Re: [mpich-discuss] MPI_Comm_spawn crosses node boundaries
Ken, I confirmed that MPI_Comm_spawn fails completely if I build MPICH without the PMI2 option. Looking at the Slurm documentation https://slurm.schedmd.com/mpi_guide.html#intel_mpiexec_hydra it states "All MPI_comm_spawn work fine now going through hydra's PMI 1.1 interface." The full quote is below for reference. 1) how do I build MPICH to support hydra's PMI 1.1 interface? 2) Can you offer any guesses on how to build Slurm to do the same? (I realize this isn't a Slurm forum 😊) Thanks, Kurt =========== Full quote =============== MPICH2 with mpiexec Do not add any flags to mpich and build the default (e.g. "./configure -prefix ... ". Do NOT pass the --with-slurm, --with-pmi, --enable-pmiport options). Do not add -lpmi to your application (it will force slurm's pmi 1 interface which doesn't support PMI_Spawn_multiple). Launch the application using salloc to create the job allocation and mpiexec to launch the tasks. A simple example is shown below. salloc -N 2 mpiexec my_application All MPI_comm_spawn work fine now going through hydra's PMI 1.1 interface. -----Original Message----- From: Mccall, Kurt E. (MSFC-EV41) via discuss <[email protected]> Sent: Friday, January 28, 2022 1:43 PM To: Raffenetti, Ken <[email protected]>; [email protected] Cc: Mccall, Kurt E. (MSFC-EV41) <[email protected]> Subject: [EXTERNAL] Re: [mpich-discuss] MPI_Comm_spawn crosses node boundaries I have built in the past without the pmi2 option, and MPI_Comm_spawn doesn't work at all. My memory is a little fuzzy, so I'll try that to make sure. In the meantime, can you recommend an option with which to build Slurm that MPICH also supports and has tested? Here is what we have now: $ srun --mpi=list srun: MPI types are... srun: cray_shasta srun: pmi2 srun: none -----Original Message----- From: Raffenetti, Ken <[email protected]<mailto:[email protected]>> Sent: Friday, January 28, 2022 1:35 PM To: Mccall, Kurt E. (MSFC-EV41) <[email protected]<mailto:[email protected]>>; [email protected]<mailto:[email protected]> Subject: [EXTERNAL] Re: [mpich-discuss] MPI_Comm_spawn crosses node boundaries I'm just now realizing that we don't test spawn functionality with our pmi2 implementation. Can you try rebuilding without that option and see if it works as expected? Ken On 1/28/22, 1:18 PM, "Mccall, Kurt E. (MSFC-EV41)" <[email protected]<mailto:[email protected]>> wrote: ../mpich-4.0rc3/configure --prefix=/opt/mpich --with-pmi=pmi2/simple --with-device=ch3:nemesis --disable-fortran -enable-debuginfo --enable-g=debug -----Original Message----- From: Raffenetti, Ken <[email protected]<mailto:[email protected]>> Sent: Friday, January 28, 2022 1:16 PM To: Mccall, Kurt E. (MSFC-EV41) <[email protected]<mailto:[email protected]>>; [email protected]<mailto:[email protected]> Subject: [EXTERNAL] Re: [mpich-discuss] MPI_Comm_spawn crosses node boundaries From what I can tell, the info keyvals are not being sent to the process manager, which would explain what you are seeing. Need to investigate why that is happening next. What is your MPICH ./configure line? That'll help narrow where to look. Ken On 1/28/22, 12:49 PM, "Mccall, Kurt E. (MSFC-EV41)" <[email protected]<mailto:[email protected]>> wrote: Ken, There is a lot of my own output mixed up in the "mpiexec -v" output. I hope you can make sense of this. Thanks, Kurt -----Original Message----- From: Raffenetti, Ken <[email protected]<mailto:[email protected]>> Sent: Friday, January 28, 2022 12:36 PM To: Mccall, Kurt E. (MSFC-EV41) <[email protected]<mailto:[email protected]>>; [email protected]<mailto:[email protected]> Subject: [EXTERNAL] Re: [mpich-discuss] MPI_Comm_spawn crosses node boundaries "ip_address" won't be recognized, only "host", "hosts", or "hostfile". Could you run an example using "mpiexec -v" and capture/share the output? That should help tell us if the hostname information is being fed correctly to the process manager by the spawn command. Ken On 1/28/22, 11:35 AM, "Mccall, Kurt E. (MSFC-EV41)" <[email protected]<mailto:[email protected]>> wrote: Ken, I'm using sbatch, which calls a bash script that calls mpiexec (4.0rc3). Which host name convention is correct, the short or the long host name? Would the "ip_address" info key work? Kurt -----Original Message----- From: Raffenetti, Ken <[email protected]<mailto:[email protected]>> Sent: Friday, January 28, 2022 10:49 AM To: [email protected]<mailto:[email protected]> Cc: Mccall, Kurt E. (MSFC-EV41) <[email protected]<mailto:[email protected]>> Subject: [EXTERNAL] Re: [mpich-discuss] MPI_Comm_spawn crosses node boundaries Are you using mpiexec or srun when initially launching your job? Hydra (mpiexec) should support the "host" info key, but I'm not sure if srun will. Ken On 1/28/22, 10:41 AM, "Mccall, Kurt E. (MSFC-EV41) via discuss" <[email protected]<mailto:[email protected]>> wrote: Hi, Running MPICH under Slurm, MPI_Comm_spawn unexpectedly creates new processes on any and all of the nodes that Slurm allocates to the job. I would like it to only create new processes locally on the node that called MPI_Comm_spawn. I’ve tried passing MPI_Comm_spawn an info struct created like this: MPI_Info info; MPI_Info_create(&info); MPI_Info_set(info, "host", host_name); MPI_Info_set(info, "bind_to", "core"); where hostname = “n001” or even the full name “n001.cluster.pssclabs.com” but that doesn’t prevent the problem. Any suggestions? Thanks, Kurt _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://gcc02.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.mpich.org%2Fmailman%2Flistinfo%2Fdiscuss&data=04%7C01%7Ckurt.e.mccall%40nasa.gov%7C132072f5f8994f8cb31308d9e2966ce7%7C7005d45845be48ae8140d43da96dd17b%7C0%7C0%7C637789957980739463%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=5q%2FzYyNnO9HMxQ%2Bq1xDDaCLC06vCuCDolIuS1Oe%2FLNo%3D&reserved=0
participants (1)
