Re: [mpich-devel] Regression tests on mpich-1.3.2
Forwarding this at the suggestion of Rob Latham. It's worth noting that a high percentage of the f77 failures were syntax issues but a few tests did pass: [wscullin@vestalac2 mpich-1.3.2-testing]$ grep -v 'not ok' *-r3-postpatch/summary.tap | grep f77 | grep ok | grep -v '##' | grep xl xl.legacy.ndebug-r3-postpatch/summary.tap:ok 526 - ./f77/io/c2fmultio 1 xl.legacy.ndebug-r3-postpatch/summary.tap:ok 543 - ./f77/ext/c2fmult 1 xl.ndebug-r3-postpatch/summary.tap:ok 526 - ./f77/io/c2fmultio 1 xl.ndebug-r3-postpatch/summary.tap:ok 543 - ./f77/ext/c2fmult 1 xl-r3-postpatch/summary.tap:ok 526 - ./f77/io/c2fmultio 1 xl-r3-postpatch/summary.tap:ok 543 - ./f77/ext/c2fmult 1 The XL compilers used are the May 2014 PTF: [wscullin@vestalac2 mpich-1.3.2-testing]$ xlf -qversion=verbose IBM XL Fortran for Blue Gene, V14.1 Version: 14.01.0000.0008 Driver Version: 14.01(Fortran) Level: 140417 ID:_gBvIcmjEEeOTbt3so48j-A Fortran Front End and Run Time Version: 14.01(Fortran) Level: 140417 ID:_o3fhwsZGEeOCnf7uAVQYOQ Fortran Transformer Version: 14.01(Fortran) Level: 140417 ID:_o4Glx8ZGEeOCnf7uAVQYOQ High-Level Optimizer Version: 12.01(C/C++) and 14.01(Fortran) Level: 140417 ID:_kTVT9H7SEeOTb93so48j-A Low-Level Optimizer Version: 12.01(C/C++) and 14.01(Fortran) Level: 140417 ID:_o-Q4IMZGEeOCnf7uAVQYOQ [wscullin@vestalac2 mpich-1.3.2-testing]$ xlc -qversion=verbose IBM XL C/C++ for Blue Gene, V12.1 Version: 12.01.0000.0008 Driver Version: 12.01(C/C++) Level: 140417 ID:_gBvIcmjEEeOTbt3so48j-A C Front End Version: 12.01(C/C++) Level: 140417 ID:_kTr5Qn7SEeOTb93so48j-A C++ Front End Version: 12.01(C/C++) Level: 140501 ID:_TB1SNdFsEeOC9P7uAVQYOQ High-Level Optimizer Version: 12.01(C/C++) and 14.01(Fortran) Level: 140417 ID:_kTVT9H7SEeOTb93so48j-A Low-Level Optimizer Version: 12.01(C/C++) and 14.01(Fortran) Level: 140417 ID:_o-Q4IMZGEeOCnf7uAVQYOQ Thanks, William On Sat, Aug 2, 2014 at 1:05 PM, William Scullin <[email protected]> wrote:
I built mpich-1.3.2 on Vesta in /dev/shm/mpich under V1R2M2 with eFixes through eFix 3 plus Rob Latham's patch from commit 80b48f9ab06c79e663e9f8b72ec1c70c72198e94 using the instructions found at https://wiki.mpich.org/mpich/index.php/BGQ. There were a handful of failures when I ran the regression test suite. Are they meaningful and how should I proceed from here?
