Re: [mpich-discuss] CPU usage versus Nodes, Threads
The cause of low utilization of CPU use can be blocking communications, load imbalance or thread contentions in your application. What MPI calls are you using? Are they blocking or nonblocking? Are the load balanced on each node? What thread level are your using? MPI_THREAD_MULTIPLE or MPI_THREAD_FUNNELED? — Huiwei
On Oct 22, 2014, at 5:02 PM, Qiguo Jing <[email protected]> wrote:
Hi All,
We have a parallel program running on a cluster. We recently found a case, which decreases the CPU usage and increase the run-time when increases Nodes. Below is the results table.
The particular run requires a lot of data communication between nodes.
Any thoughts about this phenomena? Or is there any way we can improve the CPU usage when using higher number of nodes?
Average CPU Usage (%) Number of Nodes Number of Threads/Node 100 1 8 92 2 8 50 3 8 40 4 8 35 5 8 30 6 8 25 7 8 20 8 8 20 8 4
Thanks!
_________________________________________________________________________
The information transmitted is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you received this in error, please contact the sender and delete the material from any computer. _________________________________________________________________________ _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Lu, Huiwei
