Re: [mpich-discuss] Error Running MPICH for Photochemical Modeling
Abhishek, Could you reduce the example to one single file with less than 300 lines of code that reproduce the problem? Although we would like to help you, but looking at tarball of 147,000 line of Fortran code is too much effort for us. Also, another thing you could try is to use valgrind for detecting memory errors in the application. You can see the instructions of how to build MPICH with valgrind here: http://wiki.mpich.org/mpich/index.php/Support_for_Debugging_Memory_Allocatio... (please don’t drop the discuss list) Thanks, — Huiwei On Sep 19, 2014, at 6:45 PM, Abhishek Bhat <[email protected]> wrote:
Huiwei And Sangmin,
Please find attached - 1. The compiled application 2. Source Code Tarball 3. The failed job
Any help is really appreciated
Thank you Abhishek ................................................................................................................ Abhishek Bhat, PhD, EPI, Senior Consultant
-----Original Message----- From: Lu, Huiwei [mailto:[email protected]] Sent: Friday, September 19, 2014 5:30 PM To: [email protected] Subject: Re: [mpich-discuss] Error Running MPICH for Photochemical Modeling
Hi, Abhishek,
As mentioned in previous email, it looks like the problem lies in the application. Is it possible that you can provide us with a minimum example that fails? So that we can looked at the code and reproduce the problem on our machines.
Thanks, - Huiwei
On Sep 17, 2014, at 3:29 PM, Abhishek Bhat <[email protected]> wrote:
Sangmin,
Fatal error in MPI_Recv: A process has failed, error stack: MPI_Recv(187).............: MPI_Recv(buf=0x7fff21bc04b0, count=644490, MPI_REAL, src=1, tag=14131, MPI_COMM_WORLD, status=0x7fff227c47a0) failed dequeue_and_set_error(865): Communication error with rank 1
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 4183 RUNNING AT dfw-camx = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ====================================================================== ============= [proxy:0:4@dfw-camx-n4] HYD_pmcd_pmip_control_cmd_cb (pm/pmiserv/pmip_cb.c:885): assert (!closed) failed [proxy:0:4@dfw-camx-n4] HYDT_dmxu_poll_wait_for_event (tools/demux/demux_poll.c:76): callback returned error status [proxy:0:4@dfw-camx-n4] main (pm/pmiserv/pmip.c:206): demux engine error waiting for event [proxy:0:2@dfw-camx-n2] HYD_pmcd_pmip_control_cmd_cb (pm/pmiserv/pmip_cb.c:885): assert (!closed) failed [proxy:0:2@dfw-camx-n2] HYDT_dmxu_poll_wait_for_event (tools/demux/demux_poll.c:76): callback returned error status [proxy:0:2@dfw-camx-n2] main (pm/pmiserv/pmip.c:206): demux engine error waiting for event [proxy:0:3@dfw-camx-n3] HYD_pmcd_pmip_control_cmd_cb (pm/pmiserv/pmip_cb.c:885): assert (!closed) failed [proxy:0:3@dfw-camx-n3] HYDT_dmxu_poll_wait_for_event (tools/demux/demux_poll.c:76): callback returned error status [proxy:0:3@dfw-camx-n3] main (pm/pmiserv/pmip.c:206): demux engine error waiting for event [proxy:0:6@dfw-camx-n6] HYD_pmcd_pmip_control_cmd_cb (pm/pmiserv/pmip_cb.c:885): assert (!closed) failed [proxy:0:6@dfw-camx-n6] HYDT_dmxu_poll_wait_for_event (tools/demux/demux_poll.c:76): callback returned error status [proxy:0:6@dfw-camx-n6] main (pm/pmiserv/pmip.c:206): demux engine error waiting for event [proxy:0:5@dfw-camx-n5] HYD_pmcd_pmip_control_cmd_cb (pm/pmiserv/pmip_cb.c:885): assert (!closed) failed [proxy:0:5@dfw-camx-n5] HYDT_dmxu_poll_wait_for_event (tools/demux/demux_poll.c:76): callback returned error status [proxy:0:5@dfw-camx-n5] main (pm/pmiserv/pmip.c:206): demux engine error waiting for event [proxy:0:7@dfw-camx-n7] HYD_pmcd_pmip_control_cmd_cb (pm/pmiserv/pmip_cb.c:885): assert (!closed) failed [proxy:0:7@dfw-camx-n7] HYDT_dmxu_poll_wait_for_event (tools/demux/demux_poll.c:76): callback returned error status [proxy:0:7@dfw-camx-n7] main (pm/pmiserv/pmip.c:206): demux engine error waiting for event [mpiexec@dfw-camx] HYDT_bscu_wait_for_completion (tools/bootstrap/utils/bscu_wait.c:76): one of the processes terminated badly; aborting [mpiexec@dfw-camx] HYDT_bsci_wait_for_completion (tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion [mpiexec@dfw-camx] HYD_pmci_wait_for_completion (pm/pmiserv/pmiserv_pmci.c:218): launcher returned error waiting for completion [mpiexec@dfw-camx] main (ui/mpich/mpiexec.c:344): process manager error waiting for completion
This is what I got from the exitallcodes.
Anything helpful??
Thank you very much for all help Abhishek
From: Seo, Sangmin [mailto:[email protected]] Sent: Wednesday, September 17, 2014 1:17 PM To: Abhishek Bhat Subject: Re: [mpich-discuss] Error Running MPICH for Photochemical Modeling
On Sep 17, 2014, at 1:08 PM, Abhishek Bhat <[email protected]> wrote:
Sangmin,
What should be the correct syntax for print all exitcodes - If I use
if( ! { mpiexec -machinefile nodes -np $NUMPROCS -print-all-exitcodes $EXEC -mpich-dbg=file -mpich-dbg-class=all -mpich-dbg-level=verbose } )
This is correct. And, the output will be shown on your terminal, not in file, like: [mpiexec@host] Exit codes: [host] 0,0
I am getting error saying "-print-all-exitcodes" is not a valid local parameters
Which version of MPICH are you using? Can you let me know the result of the following? $ mpiexec -info
- Sangmin
______________________________________________________________________ ___
The information transmitted is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you received this in error, please contact the sender and delete the material from any computer. ______________________________________________________________________ ___ _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- _________________________________________________________________________
The information transmitted is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you received this in error, please contact the sender and delete the material from any computer. _________________________________________________________________________ <Application.zip>
participants (1)
Lu, Huiwei