Thanks, William
The following regression rests showed failures:
[wscullin@vestalac2 mpich-1.3.2-testing]$ grep 'not ok' *-r3-postpatch/summary.tap gcc-4.4.7-r3-postpatch/summary.tap:not ok 284 - ./init/timeout 2 gcc-4.4.7-r3-postpatch/summary.tap:not ok 468 - ./io/bigtype 1
gcc-4.7.2-r3-postpatch/summary.tap:not ok 284 - ./init/timeout 2 gcc-4.7.2-r3-postpatch/summary.tap:not ok 310 - ./pt2pt/issendselfcancel 1 gcc-4.7.2-r3-postpatch/summary.tap:not ok 429 - ./rma/linked_list_bench_lock_shr_nocheck 4 gcc-4.7.2-r3-postpatch/summary.tap:not ok 468 - ./io/bigtype 1
xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 284 - ./init/timeout 2 xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 426 - ./rma/linked_list_bench_lock_all 4 xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 468 - ./io/bigtype 1 xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 469 - ./f77/attr/attrmpi1f xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 470 - ./f77/attr/baseattrf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 471 - ./f77/attr/baseattr2f xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 472 - ./f77/attr/commattrf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 473 - ./f77/attr/commattr2f xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 474 - ./f77/attr/commattr3f xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 475 - ./f77/attr/typeattrf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 476 - ./f77/attr/typeattr2f xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 477 - ./f77/attr/typeattr3f xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 478 - ./f77/coll/uallreducef xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 479 - ./f77/coll/exscanf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 480 - ./f77/coll/alltoallwf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 481 - ./f77/coll/alltoallvf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 482 - ./f77/coll/inplacef xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 483 - ./f77/coll/reducelocalf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 484 - ./f77/coll/redscatf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 485 - ./f77/coll/split_typef xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 486 - ./f77/coll/nonblockingf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 487 - ./f77/coll/vw_inplacef xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 488 - ./f77/coll/red_scat_blockf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 489 - ./f77/coll/nonblocking_inpf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 490 - ./f77/datatype/typenamef xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 491 - ./f77/datatype/typename3f xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 492 - ./f77/datatype/typesnamef xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 493 - ./f77/datatype/typecntsf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 494 - ./f77/datatype/typem2f xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 495 - ./f77/datatype/typesubf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 496 - ./f77/datatype/packef xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 497 - ./f77/datatype/gaddressf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 498 - ./f77/datatype/allctypesf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 499 - ./f77/datatype/hindex1f xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 500 - ./f77/datatype/hindexed_blockf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 501 - ./f77/pt2pt/statusesf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 