Re: [mpich-discuss] MPI_Info key host error in SLURM
I notice in the output that the sbatch version uses --launcher slurm while the interactive version uses --launcher ssh. Can you try adding --launcher ssh to the mpiexec command of you sbatch script and see if it makes a difference? Ken On 3/1/21, 1:38 PM, "Iker Martín Álvarez" <[email protected]> wrote: Hi Ken, Thanks for your reply. Here are attached two files with the arg "-v". BatchOutput.txt has the output which is giving the error message when the code is executed with the command sbatch, while the file InteractiveOutput.txt is the one executed interactively in the node and work as expected. Both of them has been compiled and executed with mpich 3.4.1. Thanks, Iker El vie, 26 feb 2021 a las 16:15, Raffenetti, Kenneth J. (<[email protected]>) escribió: Hi, Could you add "-v" to your mpiexec command and provide the output? The "host" info key is handled by the process manager when executing the spawn command. Ken On 2/24/21, 11:55 AM, "Iker Martín Álvarez via discuss" <[email protected]> wrote: Hi, I have been working around the MPI_Comm_spawn function with the key "host" along a value in a system with the SLURM resource manager (slurm-wlm 17.11.2). The function works as expected, but when I send to execute the code with the sbatch command, an error arises. This does not happen when I execute directly the code in the same machine SLURM decided to execute it when it was sended with sbatch. In both cases with the key "host", as when I do not use the key, it works just fine. The same code has been tested with MPICH 3.3.2 and 3.4.1, which gives different errors. Also, I tried it with other implementations (OpenMPI and Intel MPI), which works as expected creating the processes in the indicated host. I would like to create processes by MPI_Comm_spawn in an assigned host, so if there are other key values for the Info argument, I could try them, but I have not found any looking through MPICH documentation. Here is the code I have been using: int main(int argc, char ** argv) { int myId, numP; MPI_Info info; MPI_Comm comm; MPI_Init(&argc, &argv); MPI_Comm_rank(MPI_COMM_WORLD, &myId); MPI_Comm_size(MPI_COMM_WORLD, &numP); MPI_Comm comm_par; MPI_Comm_get_parent(&comm_par); if(comm_par != MPI_COMM_NULL ) { if(myId == ROOT) { printf("SONS\n"); fflush(stdout); } } else { if(myId == ROOT) { printf("FATHERS\n"); fflush(stdout); } MPI_Info_create(&info); MPI_Info_set(info, "host", "n00"); MPI_Comm_spawn(argv[0], MPI_ARGV_NULL, numP, info, ROOT, MPI_COMM_WORLD, &comm, MPI_ERRCODES_IGNORE); } MPI_Finalize(); return 0; } For MPICH 3.4.1 there is sometimes no error and the code stops working at MPI_Comm_spawn function, other times this error is shown: Abort(1615120) on node 0 (rank 0 in comm 0): Fatal error in PMPI_Init: Internal MPI error!, error stack: MPIR_Init_thread(152)...: MPID_Init(562)..........: MPIDU_Init_shm_init(195): Init_shm_barrier(94)....: Internal MPI error! barrier not initialized Also, the error code for MPICH 3.3.2: Assertion failed in file src/mpid/ch3/channels/nemesis/src/mpid_nem_init.c at line 683: our_pg_rank < pg->size Assertion failed in file src/mpid/ch3/channels/nemesis/src/mpid_nem_init.c at line 683: our_pg_rank < pg->size Assertion failed in file src/mpid/ch3/channels/nemesis/src/mpid_nem_init.c at line 683: our_pg_rank < pg->size libbacktrace: no debug info in ELF executable libbacktrace: no debug info in ELF executable libbacktrace: no debug info in ELF executable libbacktrace: no debug info in ELF executable libbacktrace: no debug info in ELF executable libbacktrace: no debug info in ELF executable libbacktrace: no debug info in ELF executable libbacktrace: no debug info in ELF executable libbacktrace: no debug info in ELF executable libbacktrace: no debug info in ELF executable libbacktrace: no debug info in ELF executable libbacktrace: no debug info in ELF executable internal ABORT - process 0 Thanks, Iker
participants (1)
