Re: [mpich-discuss] discuss Digest, Vol 8, Issue 39
Hi Jeff, Please correct me where I'm wrong: if only one thread calls MPI_Barrier, that one will get locked while others will go ahead. On the other hand, if every thread calls MPI_Barrier, all will get locked in that call until the barrier completes. That doesn't mean this will be a replacement for thread-wise synchronization mechanisms, but will be effective for all of them waiting for the barrier. Antonio On Monday, June 24, 2013 04:14:20 PM Jeff Hammond wrote:
MPI_Barrier will not sync threads. If N threads call MPI_Barrier, you will get at best the same result as if you call MPI_Barrier N times from the main thread.
If you want to sync threads, you need to sync them with the appropriate thread API. OpenMP and Pthreads both have barrier calls. If you want a fast Pthread barrier, you should not use pthread_barrier though. The Internet has details.
Jeff
----- Original Message ----- From: "Antonio J. Peña" <[email protected]> To: [email protected] Sent: Monday, June 24, 2013 3:49:08 PM Subject: Re: [mpich-discuss] discuss Digest, Vol 8, Issue 39
Sufeng,
I'd say you're OK syncing your threads by all of them calling MPI_Barrier, as it's a thread-safe function.
Antonio
On Monday, June 24, 2013 11:41:44 AM Sufeng Niu wrote:
Hi, Antonio
Thanks a lot! Now I make sense. Let's say if I am running MPI and multithreads program. If I called MPI_Barrier in each threads
what gonna happen? Will threads be synced by MPI_Barrier? or I should use thread level sync?
Thank you!
Sufeng
On Sun, Jun 23, 2013 at 6:54 PM, < [email protected] > wrote:
Send discuss mailing list submissions to [email protected]
To subscribe or unsubscribe via the World Wide Web, visit https://lists.mpich.org/mailman/listinfo/discuss or, via email, send a message with subject or body 'help' to [email protected]
You can reach the person managing the list at [email protected]
When replying, please edit your Subject line so it is more specific than "Re: Contents of discuss digest..."
Today's Topics:
1. Re: Error with MPI_Spawn (Jeff Hammond) 2. Re: discuss Digest, Vol 8, Issue 37 (Antonio J. Pe?a)
Message: 1 Date: Sun, 23 Jun 2013 17:03:09 -0500 From: Jeff Hammond < [email protected] > To: " [email protected] " < [email protected] > Subject: Re: [mpich-discuss] Error with MPI_Spawn Message-ID: <-1578386667793986954@unknownmsgid> Content-Type: text/plain; charset=ISO-8859-1
This is the wrong way to use PETSc and to parallelize a code with a parallel library in general.
Write the PETSc user list and they will explain to you how to parallelize your code properly with PETSc.
Jeff
Sent from my iPhone
On Jun 23, 2013, at 4:59 PM, Nitel Muhtaroglu < [email protected] > wrote:
Hello,
I am trying to integrate PETSc library to a serial program. The idea is that the serial program creates a linear equation system and then calls PETSc solver by MPI_Spawn and then solves this system in parallel. But when I execute MPI_Spawn the following error message occurs and the solver is not called. I couldn't find a solution to this error. Does anyone have an idea about it?
Kind Regards,
Message: 2 Date: Sun, 23 Jun 2013 18:54:38 -0500 From: Antonio J. Pe?a < [email protected] > To: [email protected] Subject: Re: [mpich-discuss] discuss Digest, Vol 8, Issue 37 Message-ID: <[email protected]> Content-Type: text/plain; charset="iso-8859-1"
Sufeng,
The correct way is to use the MPI_Init_thread function with MPI_THREAD_MULTIPLE. This will tell the MPI implementation to be thread safe. It supports OpenMP and Posix Threads (OpenMP primitives in most systems are likely to be implemented on top of PThreads).
