Re: [mpich-devel] uninit status_static_array
Hi Daniel, My Github fork is totally unofficial and I don't want anyone to be confused about the authority of http://git.mpich.org/mpich.git/. Generating patch files with 'git format-patch' and emailing them to the list or attaching them to a Trac ticket are better. There is also 'git send-email', but I don't know how to use it. However, if you really, really like Github, you can submit a pull request to my repo and I'll push it to the MPICH review repo for you if it passes the test suite in Travis. Best, Jeff On Sat, Jan 9, 2016 at 5:14 PM, Daniel Ibanez <[email protected]> wrote:
Well, here is what I think is a legitimate fix based on the MPICH 3.2 tarball, to the file src/mpi/coll/helper_fns.c
--- helper_fns_old.c 2016-01-09 19:21:21.000000000 -0500 +++ helper_fns.c 2016-01-09 19:22:19.000000000 -0500 @@ -760,6 +760,8 @@ to check for the error bit in the tag below, we should initialize all tag fields here. */ status_array[i].MPI_TAG = 0; + /* Same as above for MPI_SOURCE */ + status_array[i].MPI_SOURCE = MPI_PROC_NULL;
/* Convert the MPID_Request objects to MPI_Request objects */ request_ptrs[i] = requests[i]->handle;
Seems like the MPID refactoring introduced both the status_static_array optimization and properly caught the uninitialized MPI_TAG:
https://github.com/jeffhammond/mpich/commit/54362c008ee413b40d5e4f654b72ee45...
Then subsequent continuations of that work added MPI_SOURCE as something that is checked but didn't go back and initialize it:
https://github.com/jeffhammond/mpich/commit/9a1ae5a841cd9cc5b2d258aa52fe1cb7...
Apologies for the lack of version control coherence, I'm not sure what the optimal way is to propose changes.
Please let me know if you can apply this patch.
Thanks
On Sat, Jan 9, 2016 at 10:18 AM, Daniel Ibanez <[email protected]> wrote:
Hello,
Using MPICH 3.2, I get the following from Valgrind:
==80605== Conditional jump or move depends on uninitialised value(s) ==80605== at 0x100198C14: MPIC_Waitall (mpiimpl.h:4394) ==80605== by 0x100061D82: MPI_Dist_graph_create (dist_gr_create.c:380) ==80605== by 0x100000EC5: main (uninit.c:21) ==80605== Uninitialised value was created by a stack allocation ==80605== at 0x100198ADD: MPIC_Waitall (helper_fns.c:735)
When I run this program with 2 ranks:
int main(int argc, char** argv) { MPI_Init(&argc, &argv); int n[2] = {1,1}; int sources[2] = {0,1}; int degrees[2] = {0,2}; int destinations_1[2] = {0,1}; int* destinations[2] = {0, destinations_1}; int weights_1[2] = {1,1}; int* weights[2] = {0, weights_1}; int rank; MPI_Comm_rank(MPI_COMM_WORLD, &rank); MPI_Comm new_comm; MPI_Dist_graph_create(MPI_COMM_WORLD, n[rank], &sources[rank], °rees[rank], destinations[rank], weights[rank], MPI_INFO_NULL, 0, &new_comm); MPI_Comm_free(&new_comm); MPI_Finalize(); }
It seems to come from the status_static_array at src/mpi/coll/helper_fns.c:740
It looks like status->MPI_SOURCE, when checked by MPIR_Process_status at src/include/mpiimpl.h:4394 might not be initialized by MPIR_Waitall_impl (I checked the other things used in that if statement and I'm pretty sure its MPI_SOURCE). I had a hard time tracing through the code further than that though.
I just switched from MPICH 3.1.4 and this didn't show up in that version. I tend to like MPICH for its lack of Valgrind issues, so let me know how I can help get this fixed.
Thank you,
_______________________________________________ To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/devel
-- Jeff Hammond [email protected] http://jeffhammond.github.io/
participants (1)
Jeff Hammond
