Re: [mpich-discuss] Error buildingmpich-master-v3.2-88-gbbb40df74d46
Hi Rob, thank you very much for the second patch. Unfortunately it didn't solve the problem completely. I looked around and found two more files which needed your patches. After applying your patches I was able to build the system with both compilers. I patched the following files. loki bt 159 pwd /export2/src/mpich-3.2.1/mpich-master-v3.2-88-gbbb40df74d46/src/pm/hydra/mpl/src/bt loki bt 160 diff mpl_bt.c* 47,51c47 < /* we need not only the symbols but the header file too (for the cursor and < * context), so tighten up when we take the libunwind path. Thanks < * [email protected] for the bug report about systems with < * libunwind libraries but no libunwind development headers */ < #elif defined MPL_HAVE_LIBUNWIND && defined(MPL_HAVE_LIBUNWIND_H) ---
#elif defined MPL_HAVE_LIBUNWIND 125c121 < #elif defined MPL_HAVE_LIBUNWIND && defined(MPL_HAVE_LIBUNWIND_H)
#elif defined MPL_HAVE_LIBUNWIND loki bt 161 loki bt 161 loki bt 161 loki bt 161 cd /export2/src/mpich-3.2.1/mpich-master-v3.2-88-gbbb40df74d46/src/mpi/romio/mpl/src/bt loki bt 162 diff mpl_bt.c* 47,51c47 < /* we need not only the symbols but the header file too (for the cursor and < * context), so tighten up when we take the libunwind path. Thanks < * [email protected] for the bug report about systems with < * libunwind libraries but no libunwind development headers */ < #elif defined MPL_HAVE_LIBUNWIND && defined(MPL_HAVE_LIBUNWIND_H)
#elif defined MPL_HAVE_LIBUNWIND loki bt 163 loki bt 163 loki bt 163 loki bt 163 cd /export2/src/mpich-3.2.1/mpich-master-v3.2-88-gbbb40df74d46/src/mpl/src/bt/ loki bt 164 diff mpl_bt.c mpl_bt.c.orig 47,51c47 < /* we need not only the symbols but the header file too (for the cursor and < * context), so tighten up when we take the libunwind path. Thanks < * [email protected] for the bug report about systems with < * libunwind libraries but no libunwind development headers */ < #elif defined MPL_HAVE_LIBUNWIND && defined(MPL_HAVE_LIBUNWIND_H)
#elif defined MPL_HAVE_LIBUNWIND loki bt 165
I also got a lot of errors for Sun C. I don't know if they break anything or are just a kind of "warning". loki mpich-master-v3.2-88-gbbb40df74d46-Linux.x86_64.64_cc 176 loki mpich-master-v3.2-88-gbbb40df74d46-Linux.x86_64.64_cc 176 grep error: log.make.Linux.x86_64.64_cc | sort | uniq "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/channels/nemesis/include/mpid_nem_datatypes.h", line 156: warning: syntax error: empty member declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/channels/nemesis/include/mpid_nem_datatypes.h", line 161: warning: syntax error: empty member declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/channels/nemesis/src/ch3_win_fns.c", line 17: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/include/mpid_rma_lockqueue.h", line 13: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/include/mpid_rma_lockqueue.h", line 14: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/include/mpid_rma_oplist.h", line 21: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/include/mpidi_recvq_statistics.h", line 13: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_recvq.c", line 100: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_recvq.c", line 103: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_recvq.c", line 95: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_recvq.c", line 96: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_recvq.c", line 97: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_recvq.c", line 98: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_recvq.c", line 99: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_ops.c", line 9: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_pkthandler.c", line 10: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_pkthandler.c", line 11: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_pkthandler.c", line 12: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_pkthandler.c", line 13: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_pkthandler.c", line 14: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_pkthandler.c", line 15: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_pkthandler.c", line 16: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_pkthandler.c", line 17: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_pkthandler.c", line 18: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_pkthandler.c", line 19: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_pkthandler.c", line 20: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_pkthandler.c", line 21: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_pkthandler.c", line 22: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_pkthandler.c", line 23: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_pkthandler.c", line 24: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_pkthandler.c", line 25: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_sync.c", line 259: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_sync.c", line 260: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_sync.c", line 261: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_sync.c", line 263: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_rma_sync.c", line 264: warning: syntax error: empty declaration "../mpich-master-v3.2-88-gbbb40df74d46/src/mpid/ch3/src/ch3u_win_fns.c", line 11: warning: syntax error: empty declaration loki mpich-master-v3.2-88-gbbb40df74d46-Linux.x86_64.64_cc 177 I'll try to test this version later and let you know if something doesn't work as expected. Best regards and thank you very much for your help again Siegmar On 01/19/16 18:45, Rob Latham wrote:
On 01/16/2016 02:35 AM, Siegmar Gross wrote:
Hi Rob,
I've attached the files for both compilers.
It looks like the compiler doesn't matter in your environment.
I did find one more spot to update, and now with your mplconfig.h in place I get no warnings.
From the messages you included, it still looks like MPICH is trying to compile the libunwind functions, even though I've done everything I can to check for that.
If the attached patch does nothing for you, then I will simply remove libunwind support until I can set up a suse virtual machine and figure out what's going on.
==rob
Siegmar
Am 15.01.2016 um 16:55 schrieb Rob Latham:
On 01/15/2016 06:56 AM, Siegmar Gross wrote:
Hi Rob,
I had to change "#if" to "#elif", but I still get errors. I've attached the log files.
OK, you can see what I'm trying to do, yes? On my end, everything I've done to re-create your environment works for me. One more favor: send me your src/mpl/include/mplconfig.h
Thanks ==rob _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Siegmar Gross
