problems with installing mpich: library missed
Hello everyone! I am trying to install mpich in order to use PARDISO project 5.0.0 (cluster MPI version for distributed memory machines), and since it fails during the compilation with the errors ld: warning: libmpich.so.3, needed by /ifs/home/icmmg/voronin/pardiso_proekt/pardiso_project/new/libpardiso500-MPI-INTEL1301-X86-64.so, not found (try using -rpath or -rpath-link) ld: warning: libpmi.so.0, needed by /ifs/home/icmmg/voronin/pardiso_proekt/pardiso_project/new/libpardiso500-MPI-INTEL1301-X86-64.so, not found (try using -rpath or -rpath-link) ld: warning: liblimic2.so.0, needed by /ifs/home/icmmg/voronin/pardiso_proekt/pardiso_project/new/libpardiso500-MPI-INTEL1301-X86-64.so, not found (try using -rpath or -rpath-link) I thought something related to mpich is missing (I found mpich mvapich2-x-1.9-6 installed on the main node but the required libraries were missing). Following the MPICH Installer's guide I tried to install the latest version of mpich into my home directory (with --enable-shared option) on the cluster, but only libmpich.so appears (and some other stuff which looks very far from the names of the libraries I need). No traces of libpmi.s0.0 or liblimic2.so.0 and the wrong version of libimpich.so. Can you give an idea why this happened or how can I deal with this problem? Thank you in advance! -- Kind regards, Kirill Voronin
participants (1)
Kirill Voronin
