Re: [mpich-devel] Mac autogen.sh fails
This would appear to be the culprit. Maybe Pavan/Ken can talk about why it was removed? https://github.intel.com/csr/mpich-ofi/commit/a512f954007fefa4b3b21884885448... On Dec 7, 2017, at 3:51 PM, Jeff Hammond <[email protected]> wrote: autogen.sh is failing for me on Mac because Apple's libtool is not in the same place as Homebrew's autoconf/automake. I perused autogen.sh but didn't see an option to fix this. I need to use Homebrew autotools for other projects and don't want to uninstall Xcode for obvious reasons. Is there a workaround besides hacking autogen.sh and hating myself? I'd like to cause it to glibtool instead. If nothing else, autogen.sh incorrectly prints the location of libtool. It is in /usr/bin not /. Thanks, Jeff jrhammon-mac01:git jrhammon$ which libtool /usr/bin/libtool jrhammon-mac01:git jrhammon$ which autoconf /usr/local/bin/autoconf jrhammon-mac01:git jrhammon$ which automake /usr/local/bin/automake jrhammon-mac01:git jrhammon$ which glibtool /usr/local/bin/glibtool jrhammon-mac01:git jrhammon$ ./autogen.sh #################################### ## Checking user environment #################################### Verifying the location of autogen.sh... done usage: dirname path Checking if autotools are in the same location... no autoconf is in /usr/local automake is in /usr/local libtool is in / ===> WARNING: Autotools are in different locations. In rare occasion, ===> WARNING: resulting configure or makefile may fail in some unexpected ways. Checking if autoreconf accepts -I //share/aclocal... no Checking if autoreconf works after an additional libtoolize step... no ===> ERROR: Since none of the autoreconf workaround works ===> ERROR: and autotools are not in the same directory, aborting... ===> ERROR: Updating autotools or putting all autotools in the same location ===> ERROR: may resolve the issue. -- Jeff Hammond [email protected]<mailto:[email protected]> http://jeffhammond.github.io/ _______________________________________________ To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/devel
participants (1)
Bland, Wesley
