Re: [mpich-devel] patch for missing declarations in test suite
Okay, here is a formatted patch file for both the MTestSleep business and http://trac.mpich.org/projects/mpich/ticket/1798. I don't really know how to split the two automatically; I created two patches by hand last night. I have committed locally already so if you know the Git-fu I should be using, please let me know. Thanks, Jeff On Thu, Mar 21, 2013 at 7:11 AM, Jim Dinan <[email protected]> wrote:
Hi Jeff,
These are different changes; the earlier patch you submitted was primarily fixing header files:
http://git.mpich.org/mpich.git/commitdiff/617927fb?hp=bda59a264d3889c1eb80ba...
I'll take a look at the new patch (or Dave is welcome to handle it, if he's already started).
Thanks for the patch, ~Jim.
On 03/20/2013 08:20 PM, Jeff Hammond wrote:
For some reason I do not see these changes. I attached a patch that implements "s/sleep/MTestSleep/g" in case it hasn't been done yet.
Jeff
On Thu, Feb 21, 2013 at 3:43 PM, Jim Dinan <[email protected]> wrote:
Hi Jeff,
Already done, and committed in 617927fb.
On 2/21/13 3:35 PM, Jeff Hammond wrote:
I'll see if I can make the patch Windows-safe then and resubmit.
Jeff
On Thu, Feb 21, 2013 at 1:18 PM, William Gropp <[email protected]> wrote:
unistd.h is not part of C - it is for Unix and Unix-like systems. There is a test for this file in configure.ac that should be used, and the Unixism in the test should be removed or protected. The test programs should not assume Unix/POSIX/Linux. The other fixes look good.
Bill
William Gropp Director, Parallel Computing Institute Deputy Director for Research Institute for Advanced Computing Applications and Technologies Thomas M. Siebel Chair in Computer Science University of Illinois Urbana-Champaign
On Feb 18, 2013, at 6:47 AM, Jeff Hammond wrote:
I'm submitting this via email because Trac is hosed right now (I assume it will be fixed in a few hours, but I don't want to enqueue this in my head that long).
LLVM complained about use of undeclared functions being invalid in C99. I fixed them in the attached patch, which is copied below.
The fix to test/mpi/rma/mutex_bench.c depends upon the patch to test/mpi/rma/Makefile.am because otherwise the header will not be found.
Best,
Jeff
$ cat test.patch diff --git a/test/mpi/coll/nonblocking3.c b/test/mpi/coll/nonblocking3.c index b1f66dd..8e896b7 100644 --- a/test/mpi/coll/nonblocking3.c +++ b/test/mpi/coll/nonblocking3.c @@ -16,6 +16,7 @@ #include "mpi.h" #include <stdlib.h> #include <stdio.h> +#include <unistd.h> #include <string.h> #include <assert.h> /* USE_STRICT_MPI may be defined in mpitestconf.h */ diff --git a/test/mpi/f90/attr/attrlangc.c b/test/mpi/f90/attr/attrlangc.c index 6920668..2ee4ef5 100644 --- a/test/mpi/f90/attr/attrlangc.c +++ b/test/mpi/f90/attr/attrlangc.c @@ -124,7 +124,7 @@ void cgetsizes_( MPI_Fint *ptrSize, MPI_Fint *intSize, MPI_Fint *aintSize ) }
/* ----------------------------------------------------------------------- */ -/* Copy and delete functions attached to keyvals +/* Copy and delete functions attached to keyvals */ /* ----------------------------------------------------------------------- */ static int CMPI1_COPY_FN( MPI_Comm comm, int keyval, void *extra, void *inval, void *outval, int *flag ) diff --git a/test/mpi/manual/mpi_t/nem_fbox_fallback_to_queue_count.c b/test/mpi/manual/mpi_t/nem_fbox_fallback_to_queue_count.c index f045212..9718bbc 100644 --- a/test/mpi/manual/mpi_t/nem_fbox_fallback_to_queue_count.c +++ b/test/mpi/manual/mpi_t/nem_fbox_fallback_to_queue_count.c @@ -17,6 +17,7 @@ #include <stdlib.h> #include <stdint.h> #include <stdio.h> +#include <unistd.h>
#define TRY(func) \ do { \ diff --git a/test/mpi/rma/Makefile.am b/test/mpi/rma/Makefile.am index 579721a..76155c5 100644 --- a/test/mpi/rma/Makefile.am +++ b/test/mpi/rma/Makefile.am @@ -155,5 +155,5 @@ get_accumulate_double_derived_SOURCES = get_accumulate.c get_accumulate_int_derived_SOURCES = get_accumulate.c
mutex_bench_SOURCES = mutex_bench.c mcs-mutex.c mcs-mutex.h -mutex_bench_shared_CPPFLAGS = -DUSE_WIN_SHARED +mutex_bench_shared_CPPFLAGS = -DUSE_WIN_SHARED $(AM_CPPFLAGS) mutex_bench_shared_SOURCES = mutex_bench.c mcs-mutex.c mcs-mutex.h diff --git a/test/mpi/rma/lockcontention3.c b/test/mpi/rma/lockcontention3.c index 6204e94..196dfb5 100644 --- a/test/mpi/rma/lockcontention3.c +++ b/test/mpi/rma/lockcontention3.c @@ -8,6 +8,7 @@ #include "stdlib.h" #include "mpitest.h" #include <assert.h> +#include <string.h>
#define LAST_TEST 14 #define RMA_SIZE 2048 diff --git a/test/mpi/rma/mutex_bench.c b/test/mpi/rma/mutex_bench.c index 098382e..2db24e4 100644 --- a/test/mpi/rma/mutex_bench.c +++ b/test/mpi/rma/mutex_bench.c @@ -12,6 +12,7 @@ #include <assert.h>
#include <mpi.h> +#include "mpitest.h" #include "mcs-mutex.h"
#define NUM_ITER 1000
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond <test.patch>
participants (1)
Jeff Hammond
