Re: [mpich-discuss] gather, send
Just before the call to gather, check the value of send_count and check that send_buffer is not all zeros. send_count has to be the same on all ranks. Otherwise you have to use Gatherv. On May 1, 2013, at 7:03 PM, Ryan Crocker wrote:
that's where i checked it with and it's min and max are still zero. I just amended it so that each send buffer from the different cores are the same size and when i check it on the root gsend_buffer is still incorrect.
On May 1, 2013, at 5:00 PM, Rajeev Thakur wrote:
gsend_buffer will be valid only on the root.
On May 1, 2013, at 6:55 PM, Ryan Crocker wrote:
I just looked at the gsend_buffer, that's actually all zeros as well, and each send_buffer is not. So i think my problem is there.
On May 1, 2013, at 4:47 PM, Rajeev Thakur wrote:
The count passed to MPI_Scatter should be the local size, i.e., the amount that gets sent to each process. Looks like what is being passed is the global size.
On May 1, 2013, at 6:21 PM, Ryan Crocker wrote:
Hi all,
So i don't know what the issue with this code snippet is but i cannot get the scatter call to work. When i print out the recieve_buffer it comes out as all zeros. The counters without the underscore are the core domains, with the o, the global domains.
rec_count = (imaxo-imino+1)*(jmaxo-jmino+1)*(kmaxo-kmino+1) send_count = (imax_-imin_+1)*(jmax_-jmin_+1)*(kmax_-kmin_+1)
call MPI_GATHER (send_buffer, send_count, MPI_REAL, gsend_buffer, send_count, MPI_REAL, iroot, comm, ierr)
rec_count = (imaxo-imino+1)*(jmaxo-jmino+1)*(kmaxo-kmino+1) send_count = (imaxo-imino+1)*(jmaxo-jmino+1)*(kmaxo-kmino+1)
call MPI_SCATTER (gsend_buffer, send_count, MPI_REAL, recieve_buffer, rec_count, MPI_REAL, iroot, comm, ierr)
thanks for the help.
Ryan Crocker University of Vermont, School of Engineering Mechanical Engineering Department [email protected]
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
Ryan Crocker University of Vermont, School of Engineering Mechanical Engineering Department [email protected] 315-212-7331
participants (1)
Rajeev Thakur