502 - ./f77/pt2pt/greqf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 503 - ./f77/pt2pt/allpairf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 504 - ./f77/pt2pt/mprobef xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 505 - ./f77/info/infotestf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 506 - ./f77/info/infotest2f xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 507 - ./f77/io/iwriteatf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 508 - ./f77/io/iwritef xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 509 - ./f77/io/iwriteshf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 510 - ./f77/io/writef xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 511 - ./f77/io/writeatf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 512 - ./f77/io/writeallf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 513 - ./f77/io/writeshf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 514 - ./f77/io/writeordf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 515 - ./f77/io/writeatallf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 516 - ./f77/io/writeatallbef xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 517 - ./f77/io/writeallbef xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 518 - ./f77/io/writeordbef xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 519 - ./f77/io/fileerrf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 520 - ./f77/io/fileinfof xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 521 - ./f77/io/shpositionf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 522 - ./f77/io/atomicityf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 523 - ./f77/io/miscfilef xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 524 - ./f77/io/setviewcurf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 525 - ./f77/io/c2f2ciof xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 527 - ./f77/rma/winscale1f xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 528 - ./f77/rma/winfencef xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 529 - ./f77/rma/wingetf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 530 - ./f77/rma/winscale2f xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 531 - ./f77/rma/winerrf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 532 - ./f77/rma/winnamef xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 533 - ./f77/rma/wingroupf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 534 - ./f77/rma/winaccf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 535 - ./f77/rma/c2f2cwinf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 536 - ./f77/rma/baseattrwinf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 537 - ./f77/rma/winattrf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 538 - ./f77/rma/winattr2f xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 539 - ./f77/init/baseenvf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 540 - ./f77/comm/commnamef xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 541 - ./f77/comm/commerrf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 542 - ./f77/ext/c2f2cf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 544 - ./f77/ext/ctypesinf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 545 - ./f77/ext/allocmemf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 546 - ./f77/topo/cartcrf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 547 - ./f77/topo/dgraph_wgtf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 548 - ./f77/topo/dgraph_unwgtf xl.legacy.ndebug-r3-postpatch/summary.tap:not ok 549 - ./f77/profile/profile1f
