Re: [mpich-discuss] Missing Nemesis ib
I seems you have mismatch in the OFED stack. Try installing the Mellanox OFED stack if you are using the bundled OFED stack right now. Make sure MXM works before trying MPICH. Use the mxm/bin/mxm_perftest from your MXM installation to test that things work properly. If it doesn't work, then contact your admin or Mellanox cause it is not an MPICH problem. Halim www.mcs.anl.gov/~aamer On 9/19/17 7:14 AM, Jason Collins wrote:
Thank you very much.
I have compiled with "CH3:nemesis:mxm". The compilation was successful.
Now I have a new problem. I tested the test "./icp" and get the following error.
# mpiexec -f hosts -n 4 ./cpi [1505822776.546898] [compute1:16212:0] sys.c:744 MXM WARN Conflicting CPU frequencies detected, using: 3459.84 [1505822776.546898] [compute1:16213:0] sys.c:744 MXM WARN Conflicting CPU frequencies detected, using: 3459.84 [1505822776.546951] [compute1:16216:0] sys.c:744 MXM WARN Conflicting CPU frequencies detected, using: 3459.84 [1505822776.547039] [compute1:16214:0] sys.c:744 MXM WARN Conflicting CPU frequencies detected, using: 3459.84 [1505822776.561357] [compute1:16214:0] ib_dev.c:533 MXM WARN failed call to ibv_exp_use_priv_env(): Function not implemented [1505822776.561371] [compute1:16214:0] ib_dev.c:544 MXM ERROR ibv_query_device() returned 38: Function not implemented [1505822776.561386] [compute1:16218:0] ib_dev.c:533 MXM WARN failed call to ibv_exp_use_priv_env(): Function not implemented [1505822776.561396] [compute1:16218:0] ib_dev.c:544 MXM ERROR ibv_query_device() returned 38: Function not implemented [1505822776.561426] [compute1:16225:0] ib_dev.c:533 MXM WARN failed call to ibv_exp_use_priv_env(): Function not implemented [1505822776.561442] [compute1:16225:0] ib_dev.c:544 MXM ERROR ibv_query_device() returned 38: Function not implemented Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(474).........: MPID_Init(190)................: channel initialization failed MPIDI_CH3_Init(89)............: MPID_nem_init(320)............: MPID_nem_mxm_init(158)........: MPID_nem_mxm_get_ordering(464): mxm_init failed (Input/output error)
El vie., 15 sept. 2017 a las 16:01, Halim Amer (<[email protected] <mailto:[email protected]>>) escribió:
The "nemesis:ib" netmod does not exist anymore. Try "ch3:nemesis:mxm" with a dependency on Mellanox's MXM library (can be obtained from the HPCX package at www.mellanox.com/products/hpcx <http://www.mellanox.com/products/hpcx>) or "ch3:nemesis:ofi" with a dependency on libfabric (which would be built to support the IB or MXM providers; see https://ofiwg.github.io/libfabric/).
Halim www.mcs.anl.gov/~aamer <http://www.mcs.anl.gov/~aamer>
On 9/15/17 4:20 AM, Jason Collins wrote: > Hello everyone. > > Recently, I downloaded Mpich-3.2 > > I want to configure with support for InfiniBand. I've put the following > command: > > # ./configure --prefix=/my/path --with-device=ch3:nemesis:ib > > And I get the following error: > > configure: error: Network module ib is unknown > "./src/mpid/ch3/channels/nemesis/netmod/ib" > > When I check the path I confirm that in the folder "netmod" does not > exist the folder "ib". How can this be solved? > > Many thanks. > <https://audio1.spanishdict.com/audio?lang=en&text=when-i-check-the-path-i-confirm-that-within-the-folder-netmod-the-folder-does-not-exist-ib-how-can-this-be-solved-many-thanks> > > > _______________________________________________ > discuss mailing list [email protected] <mailto:[email protected]> > To manage subscription options or unsubscribe: > https://lists.mpich.org/mailman/listinfo/discuss > _______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Halim Amer
