Re: [mpich-discuss] spurious lock ups on collective merge intercom
Thank you, Kenneth. Here is a simple C++ equivalent of what i am doing: server.cpp: ============================= #include <iostream> #include <mpi/mpi.h> #include <stdlib.h> using namespace std; // The only argument must be the number of processes in communicator we expect to build. int main(int argc, char** argv) { int np = atoi(argv[1]); int ac = 0; MPI_Init(&ac, &argv); char portName[MPI_MAX_PORT_NAME]; MPI_Open_port(MPI_INFO_NULL, portName); cout << portName << "\n"; MPI_Comm intercomm, intracomm = MPI_COMM_SELF; // Build an intracom dynamically until n processes are reached. for (int i = 1; i < np; i++) { MPI_Comm_accept(portName, MPI_INFO_NULL, 0, intracomm, &intercomm); cout << "Accepted.\n"; MPI_Intercomm_merge(intercomm, false, &intracomm); cout << "Merged to an intracom.\n"; MPI_Comm_free(&intercomm); } // Intracomm contains the one we can now use with n-grid. MPI_Comm_free(&intracomm); MPI_Close_port(portName); MPI_Finalize(); } client.cpp: =============================== #include <iostream> #include <mpi/mpi.h> #include <stdlib.h> using namespace std; // This expects intracom size and the port name to connect to. // When using with shell, use single quotas to avoid shell substitution. int main(int argc, char** argv) { int ac = 0; MPI_Init(&ac, &argv); int np = atoi(argv[1]); char* portName = argv[2]; cout << "Connecting to " << portName << "\n"; MPI_Comm intercomm, intracomm; MPI_Comm_connect(portName, MPI_INFO_NULL, 0, MPI_COMM_SELF, &intercomm); cout << "Connected.\n"; MPI_Intercomm_merge(intercomm, true, &intracomm); cout << "Merged.\n"; MPI_Comm_free(&intercomm); int i; MPI_Comm_size(intracomm, &i); // Build an intracom dynamically until n processes are reached. for (; i < np; i++) { MPI_Comm_accept(portName, MPI_INFO_NULL, 0, intracomm, &intercomm); cout << "Accepted.\n"; MPI_Intercomm_merge(intercomm, false, &intracomm); cout << "Merged to an intracom.\n"; MPI_Comm_free(&intercomm); } // Intracomm contains the one we can now use with n-grid. MPI_Comm_free(&intracomm); MPI_Finalize(); } ============================ Run example on one machine, intracom size=2 (in this case I have run 3.3a) dmitriy@Intel-Kubu:~/projects/mpitests$ mpic++ server.cpp -o server dmitriy@Intel-Kubu:~/projects/mpitests$ mpic++ client.cpp -o client dmitriy@Intel-Kubu:~/projects/mpitests$ dmitriy@Intel-Kubu:~/projects/mpitests$ dmitriy@Intel-Kubu:~/projects/mpitests$ mpiexec ./server 2 tag#0$description#Intel-Kubu$port#39210$ifname#127.0.1.1$ Accepted. Merged to an intracom. dmitriy@Intel-Kubu:~/projects/mpitests$ (in another shell) dmitriy@Intel-Kubu:~/projects/mpitests$ mpiexec ./client 2 'tag#0$description#Intel-Kubu$port#39210$ifname#127.0.1.1$' Connecting to tag#0$description#Intel-Kubu$port#39210$ifname#127.0.1.1$ Connected. Merged. dmitriy@Intel-Kubu:~/projects/mpitests$ First parameter is eventual size of intracom we are trying to build dynamically, and client also needs to know the port reported by server process. So there's therfore 1 server and (n-1) clients that connect to form the intracom. Now, if i do that for 192 processes on a 192 core cluster (occasionally slightly overloaded in terms of cpu load), I more often get a lock-up than not. The incidence is more frequent for 3.2 than 3.3a2. This cluster has mellanox infiniband. 3.2 usually locks up on merge intercom call; and 3.3a2 locked up at least once on 2 clients connected and waiting on merge intercom at the same time (but my understanding only one client should be connected at a time, even if there massive connects pending from other clients). Hope this gives a little more material. -Dmitriy On Fri, Feb 3, 2017 at 8:40 AM, Kenneth Raffenetti <[email protected]> wrote:
Hi Dmitriy,
MPICH does appear to be reported a process exit/crash in this case. A simple reproducer would be useful to test if that is indeed the cause or if there's something else going on.
