Re: [mpich-discuss] libmpi.so.12 error
To find /home/rpimpi/mpich3-install/bin/mpiexec first, you can set the PATH variable in your .bashrc (or .profile) file like: export PATH=/home/rpimpi/mpich3-install/bin:$PATH — Sangmin On Sep 9, 2014, at 9:21 AM, Sophie Norman <[email protected]<mailto:[email protected]>> wrote: Oops there is a version of OpenMPI on the system that is didn't find before. Sangmin thank you, here are the two different versions $ /usr/bin/mpiexec --versionmpiexec (OpenRTE) 1.4.5 Report bugs to http://www.open-mpi.org/community/help/ $ /home/rpimpi/mpich3-install/bin/mpiexec --version HYDRA build details: Version: 3.1.2 Release Date: Mon Jul 21 16:00:21 CDT 2014 CC: gcc CXX: g++ F77: gfortran F90: gfortran Configure options: '--disable-option-checking' '--prefix=/home/rpimpi/mpich3-install' '--enable-shared' '--cache-file=/dev/null' '--srcdir=/home/pi/mpich3/mpich-3.1.2/src/pm/hydra' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread ' 'CPPFLAGS= -I/home/pi/mpich3/src/mpl/include -I/home/pi/mpich3/mpich-3.1.2/src/mpl/include -I/home/pi/mpich3/mpich-3.1.2/src/openpa/src -I/home/pi/mpich3/src/openpa/src -D_REENTRANT -I/home/pi/mpich3/src/mpi/romio/include' Process Manager: pmi Launchers available: ssh rsh fork slurm ll lsf sge manual persist Topology libraries available: hwloc Resource management kernels available: user slurm ll lsf sge pbs cobalt Checkpointing libraries available: Demux engines available: poll select Running the system so that it is MPICH that runs allowed the system to work as it should! so thank you all for your help. Just one last question, how can I set it so that it is the MPICH configuration that runs not the OpenMPI without having to type /home/rpimpi/mpich3-install/bin/mpiexec each time? Yours happily Sophie On 9 September 2014 15:01, Seo, Sangmin <[email protected]<mailto:[email protected]>> wrote: Did you install MPICH-3.1.2 to /home/rpimpi/mpich3-install/? If so and you did not specify --bindir, /usr/bin/mpiexec might be installed by a different MPI implementation. Can you try these? /usr/bin/mpiexec --version /home/rpimpi/mpich3-install/bin/mpiexec --version If they are different, can you also try to use /home/rpimpi/mpich3-install/bin/mpiexec to execute your application? — Sangmin On Sep 9, 2014, at 8:44 AM, Sophie Norman <[email protected]<mailto:[email protected]>> wrote: Sure Sangmin, here you go $ mpiexec -n 4 -machinefile /home/pi/mpi_testing/machinefile which mpiexec /usr/bin/mpiexec /usr/bin/mpiexec /usr/bin/mpiexec /usr/bin/mpiexec Sophie On 9 September 2014 13:27, Seo, Sangmin <[email protected]<mailto:[email protected]>> wrote: To verify the path to mpiexec on nodes, can you try the following? mpiexec -n 4 -machinefile /home/pi/mpi_testing/__machinefile which mpiexec — Sangmin On Sep 9, 2014, at 6:37 AM, Sophie Norman <[email protected]<mailto:[email protected]>> wrote: I've looked and there's definitely no OpenMPI installation, there is however a Python-mpi4py installation, could that be causing the problem? On 9 September 2014 12:08, Kenneth Raffenetti <[email protected]<mailto:[email protected]>> wrote: That looks like an error message from OpenMPI's mpiexec. That is surely part of the problem here. Do you have an OpenMPI installation somewhere that may be conflicting with your MPICH? One solution would be to make sure that the path to MPICH's mpiexec is first in your environment. Ken On 09/09/2014 05:31 PM, Sophie Norman wrote: Hi Ken When I run that code I get the following error -------------------------------------------------------------------------- mpiexec was unable to launch the specified application as it could not find an executable: Executable: -l Node: raspberrypi while attempting to start process rank 0. -------------------------------------------------------------------------- Sophie On 9 September 2014 02:07, Kenneth Raffenetti <[email protected]<mailto:[email protected]> <mailto:[email protected]<mailto:[email protected]>>> wrote: Let's try to verify that the library is properly located on all the nodes you are running. We can do a simple test with mpiexec. Try running: mpiexec -n 4 -machinefile /home/pi/mpi_testing/____machinefile -l ls /home/rpimpi/mpich3-install/__lib/libmpi.so.12 Ken On 09/08/2014 07:03 PM, Sophie Norman wrote: Hi Ken, Yes I used mpicc to build the binary the oputput of mpicc -show is gcc -I/home/rpimpi/mpich3-install/__include -L/home/rpimpi/mpich3-install/__lib -Wl,-rpath -Wl,/home/rpimpi/mpich3-__install/lib -Wl,--enable-new-dtags -lmpi -lrt -lpthread Sophie On 9 September 2014 00:48, Kenneth Raffenetti <[email protected]<mailto:[email protected]> <mailto:[email protected]<mailto:[email protected]>> <mailto:[email protected]<mailto:[email protected]> <mailto:[email protected]<mailto:[email protected]>>>> wrote: Did you use mpicc to build your binary? What is the output of 'mpicc -show'. The compile wrappers should encode an RPATH tag in your program so that setting an LD_LIBRARY_PATH to find libmpi.so is unncessary. Ken On 09/08/2014 06:44 PM, Sophie Norman wrote: Hi, When running NAS parallel benchmarks using 4 Raspberry Pi nodes each running MPICH-3.1.2 I get the following error when I try to run the integer sort benchmark ~/NPB3.3/NPB3.3-MPI/bin $ mpiexec -n 4 -machinefile /home/pi/mpi_testing/____machinefile ./is.S.4 NAS Parallel Benchmarks 3.3 -- IS Benchmark Size: 65536 (class S) Iterations: 10 Number of processes: 1 ERROR: compiled for 4 processes Number of active processes: 1 Exiting program! ./is.S.4: error while loading shared libraries: libmpi.so.12: cannot open shared object file: No such file or directory ./is.S.4: error while loading shared libraries: libmpi.so.12: cannot open shared object file: No such file or directory ./is.S.4: error while loading shared libraries: libmpi.so.12: cannot open shared object file: No such file or directory I have tried export LD_LIBRARY_PATH=$LD_LIBRARY_____PATH:/home/rpimpi/mpich3-____install/lib on each of the nodes, and each node works individually when run with the file ./is.S.1 $ldd ./is.S.4 give the following output for the master node /usr/lib/arm-linux-gnueabihf/____libcofi_rpi.so (0xb6edf000) libmpi.so.12 => /home/rpimpi/mpich3-install/____lib/libmpi.so.12 (0xb6ca3000) libc.so.6 => /lib/arm-linux-gnueabihf/libc.____so.6 (0xb6b68000) librt.so.1 => /lib/arm-linux-gnueabihf/____librt.so.1 (0xb6b59000) libpthread.so.0 => /lib/arm-linux-gnueabihf/____libpthread.so.0 (0xb6b3a000) libgfortran.so.3 => /usr/lib/arm-linux-gnueabihf/____libgfortran.so.3 (0xb6a93000) libm.so.6 => /lib/arm-linux-gnueabihf/libm.____so.6 (0xb6a22000) libgcc_s.so.1 => /lib/arm-linux-gnueabihf/____libgcc_s.so.1 (0xb69fa000) /lib/ld-linux-armhf.so.3 (0xb6eed000) please help Thanks Sophie ___________________________________________________ discuss mailing list [email protected]<mailto:[email protected]> <mailto:[email protected]<mailto:[email protected]>> <mailto:[email protected]<mailto:[email protected]> <mailto:[email protected]<mailto:[email protected]>>> To manage subscription options or unsubscribe: https://lists.mpich.org/____mailman/listinfo/discuss <https://lists.mpich.org/__mailman/listinfo/discuss> <https://lists.mpich.org/__mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss>> ___________________________________________________ discuss mailing list [email protected]<mailto:[email protected]> <mailto:[email protected]<mailto:[email protected]>> <mailto:[email protected]<mailto:[email protected]> <mailto:[email protected]<mailto:[email protected]>>> To manage subscription options or unsubscribe: https://lists.mpich.org/____mailman/listinfo/discuss <https://lists.mpich.org/__mailman/listinfo/discuss> <https://lists.mpich.org/__mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss>> _________________________________________________ discuss mailing list [email protected]<mailto:[email protected]> <mailto:[email protected]<mailto:[email protected]>> To manage subscription options or unsubscribe: https://lists.mpich.org/__mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss> _________________________________________________ discuss mailing list [email protected]<mailto:[email protected]> <mailto:[email protected]<mailto:[email protected]>> To manage subscription options or unsubscribe: https://lists.mpich.org/__mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss> _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Seo, Sangmin
