Re: [mpich-devel] memory profiling HOWTO?
Jeff, Which memory are you interested in -- memory the application allocates, or memory that MPICH allocates? If the former, you can use the PMPI interface to hook MPI_Alloc/Free_mem. If you are interested in MPICH internal memory use, Dave can probably give the most informed answer. I would probably just modify MPIU_Malloc. ~Jim. On 2/22/13 8:44 AM, Jeff Hammond wrote:
Is there any documentation of how to properly instrument MPICH with memory profiling? I understand MPIU_MALLOC allows me to do this.
My goal is to merely print out every time memory is allocated larger than a particular size. I'd also like the rank to show up in the output.
Please RTM me if the M exists. Source comments are also a good M if they are correct and sufficiently complete.
Thanks!
Jeff
participants (1)
Jim Dinan