I see below that you are using a non-standard MPI binding. If the test case is simple enough, we can try to port it and investigate further.
Ken
On 01/19/2017 06:58 PM, Dmitriy Lyubimov wrote:
These lock-ups seem to be gone in 3.3a2.
I do occasionally get the following though:
Unknown error class, error stack: PMPI_Comm_accept(129).................: MPI_Comm_accept(port="tag#0$description#aaa.com <http://aaa.com>$port#36230$ifname#192.168.42.99$", MPI_INFO_NULL, ro ot=180, comm=0x84000003, newcomm=0x7f3cf681842c) failed MPID_Comm_accept(153).................: MPIDI_Comm_accept(1244)...............: MPIR_Get_contextid_sparse_group(499)..: MPIR_Allreduce_impl(755)..............: MPIR_Allreduce_intra(414).............: MPIDU_Complete_posted_with_error(1137): Process failed
What does this message mean? some process just exited/died (like with seg fault?)
Thank you. -Dmitriy
On Thu, Jan 12, 2017 at 11:55 AM, Dmitriy Lyubimov <[email protected] <mailto:[email protected]>> wrote:
further debugging shows that it's not actually mergeIntercom that locks up but a pair of send/recv that two nodes decide to execute before MPI_intercom_merge.
so the total snapshot of the situation is that everyone waits on mergeIntercom except for two processes that wait in send/recv respectively, while majority of others already have entered collective barrier.
it would seem that this sort of assymetric logic would be acceptable, since the send/recv pair is balanced before the merge is to occur, but in practice it seems to lock up -- increasingly so as the number of participating processes increases. It almost like once collective barrier of certain cardinality is formed, point-to-point messages are not going thru any longer.
If this scenario begets any ideas, please let me know.
thank you! -Dmitriy
On Wed, Jan 11, 2017 at 9:38 AM, Dmitriy Lyubimov <[email protected] <mailto:[email protected]>> wrote:
Maybe it has something to do with the fact that it is stepping thru JVM JNI and that somehow screws threading model of MPI, although it is a single threaded JVM process, and MPI mappings are known to have been done before (e.g., openmpi had an effort towards that).
Strange thing is that i never had lock up with # of processes under 120 but something changes after that, the spurious condition becomes much more common after that. By the time I am at 150 processes in the intercom, I am almost certain to have a merge lock-up.
On Wed, Jan 11, 2017 at 9:34 AM, Dmitriy Lyubimov <[email protected] <mailto:[email protected]>> wrote:
Thanks. it would not be easy for me to do immediately as i am using proprietary scala binding api for MPI.
it would help me to know if there's a known problem like that in the past, or generally mergeIntercomm api is known to work on hundreds of processes. Sounds like there are no known issues with that.
On Tue, Jan 10, 2017 at 11:53 PM, Oden, Lena <[email protected] <mailto:[email protected]>> wrote:
Hello Dmittiy,
can you maybe create a simple example-program to reproduce this failure? It is also often easier also to look at a code example to identify a problem.
Thanks, Lena > On Jan 11, 2017, at 2:45 AM, Dmitriy Lyubimov <[email protected] <mailto:[email protected]>> wrote: > > Hello, > > (mpich 3.2) > > I have a scenario when i add a few extra processes do existing intercom. > > it works as a simple loop -- > (1) n processes accept on n-intercom > (2) 1 process connects > (3) intracom is merged into n+1 intercom, intracom and n-intercom are closed > (4) repeat 1-3 as needed. > > Occasionally, i observe that step 3 spuriously locks up (once i get in the range of 100+ processes). From what i can tell, all processes in step 3 are accounted for, and are waiting on the merge, but nothing happens. the collective barrier locks up. > > I really have trouble resolving this issue, any ideas are appreciated! > > Thank you very much. > -Dmitriy > > > _______________________________________________ > discuss mailing list [email protected] <mailto:[email protected]> > To manage subscription options or unsubscribe: > https://lists.mpich.org/mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss>
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss>
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Dmitriy Lyubimov
