Re: [mpich-devel] datatype accessors with uncommited datatypes
On 12/27/2012 02:05 PM US Central Time, William Gropp wrote:
The standard is already clear - commit is only required when the datatype is used for communication. It is unnecessary for the standard to list all cases where commit is not required - it is enough to list where commit *is* required, which it does.
This is argument of the form "unless something is explicitly prohibited, it is permitted," which is extraordinarily dangerous and inconsistent with a robust standards document.
The way the text is currently written, it says "it is required for case X and not required for case Y" instead of saying "not required for all other cases". If the intended behavior is to not throw an error for non-communication routines, then the one example (of datatype constructors) should be removed from the standard, or just rewritten as "other operations such as datatype constructors".
Exactly. The sentence "As an argument in datatype constructors, uncommitted and also committed datatypes can be used," should be removed completely or otherwise modified such that there is no potential for it to be misinterpreted as an exclusive list of permitted usage. Jeff -- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
participants (1)
Jeff Hammond