xl.legacy-r3-postpatch/summary.tap:not ok 284 - ./init/timeout 2 xl.ndebug-r3-postpatch/summary.tap:not ok 284 - ./init/timeout 2 xl.ndebug-r3-postpatch/summary.tap:not ok 468 - ./io/bigtype 1 xl.ndebug-r3-postpatch/summary.tap:not ok 469 - ./f77/attr/attrmpi1f xl.ndebug-r3-postpatch/summary.tap:not ok 470 - ./f77/attr/baseattrf xl.ndebug-r3-postpatch/summary.tap:not ok 471 - ./f77/attr/baseattr2f xl.ndebug-r3-postpatch/summary.tap:not ok 472 - ./f77/attr/commattrf xl.ndebug-r3-postpatch/summary.tap:not ok 473 - ./f77/attr/commattr2f xl.ndebug-r3-postpatch/summary.tap:not ok 474 - ./f77/attr/commattr3f xl.ndebug-r3-postpatch/summary.tap:not ok 475 - ./f77/attr/typeattrf xl.ndebug-r3-postpatch/summary.tap:not ok 476 - ./f77/attr/typeattr2f xl.ndebug-r3-postpatch/summary.tap:not ok 477 - ./f77/attr/typeattr3f xl.ndebug-r3-postpatch/summary.tap:not ok 478 - ./f77/coll/uallreducef xl.ndebug-r3-postpatch/summary.tap:not ok 479 - ./f77/coll/exscanf xl.ndebug-r3-postpatch/summary.tap:not ok 480 - ./f77/coll/alltoallwf xl.ndebug-r3-postpatch/summary.tap:not ok 481 - ./f77/coll/alltoallvf xl.ndebug-r3-postpatch/summary.tap:not ok 482 - ./f77/coll/inplacef xl.ndebug-r3-postpatch/summary.tap:not ok 483 - ./f77/coll/reducelocalf xl.ndebug-r3-postpatch/summary.tap:not ok 484 - ./f77/coll/redscatf xl.ndebug-r3-postpatch/summary.tap:not ok 485 - ./f77/coll/split_typef xl.ndebug-r3-postpatch/summary.tap:not ok 486 - ./f77/coll/nonblockingf xl.ndebug-r3-postpatch/summary.tap:not ok 487 - ./f77/coll/vw_inplacef xl.ndebug-r3-postpatch/summary.tap:not ok 488 - ./f77/coll/red_scat_blockf xl.ndebug-r3-postpatch/summary.tap:not ok 489 - ./f77/coll/nonblocking_inpf xl.ndebug-r3-postpatch/summary.tap:not ok 490 - ./f77/datatype/typenamef xl.ndebug-r3-postpatch/summary.tap:not ok 491 - ./f77/datatype/typename3f xl.ndebug-r3-postpatch/summary.tap:not ok 492 - ./f77/datatype/typesnamef xl.ndebug-r3-postpatch/summary.tap:not ok 493 - ./f77/datatype/typecntsf xl.ndebug-r3-postpatch/summary.tap:not ok 494 - ./f77/datatype/typem2f xl.ndebug-r3-postpatch/summary.tap:not ok 495 - ./f77/datatype/typesubf xl.ndebug-r3-postpatch/summary.tap:not ok 496 - ./f77/datatype/packef xl.ndebug-r3-postpatch/summary.tap:not ok 497 - ./f77/datatype/gaddressf xl.ndebug-r3-postpatch/summary.tap:not ok 498 - ./f77/datatype/allctypesf xl.ndebug-r3-postpatch/summary.tap:not ok 499 - ./f77/datatype/hindex1f xl.ndebug-r3-postpatch/summary.tap:not ok 500 - ./f77/datatype/hindexed_blockf xl.ndebug-r3-postpatch/summary.tap:not ok 501 - ./f77/pt2pt/statusesf xl.ndebug-r3-postpatch/summary.tap:not ok 502 - ./f77/pt2pt/greqf xl.ndebug-r3-postpatch/summary.tap:not ok 503 - ./f77/pt2pt/allpairf xl.ndebug-r3-postpatch/summary.tap:not ok 504 - ./f77/pt2pt/mprobef xl.ndebug-r3-postpatch/summary.tap:not ok 505 - ./f77/info/infotestf xl.ndebug-r3-postpatch/summary.tap:not ok 506 - ./f77/info/infotest2f xl.ndebug-r3-postpatch/summary.tap:not ok 507 - ./f77/io/iwriteatf xl.ndebug-r3-postpatch/summary.tap:not ok 508 - ./f77/io/iwritef xl.ndebug-r3-postpatch/summary.tap:not ok 509 - ./f77/io/iwriteshf xl.ndebug-r3-postpatch/summary.tap:not ok 510 - ./f77/io/writef xl.ndebug-r3-postpatch/summary.tap:not ok 511 - ./f77/io/writeatf xl.ndebug-r3-postpatch/summary.tap:not ok 512 - ./f77/io/writeallf xl.ndebug-r3-postpatch/summary.tap:not ok 513 - ./f77/io/writeshf xl.ndebug-r3-postpatch/summary.tap:not ok 514 - ./f77/io/writeordf xl.ndebug-r3-postpatch/summary.tap:not ok 515 - ./f77/io/writeatallf xl.ndebug-r3-postpatch/summary.tap:not ok 516 - ./f77/io/writeatallbef xl.ndebug-r3-postpatch/summary.tap:not