Re: [mpich-discuss] Fwd: MPICH fault tolerance and resiliency
I still cannot follow what you are trying to do. The terminology is confusing (what are "app instance", machine, etc.). Using MPI/Hydra terminology would help. Maybe MPI process instead of instance and cluster node instead of machine? Also, I would like to know how MPI terminology maps to the models you described. Do you mean using comm_spawn for parent-child and comm_connect/comm_accept for the client-server model? Having some source code would be much more productive too. Halim www.mcs.anl.gov/~aamer On 5/26/17 10:40 AM, sanjeev s wrote:
In dynamic process, I read about two models: Client server and parent child.
Client Server : We need to have dedicated threads each for client and server. Now considering all instances same , we will end up doing lot of thread creation apart from our application worker threads. Moreover when 1 instance (app) goes down, we want that instance to come up without doing much manual work. We don't want to club this logic in our application. Also, When I took the size(number of instance for that comm), I am not getting the count for client instance. To distribute the task, I need to have additional logic to handle this case in my application.
2) Parent child: Suppose we have started 4 instance on 4 different machines. Now we need to add another server. I don't think parent child/ client server is good option in this case.
We don't want to build process management capabilities in our application. We are looking for process management in MPI itself (e.g in Hydra )so that we can leverage on that.
Please correct me if I am missing something in my understanding of Dynamic model.
Regards Sanjeev Sinha
On Fri, May 26, 2017 at 8:46 PM, Halim Amer <[email protected]> wrote:
Sanjeev,
More precisely my requirement is suppose I started 4 instances of my application. Now I want to add one more instance dynamically to this set
From my understanding, dynamic processes would work fine for this case. Could you elaborate on why the dynamic process model is not sufficient for your needs?
On 5/26/17 9:11 AM, sanjeev s wrote:
Hi mpich,
I have a requirement where in we need to add start stop application instances on the fly before starting a job.Is there any mpich service available. I looked through dynamic process model, but its not sufficing our need.
Is there any tool which MPICH supports for fault tolerance behavior?
Thanks Sanjeev
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Halim Amer
