Re: [mpich-devel] MPICH with SYCL on Aurora
With MPIR_CVAR_REQUEST_ERR_FATAL=1 in a 2-process run, this looks like: Abort(270742287) on node 0: Fatal error in internal_Waitall: Other MPI error, error stack: internal_Waitall(126)..: MPI_Waitall(count=1, array_of_requests=0x797cdb0, array_of_statuses=0x7ca3fb0) failed MPIR_Waitall(916)......: MPIDI_IPC_rndv_cb(172).: MPIDI_CMA_copy_data(54): copy_iovs(202).........: process_vm_readv failed (errno 14) Abort(270742287) on node 1: Fatal error in internal_Waitall: Other MPI error, error stack: (same) This succeeds for 1-process with SYCL enabled or for 2-process with SYCL disabled in the app at configure time. The app looks like: $ ldd =agent libmpicxx.so.0 => /lus/flare/projects/EpiCalib/sfw/mpich-5.0.0rc3/lib/libmpicxx.so.0 (0x0000146726aed000) libmpi.so.0 => /lus/flare/projects/EpiCalib/sfw/mpich-5.0.0rc3/lib/libmpi.so.0 (0x0000146725265000) libmkl_sycl_blas.so.5 => /opt/aurora/26.26.0/oneapi/mkl/latest/lib/libmkl_sycl_blas.so.5 (0x0000146721063000) (etc.) libstdc++.so.6 => /opt/aurora/26.26.0/spack/unified/1.1.1/install/linux-x86_64/gcc-13.4.0-hgnyg4p/lib64/libstdc++.so.6 (0x0000146708cd9000) libm.so.6 => /lib64/libm.so.6 (0x0000146708b77000) libgcc_s.so.1 => /opt/aurora/26.26.0/spack/unified/1.1.1/install/linux-x86_64/gcc-13.4.0-hgnyg4p/lib64/libgcc_s.so.1 (0x0000146708b53000) libsycl.so.8 => /opt/aurora/26.26.0/oneapi/compiler/latest/lib/libsycl.so.8 (0x0000146708758000) libOpenCL.so.1 => /opt/aurora/26.26.0/support/libraries/khronos/default/lib64/libOpenCL.so.1 (0x0000146708743000) libpthread.so.0 => /lib64/libpthread.so.0 (0x000014670871f000) libc.so.6 => /lib64/libc.so.6 (0x000014670852a000) libhwloc.so.15 => /opt/aurora/26.26.0/oneapi/tcm/latest/lib/libhwloc.so.15 (0x00001467082cc000) (etc.) Thanks -- Justin M Wozniak ________________________________ From: Harms, Kevin <[email protected]> Sent: Monday, March 30, 2026 14:50 To: [email protected] <[email protected]> Cc: Wozniak, Justin M. <[email protected]> Subject: Re: MPICH with SYCL on Aurora Justin, can you provide the specific error? kevin ________________________________________ From: Wozniak, Justin M. via devel <[email protected]> Sent: Monday, March 30, 2026 2:24 PM To: [email protected] Cc: Wozniak, Justin M. Subject: [mpich-devel] MPICH with SYCL on Aurora Hi I am trying to port a simulation ensemble workflow that runs ExaEpi/AMReX/SYCL to Aurora. The outer workflow uses the system MPI and we use MPICH to run the app with node-local parallelism using a hand-built MPICH. On Aurora, I get errors in early MPI calls that I think are due to SYCL. This approach works on NVIDIA systems like Perlmutter. Is there some simple way to make MPICH aware of SYCL? Thanks -- Justin M Wozniak
participants (1)
Wozniak, Justin M.