ok 517 - ./f77/io/writeallbef xl.ndebug-r3-postpatch/summary.tap:not ok 518 - ./f77/io/writeordbef xl.ndebug-r3-postpatch/summary.tap:not ok 519 - ./f77/io/fileerrf xl.ndebug-r3-postpatch/summary.tap:not ok 520 - ./f77/io/fileinfof xl.ndebug-r3-postpatch/summary.tap:not ok 521 - ./f77/io/shpositionf xl.ndebug-r3-postpatch/summary.tap:not ok 522 - ./f77/io/atomicityf xl.ndebug-r3-postpatch/summary.tap:not ok 523 - ./f77/io/miscfilef xl.ndebug-r3-postpatch/summary.tap:not ok 524 - ./f77/io/setviewcurf xl.ndebug-r3-postpatch/summary.tap:not ok 525 - ./f77/io/c2f2ciof xl.ndebug-r3-postpatch/summary.tap:not ok 527 - ./f77/rma/winscale1f xl.ndebug-r3-postpatch/summary.tap:not ok 528 - ./f77/rma/winfencef xl.ndebug-r3-postpatch/summary.tap:not ok 529 - ./f77/rma/wingetf xl.ndebug-r3-postpatch/summary.tap:not ok 530 - ./f77/rma/winscale2f xl.ndebug-r3-postpatch/summary.tap:not ok 531 - ./f77/rma/winerrf xl.ndebug-r3-postpatch/summary.tap:not ok 532 - ./f77/rma/winnamef xl.ndebug-r3-postpatch/summary.tap:not ok 533 - ./f77/rma/wingroupf xl.ndebug-r3-postpatch/summary.tap:not ok 534 - ./f77/rma/winaccf xl.ndebug-r3-postpatch/summary.tap:not ok 535 - ./f77/rma/c2f2cwinf xl.ndebug-r3-postpatch/summary.tap:not ok 536 - ./f77/rma/baseattrwinf xl.ndebug-r3-postpatch/summary.tap:not ok 537 - ./f77/rma/winattrf xl.ndebug-r3-postpatch/summary.tap:not ok 538 - ./f77/rma/winattr2f xl.ndebug-r3-postpatch/summary.tap:not ok 539 - ./f77/init/baseenvf xl.ndebug-r3-postpatch/summary.tap:not ok 540 - ./f77/comm/commnamef xl.ndebug-r3-postpatch/summary.tap:not ok 541 - ./f77/comm/commerrf xl.ndebug-r3-postpatch/summary.tap:not ok 542 - ./f77/ext/c2f2cf xl.ndebug-r3-postpatch/summary.tap:not ok 544 - ./f77/ext/ctypesinf xl.ndebug-r3-postpatch/summary.tap:not ok 545 - ./f77/ext/allocmemf xl.ndebug-r3-postpatch/summary.tap:not ok 546 - ./f77/topo/cartcrf xl.ndebug-r3-postpatch/summary.tap:not ok 547 - ./f77/topo/dgraph_wgtf xl.ndebug-r3-postpatch/summary.tap:not ok 548 - ./f77/topo/dgraph_unwgtf xl.ndebug-r3-postpatch/summary.tap:not ok 549 - ./f77/profile/profile1f
xl-r3-postpatch/summary.tap:not ok 284 - ./init/timeout 2 xl-r3-postpatch/summary.tap:not ok 468 - ./io/bigtype 1 xl-r3-postpatch/summary.tap:not ok 469 - ./f77/attr/attrmpi1f xl-r3-postpatch/summary.tap:not ok 470 - ./f77/attr/baseattrf xl-r3-postpatch/summary.tap:not ok 471 - ./f77/attr/baseattr2f xl-r3-postpatch/summary.tap:not ok 472 - ./f77/attr/commattrf xl-r3-postpatch/summary.tap:not ok 473 - ./f77/attr/commattr2f xl-r3-postpatch/summary.tap:not ok 474 - ./f77/attr/commattr3f xl-r3-postpatch/summary.tap:not ok 475 - ./f77/attr/typeattrf xl-r3-postpatch/summary.tap:not ok 476 - ./f77/attr/typeattr2f xl-r3-postpatch/summary.tap:not ok 477 - ./f77/attr/typeattr3f xl-r3-postpatch/summary.tap:not ok 478 - ./f77/coll/uallreducef xl-r3-postpatch/summary.tap:not ok 479 - ./f77/coll/exscanf xl-r3-postpatch/summary.tap:not ok 480 - ./f77/coll/alltoallwf xl-r3-postpatch/summary.tap:not ok 481 - ./f77/coll/alltoallvf xl-r3-postpatch/summary.tap:not ok 482 - ./f77/coll/inplacef xl-r3-postpatch/summary.tap:not ok 483 - ./f77/coll/reducelocalf xl-r3-postpatch/summary.tap:not ok 484 - ./f77/coll/redscatf xl-r3-postpatch/summary.tap:not ok 485 - ./f77/coll/split_typef xl-r3-postpatch/summary.tap:not ok 486 - ./f77/coll/nonblockingf xl-r3-postpatch/summary.tap:not ok 487 - ./f77/coll/vw_inplacef xl-r3-postpatch/summary.tap:not ok 488 - ./f77/coll/red_scat_blockf xl-r3-postpatch/summary.tap:not ok 489 - ./f77/coll/nonblocking_inpf xl-r3-postpatch/summary.tap:not ok 490 - ./f77/datatype/typenamef