Re: [mpich-devel] overzealous F90/F90FLAGS error
On Jan 13, 2015, at 10:20 AM, Jeff Hammond <[email protected]> wrote:
I understand that configure is trying to help the user do the right thing (set FC and FCFLAGS), but this is the wrong way to do it.
This is the code that I would like to see removed:
# Since F90/F90FLAGS are replaced by FC/FCFLAGS, rather than silently # substituting them, i.e. FC=$F90 and FCFLAGS=$F90FLAGS, we choose to emit # an error message and abort to avoid any ambiguous/hidden bug in choosing # Fortran90 compilers. if test -n "$F90" -o -n "$F90FLAGS" ; then AC_MSG_ERROR([F90 and F90FLAGS are replaced by FC and FCFLAGS respectively in this configure, please unset F90/F90FLAGS and set FC/FCFLAGS instead and rerun configure again.]) fi
Rather than remove this code altogether, it might be better to change the logic to complain more like this (untested): if test -n "$F90" && test "x$F90" != "x$FC" ; then AC_MSG_ERROR([F90 set but not equal to FC. This is almost certainly a mistake. Either unset F90 or set F90="$FC"]) elif test -n "$F90FLAGS" && test "x$F90FLAGS" != "x$FCFLAGS" ; then AC_MSG_ERROR([F90FLAGS set but not equal to FCFLAGS. This is almost certainly a mistake. Either unset F90FLAGS or set F90FLAGS="$FCFLAGS"]) fi -Dave
participants (1)
Dave Goodell (dgoodell)