Antonio
On Sunday, June 23, 2013 11:13:31 AM Sufeng Niu wrote:
Hi, Antonio
Thanks a lot for your reply, I just figure out that is the firewall issue. after I set the firewall. it works now. Thanks again.
But I still got a few questions on MPI and multithreads mixed programming. Currently, I try to run each process on each server, and each process using thread pool to run multiple threads (pthread lib). I am not sure whether it is the correct way or not. I wrote it as:
MPI_Init() .... ... /* create thread pool and initial */ ...... /* fetch job into thread pool */ ......
MPI_Finalize();
When I check the book and notes, I found people use
MPI_Init_thread() with MPI_THREAD_MULTIPLE
but the some docs said it supported OpenMP, is that possible to use it with pthread library? I am new guy to this hybrid programming. I am not sure which is the proper way to do it. Any suggestions are appreciate. Thank you!
Sufeng
On Sat, Jun 22, 2013 at 12:12 PM, < [email protected] [1]> wrote:
Send discuss mailing list submissions to [email protected] [2] https://lists.mpich.org/mailman/listinfo/discuss[3] [email protected] [1] [email protected] [4] [email protected] [5]>To: [email protected] [2] [email protected] om[6]>Content-Type: text/plain; charset="iso-8859-1"
Sorry to bother you guys on this stupid question. last time I re-install OSfor all blades to keep them the same version. after I mount, set keylessssh, the terimnal gives the error below:
[ proxy:0:[email protected] [7]] HYDU_sock_connect(./utils/sock/sock.c:174): unable to connect from " iocfccd3.aps.anl.gov [8]" to" iocfccd1.aps.anl.gov [9]" (No route to host) [ proxy:0:[email protected] [7]] main (./pm/pmiserv/pmip.c:189): unable toconnect to server iocfccd1.aps.anl.gov [9] at port 38242 (check for firewalls!)
I can ssh from iocfccd1 to iocfccd3 without password. Should I shut downall firewalls on each server? I cannot find out where is the problem. Thankyou
--Best Regards,Sufeng NiuECASP lab, ECE department, Illinois Institute of TechnologyTel: 312-731-7219[10] http://lists.mpich.org/pipermail/discuss/attachments/20130621/5503b1bc/a ttachment-0001.html[11] >
Message: 2Date: Fri, 21 Jun 2013 10:58:26 -0500From: Antonio J. Pe?a < [email protected] [12]>To: [email protected] [2] iocfccd1.aps.anl.gov [9]" from iocfccd3?[1]
Antonio
On Friday, June 21, 2013 10:51:50 AM Sufeng Niu wrote:
Sorry to bother you guys on this stupid question. last time I re-install OS forall blades to keep them the same version. after I mount, set keyless ssh,the terimnal gives the error below:
proxy:0:[email protected] [7][2]] HYDU_sock_connect(./utils/sock/sock.c:174): unable to connect from " iocfccd3.aps.anl.gov [8][3]"to " iocfccd1.aps.anl.gov [9][1]" (No route to host)[ proxy:0:[email protected] [7][2]] main (./pm/pmiserv/pmip.c:189):unable to connect to server iocfccd1.aps.anl.gov [9][1] at port 38242 (checkfor firewalls!)
-- Best Regards,Sufeng NiuECASP lab, ECE department, Illinois Institute of TechnologyTel: 312-731-7219[4]
--------[1] _ http://iocfccd1.aps.anl.gov_ proxy%3A0%[email protected] [13] http://iocfccd3.aps.anl.gov [8] 312-731-7219[10] http://lists.mpich.org/pipermail/discuss/attachments/20130621/01b37902/ attachment-0001.html[14] >
Message: 3Date: Sat, 22 Jun 2013 12:49:10 -0400From: Jiri Simsa < [email protected] [15]>To: [email protected] [2] CAHs9ut-_6W6SOHTJ_rD+shQ76bo4cTCuFVAy1f9x- [email protected] [16]>Content-Type: text/plain; charset="iso-8859-1"
participants (1)
Antonio J. Peña
