Re: [mpich-devel] ./configure --enable-timer-type help output missing
Thanks. I don't know the answer, but I thought there was a standard method for implementing this. If the MPICH team doesn't know if, then I am certainly no help, since essentially all of my build systems and knowledge thereof are derived from MPICH :-) At the very least, if I know to set the --enable-timer-type option, will it be passed on to the child configure scripts if I pass it to the top-level configure invocation? Jeff On Thu, Apr 7, 2016 at 2:28 PM, Balaji, Pavan <[email protected]> wrote:
It is convenient to have all the help output be present in the top-level configure. We need to figure out how to make that happen while still allowing multiple independent packages inside MPICH. We don't have a good solution for that yet, but we are open to suggestions.
-- Pavan
On Apr 7, 2016, at 3:24 PM, Jeff Hammond <[email protected]> wrote:
I recall that the base configure script used to emit the help associated with --enable-timer-type. It no longer does so, although the option is still present in src/mpl/configure.
Do I have a reasonable expectation of seeing --help output for all options in the base configure, or am I expected to run --help against every configure in the tree?
Jeff
jrhammon-mac01:git jrhammon$ ./configure --help | grep time runtime - error checking controllable at runtime through environment runtime - Runtime control of data collected runtime - Alias to "multiple" --enable-mutex-timing calculate the time spent waiting on mutexes speeds up one-time build sometimes confusing) to the casual installer User-defined run-time library search path. jrhammon-mac01:git jrhammon$ ./src/mpl/configure --help | grep time speeds up one-time build --enable-timer-type=name - Select the timer to use for MPI_Wtime and internal timestamps. gethrtime - Solaris timer (Solaris systems only) clock_gettime - Posix timer (where available) gettimeofday - Most Unix systems linux86_cycle - Linux x86; returns cycle counts, not time in seconds* gcc_ia64_cycle - IPF ar.itc timer* mach_absolute_time - Mach absolute time (alternative to clock_gettime device - The timer is provided by the device *Note that the cycle timers are intended to be used by User-defined run-time library search path.
-- Jeff Hammond [email protected] http://jeffhammond.github.io/ _______________________________________________ To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/devel
participants (1)
Jeff Hammond
