Re: [mpich-discuss] Iprobe does not find all messages.
Okay, just to check, is there a way to tell it to use eager (or eager threshold), or does MPICH just make that decision? Thanks, Steve ________________________________ From: Thakur, Rajeev <[email protected]> Sent: Tuesday, June 29, 2021 11:31 AM To: Hudson, Stephen Tobias P <[email protected]>; [email protected] <[email protected]> Subject: Re: [mpich-discuss] Iprobe does not find all messages. It shouldn’t matter whether it is eager or rendezvous. The envelope in the rendezvous contains the message matching information. Iprobe will initiate progress, so the next call to Iprobe should find a message if there is one. Rajeev From: "Hudson, Stephen Tobias P" <[email protected]> Date: Tuesday, June 29, 2021 at 11:27 AM To: "Thakur, Rajeev" <[email protected]>, "[email protected]" <[email protected]> Subject: Re: [mpich-discuss] Iprobe does not find all messages. Thanks Rajeev, is this going to be using rendezvous protocol, in which case the receiver has to receive an envelope and ping back. In that case, it may make sense to me? Does mpich have a way of controlling message sizes for eager/rendezvous as intel MPI does? I havn't found any environment variables. Thanks, Steve ________________________________ From: Thakur, Rajeev <[email protected]> Sent: Monday, June 28, 2021 9:13 PM To: [email protected] <[email protected]> Cc: Hudson, Stephen Tobias P <[email protected]> Subject: Re: [mpich-discuss] Iprobe does not find all messages. I guess the reason is that iprobe does not find a message until some MPI function causes progress on the communication. Just a delay will not cause progress. Rajeev From: "Hudson, Stephen Tobias P via discuss" <[email protected]> Reply-To: "[email protected]" <[email protected]> Date: Monday, June 28, 2021 at 4:30 PM To: "[email protected]" <[email protected]> Cc: "Hudson, Stephen Tobias P" <[email protected]> Subject: [mpich-discuss] Iprobe does not find all messages. Hi, TLDR: Why does iprobe not pick up messages that should be there? In this use-case, a manager is calling iprobe (via mpi4py) to look for messages received from various workers. In the receive function (1.), there is a loop over workers doing an iprobe for each worker, and only if it loops round them all receiving nothing does it come out. Each worker may have sent several messages. loop: 1. receive_func (loop over all workers doing iprobe - until none have anything) 2. do some other stuff. (actual code: https://github.com/Libensemble/libensemble/blob/main/libensemble/manager.py#...) The workers are sending with isend, and I know they have passed the isend call for all the required messages. Manager side, the iprobe loop does not necessarily pick up all messages in one call to receive_func (but if I replace each iprobe call with its own loop of several iprobes it does). In my code, the iprobe is part of a loop which may occasionally spend some time in another function (2.), so I want to better understand why it may not pick up all the messages. Even if I put a delay of a few seconds in (2), it still has cycles that do not pick up the messages - as though a certain number of iprobes are required. In particular, I want to understand whether the messages are present on the receiving end, maybe in the unexpected message buffer, but may not get picked up by the iprobe? Or is there some delay on the sending end (I know from timing the code has passed the isend for all messages). Also, as adding several iprobes (in their own sub-loop) always finds the messages, if the delay is not receiver side, then it must be doing some handshake? I have seen answers online, which suggest that this is expected behavior, but I wonder if there is a fairly simple explanation as to why iprobe does not pick everything up? If its too complicated, then okay. I am running on a Ubuntu laptop with $ mpirun --version HYDRA build details: Version: 3.2.1 Thanks, Steve
participants (1)