xl-r3-postpatch/summary.tap:not ok 491 - ./f77/datatype/typename3f xl-r3-postpatch/summary.tap:not ok 492 - ./f77/datatype/typesnamef xl-r3-postpatch/summary.tap:not ok 493 - ./f77/datatype/typecntsf xl-r3-postpatch/summary.tap:not ok 494 - ./f77/datatype/typem2f xl-r3-postpatch/summary.tap:not ok 495 - ./f77/datatype/typesubf xl-r3-postpatch/summary.tap:not ok 496 - ./f77/datatype/packef xl-r3-postpatch/summary.tap:not ok 497 - ./f77/datatype/gaddressf xl-r3-postpatch/summary.tap:not ok 498 - ./f77/datatype/allctypesf xl-r3-postpatch/summary.tap:not ok 499 - ./f77/datatype/hindex1f xl-r3-postpatch/summary.tap:not ok 500 - ./f77/datatype/hindexed_blockf xl-r3-postpatch/summary.tap:not ok 501 - ./f77/pt2pt/statusesf xl-r3-postpatch/summary.tap:not ok 502 - ./f77/pt2pt/greqf xl-r3-postpatch/summary.tap:not ok 503 - ./f77/pt2pt/allpairf xl-r3-postpatch/summary.tap:not ok 504 - ./f77/pt2pt/mprobef xl-r3-postpatch/summary.tap:not ok 505 - ./f77/info/infotestf xl-r3-postpatch/summary.tap:not ok 506 - ./f77/info/infotest2f xl-r3-postpatch/summary.tap:not ok 507 - ./f77/io/iwriteatf xl-r3-postpatch/summary.tap:not ok 508 - ./f77/io/iwritef xl-r3-postpatch/summary.tap:not ok 509 - ./f77/io/iwriteshf xl-r3-postpatch/summary.tap:not ok 510 - ./f77/io/writef xl-r3-postpatch/summary.tap:not ok 511 - ./f77/io/writeatf xl-r3-postpatch/summary.tap:not ok 512 - ./f77/io/writeallf xl-r3-postpatch/summary.tap:not ok 513 - ./f77/io/writeshf xl-r3-postpatch/summary.tap:not ok 514 - ./f77/io/writeordf xl-r3-postpatch/summary.tap:not ok 515 - ./f77/io/writeatallf xl-r3-postpatch/summary.tap:not ok 516 - ./f77/io/writeatallbef xl-r3-postpatch/summary.tap:not ok 517 - ./f77/io/writeallbef xl-r3-postpatch/summary.tap:not ok 518 - ./f77/io/writeordbef xl-r3-postpatch/summary.tap:not ok 519 - ./f77/io/fileerrf xl-r3-postpatch/summary.tap:not ok 520 - ./f77/io/fileinfof xl-r3-postpatch/summary.tap:not ok 521 - ./f77/io/shpositionf xl-r3-postpatch/summary.tap:not ok 522 - ./f77/io/atomicityf xl-r3-postpatch/summary.tap:not ok 523 - ./f77/io/miscfilef xl-r3-postpatch/summary.tap:not ok 524 - ./f77/io/setviewcurf xl-r3-postpatch/summary.tap:not ok 525 - ./f77/io/c2f2ciof xl-r3-postpatch/summary.tap:not ok 527 - ./f77/rma/winscale1f xl-r3-postpatch/summary.tap:not ok 528 - ./f77/rma/winfencef xl-r3-postpatch/summary.tap:not ok 529 - ./f77/rma/wingetf xl-r3-postpatch/summary.tap:not ok 530 - ./f77/rma/winscale2f xl-r3-postpatch/summary.tap:not ok 531 - ./f77/rma/winerrf xl-r3-postpatch/summary.tap:not ok 532 - ./f77/rma/winnamef xl-r3-postpatch/summary.tap:not ok 533 - ./f77/rma/wingroupf xl-r3-postpatch/summary.tap:not ok 534 - ./f77/rma/winaccf xl-r3-postpatch/summary.tap:not ok 535 - ./f77/rma/c2f2cwinf xl-r3-postpatch/summary.tap:not ok 536 - ./f77/rma/baseattrwinf xl-r3-postpatch/summary.tap:not ok 537 - ./f77/rma/winattrf xl-r3-postpatch/summary.tap:not ok 538 - ./f77/rma/winattr2f xl-r3-postpatch/summary.tap:not ok 539 - ./f77/init/baseenvf xl-r3-postpatch/summary.tap:not ok 540 - ./f77/comm/commnamef xl-r3-postpatch/summary.tap:not ok 541 - ./f77/comm/commerrf xl-r3-postpatch/summary.tap:not ok 542 - ./f77/ext/c2f2cf xl-r3-postpatch/summary.tap:not ok 544 - ./f77/ext/ctypesinf xl-r3-postpatch/summary.tap:not ok 545 - ./f77/ext/allocmemf xl-r3-postpatch/summary.tap:not ok 546 - ./f77/topo/cartcrf xl-r3-postpatch/summary.tap:not ok 547 - ./f77/topo/dgraph_wgtf xl-r3-postpatch/summary.tap:not ok 548 - ./f77/topo/dgraph_unwgtf xl-r3-postpatch/summary.tap:not ok 549 - ./f77/profile/profile1f [wscullin@vestalac2 mpich-1.3.2-testing]$
participants (1)
William Scullin
