is under maintenance. I know the environment variable selection helps only a little bit (like improves scaling from 4k to 8k maybe? don't have the notes offhand).
Ouch. So you've seen the scaling failures at 8k... ranks? racks? Kevin is failing at... 16 racks x 16 ranks per node... I think ... so 256k ranks.
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond ALCF docs: http://www.alcf.anl.gov/user-guides
participants (1)
Jeff Hammond
